Page 4 of 4 FirstFirst ... 2 3 4
Results 46 to 50 of 50
Thread: O-Ring (Oil Pump Drive Seal) Fix (Pictures)
  1. #46
    I experienced the pop cap phenomenon, myself. I bent the edge out a bit and shoved it back in place and then coated the top with RTV.
    NOTE TO ALL... try to cut above the level of the cap insert. it protects lubricant on a bearing on the top of the drive gear, though it is not under pressure from the oil sytem.
    BUILDER AND DESTROYER OF FINE(?) AMERICAN CARS.
  2. The Following User Says Thank You to Crazy K For This Useful Post:
    RobertISaar (09-02-2010)
  3. #47
    Will these methods work for a 94 3.1? I went to look at mine and it was hard to tell.
  4. #48
    Quote Originally Posted by eeltam View Post
    the parts you need are the same(gasket, paper backup gasket), but I would pull the plenum and intake instead of the exhaust for access. Only the LQ1 requires the hack, all other engines don't.
  5. #49
    I didn't have to relieve fuel pressure, I just lifted the fuel rail our of the way, held temporarily out of the way with a zip tie
    '92 5 speed GTP - Mod list _____ 95 Monte Carlo Z34 - DD _____ 91 GP Sedan - lent to GF as her DD
  6. #50
    Forum Moderator GOT2B GM's Avatar
    3D Quick Pool Champion!
    Join Date
    Aug 2004
    Location
    Kitchener, Ontario, Canada
    Posts
    10,755
    Thanks
    468
    I've gotta do this on my black vert, just bought the brown GM silicone o-ring and the dizzy gasket.
    Matt Shantz
    '95 Oldsmobile Cutlass Supreme Vert LQ1
    '94 Oldsmobile Cutlass Supreme Vert LQ1
    '90 Pontiac Turbo Grand Prix #0058 of 2749
    '92 Pontiac Grand Prix GTP - 282
    '92 Chevrolet Lumina Z34 - 284
    '88 Pontiac Fiero GT - 282
    '01 Cadillac Seville STS - Corsa
    '01 GMC Yukon Denali - GM 22's
    Quote Originally Posted by Mach 5
    Car is machine, Matt is boss status trained precision task killer..
oil pump drive seal
1989 cutlass supreme international
3.4 oil pump drive seal
drive line picture for a 1990 oldsmobile
3.1 oil pump drive seal
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
