Results 1 to 6 of 6
  1. #1
    base93lumina's Avatar
    Join Date
    Jan 2012
    Location
    Central Arizona
    Posts
    260
    Thanks
    5
    Remove Exhaust Rasp 3800 Motor *J-Pipe*
    Okay, now i know some may talk about it, and there may be some threads talking about it, but cannot find what im asking.
    As anyone who has owned a 3800S2 motor, whether is be supercharged or not, will tell you, there is pretty much no way to make a 3800 sound good with exhaust that produces zero rasp above 3k. Now, there are some companies out there that make exhaust systems for newer vehicals that include some kind of added in J-pipe. Which is supposed to remove the rasp, and help produce a deeper tone. See below:
    Now, this does a pretty good job on the F-150s, but what im wondering, if theres a way to make this idea work on the Grand Prix chassis? I want to do a full 3" exhaust but i really dont want the excessive raspyness these motors are plagued with. Any thoughts? Or any other ideas how to remove that raspyness?
    Geoff
    00 Pontiac Grand Prix GTP: Couple Mods
    93 Chevy Lumina Base: Few Mods
  2. #2
    jake91's Avatar
    Join Date
    Sep 2008
    Location
    mesa, az
    Posts
    5,684
    Thanks
    585
    i know your asking about this j pipe i cant comment on that except it looks restrictive, but fyi the stock dual exhaust on a gtp is good down to 12s so there is no reason to spend the cash on a catback. your best bet is to run sd headers with the largest thrush glasspack you can find as a resonator then borla mufflers
    http://youtu.be/NjMwRPQMd8s
    another option is flow masters
    http://youtu.be/wu_Tb2KHWGw
    or if you like strait up loud no mufflers
    http://youtu.be/kpYGvuAV3H8
    the one thing all these have in common is a large thrush glasspack to cut the rasp
    Quote Originally Posted by WhatTheFehl View Post
    Buying a TGP with the intention of making money on it is like buying a Boeing 747 to get free peanuts.
    2003 Pontiac Grand Prix GTP - SLP intake, Intense poly dogbone mounts
    1994 Oldsmobile Cutlass Supreme Convertible [2009 3Q COTQ] - Sold
  3. #3
    Andrew's Avatar
    Join Date
    Jul 2003
    Location
    Shelton, WA
    Posts
    4,170
    Thanks
    63
    i replaced the OEM resonator with a Vibrant res, almost no rasp. ZZP sells a big one, but its pricy. The red Thrush piece is only $29 on Summitracing.
    00 GTP - mine | 05 Mariner - hers | 95 F150 - ours?
  4. #4
    ricklovin93's Avatar
    Join Date
    Feb 2012
    Location
    Utica,NY
    Posts
    431
    Thanks
    6
    pretty cool looking if you ask me, one reason i wont drive a 3800 the noise that comes from the exhaust is unbearable
  5. The Following User Says Thank You to ricklovin93 For This Useful Post:
    RobertISaar (07-02-2012)
  6. #5
    Join Date
    Jan 2012
    Location
    Central Arizona
    Posts
    260
    Thanks
    5
    Jake that second clip actually sounds pretty damn good!
    See whati was thinking was the ZZP downpipe, some kind of resonator, full 3" all the way back, and split the y-pipe into two 3" pipes, and then a couple of blow thru Magna's to complete it. Havent heard anyone do it yet, but we will see how it goes. Sounds rediculous, but i have noticed over the years the larger the pipe, the deeper and less raspy the note gets.
    Am i getting that the best way to keep the rasp down, is make sure you have a long resonator after the cat?
    Geoff
  7. #6
    RobertISaar's Avatar
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,712
    Thanks
    984
    happen to know what happens with oversized exhaust pipes? exhaust streams slows down when it goes to a larger pipe(or splits to a pipes that have more area). this causes a lot of odd things to go on, including a drop in torque at lower RPMs with the possibility of increasing power at hgiher RPM, if the engine flows enough to need it.
    a single 3" pipe has an area of 7.07 square inches. if you split to duals, a pair of 2.125" pipes would be the same area.
    King of Code
    1995 Monte Carlo LS 3100, 4T60E... for now, future plans include driving it until the wheels fall off!
grand prix j pipe
pontiac grand prix resonator delete
how to get rid of exhaust rasp
exhaust rasp or no rasp
how to make a 3800 engine sound nice
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
