Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
  1. #1
    1994RedVert's Avatar
    Join Date
    Apr 2012
    Location
    A, A
    Posts
    334
    Thanks
    17
    94 Cutty 3.4L Alternator going bad! Need help with changing it out!
    Alright, I was driving my car home the other night and I lost almost all my battery power, had to shut down the stereo, fog lights anything I didn't need just to get the battery guage to climb a little. How hard is it to change the alternator on the 3.4L? I see you might be able to get to it from the passenger wheel well. Why the hell would GM put an alternator in that position, what dumbasses! But, I need to know if anyone has changed this and what all you had to do to get to it and change it.
    1994 Red Cutlass Supreme Convertible with Heads Up Display and a 3.4L DOHC. Work in progress.
    2011 Honda Accord (Wife's Car) completely stock.
  2. #2
    Galaxie500XL's Avatar
    Join Date
    Aug 2009
    Location
    Knoxville, Tennessee
    Posts
    1,209
    Thanks
    430
    Try this article, it's a "sticky" in the FAQ section...
    http://www.w-body.com/showthread.php...epair-Write-Up
    1995 Cutlass DOHC Convertible
    3rd Quarter 2012 COTQ
    232,000 miles, and counting.
    Got 3 kids----it IS their father's Oldsmobile...
  3. The Following User Says Thank You to Galaxie500XL For This Useful Post:
    1994RedVert (06-25-2012)
  4. #3
    Breakdown's Avatar
    Join Date
    Sep 2007
    Location
    Kitchener, ON
    Posts
    3,123
    Thanks
    194
    As an FYI, I've had a number of seemingly alternator issues that were not alternators.
    Dead battery, and a whole bunch of problems with voltage drops all over the place on the car because of poor grounds. I would cover my bases first.
    Get the battery in to be checked out and go from there, at least it's reasonably easy to access, and for the love of God if you are going to get the alternator out, please have it bench tested before putting a new one in.
    Others will have to help with the access to the alternator. I know what you need to do, but not exactly how to do it.
    BTW . . . read my signature.
    BREAKDOWN ABILITIES: In car mode, his engine emits vibration that causes mechanical failures in other vehicles...can speed to 200 mph...uses concussion cannon in robot mode.
    Quote Originally Posted by bigalwalker08
    Ignore 90% of the comments here but be sure to listen to Breakdown.
    Quote Originally Posted by xtremerevolution
    If it took me 7-14 hours to change an alternator, I'd set the car on fire and roll it down a hill.
    . . .then I'd set myself on fire.
  5. The Following User Says Thank You to Breakdown For This Useful Post:
  6. #4
    Join Date
    Apr 2012
    Location
    A, A
    Posts
    334
    Thanks
    17
    Thanks you guys. I will check my grounds. How many are there on the car? I guess I can clean them up and get the battery checked first. I love this car but I am tired of my volt meter going from good to no good. But, the ground thing sounds right because usually an alternator just goes. Never had one go from bad to good in two days. But, the battery shouldn't effect anything because once your car is running you are running off the alternator. But, I will check it out. What helped you fix your voltage problems?
  7. #5
    Join Date
    Aug 2009
    Location
    Posts
    1,209
    Thanks
    430
    I used to have problems with them coming and going on my old LeBaron convertible...the brushes were the problem..the rebuilder didn't do a good job finishing the commutator,and the brushes would "bounce", killing output. Fortunately, I bought a "lifetime" alternator...went through 4 in 110,000 miles.
    Quote Originally Posted by 1994RedVert View Post
  8. #6
    Join Date
    Apr 2012
    Location
    A, A
    Posts
    334
    Thanks
    17
    You mean the brushes inside the alternator?
  9. #7
    Join Date
    Aug 2009
    Location
    Posts
    1,209
    Thanks
    430
    Yes..but technically, the brushes contact a slip ring, not a commutator...
  10. #8
    Join Date
    Apr 2012
    Location
    A, A
    Posts
    334
    Thanks
    17
    Ok, I am going to try everything you all are telling me. Now my lights dim and everything. And if I speed up to 80 the volts go back up. what do you think this could actually be? The alternator or my grounds? I can check both.
  11. #9
    Join Date
    Jan 2006
    Posts
    773
    Thanks
    28
    Please describe where YOU would put it.
    "The most negative fricken troll ever." --Bee Twenty
  12. #10
    Join Date
    Apr 2012
    Location
    A, A
    Posts
    334
    Thanks
    17
    Where most cars have it located on the top of the engine easily accessible. Like on the 3.1L engines.I haven't ever seen an alternator in the location that it is in on the 3.4L.
  13. #11
    RobertISaar's Avatar
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,716
    Thanks
    984
    with the LQ1, to do that, you would need a good extra 6" of hoodspace. the timing components prevent it from being high up.
    King of Code
    1995 Monte Carlo LS 3100, 4T60E... for now, future plans include driving it until the wheels fall off!
  14. #12
    Forum Moderator GOT2B GM's Avatar
    Join Date
    Aug 2004
    Location
    Woodstock, Ontario, Canada
    Posts
    11,633
    Thanks
    591
    ram air alternator
    Matt Shantz
    '95 Oldsmobile Cutlass Supreme Vert LQ1
    '94 Oldsmobile Cutlass Supreme Vert LQ1
    '90 Pontiac Turbo Grand Prix #0058 of 2749
    '92 Pontiac Grand Prix GTP - BAM -282
    '92 Chevrolet Lumina Z34 - 284
    '88 Pontiac Fiero GT - 282
    '01 Cadillac Seville STS - Corsa
    '01 GMC Yukon Denali - GM 22's
    '92 Subaru SVX -101k mi FOR SALE $2000
    Quote Originally Posted by Mach 5
    Car is machine, Matt is boss status trained precision task killer..
  15. #13
    Join Date
    Aug 2009
    Location
    Posts
    1,209
    Thanks
    430
    On my old 3.0 LeBaron convertible, the power steering pump sat where the alternator does on my LQ1...it had a long dipstick tube to allow access to the fluid...the alternator was then put on top, where the power steering pump is on the LQ1...worked pretty well...I never had power steering pump problems on the LeBaron, but went through several alternators...
    Quote Originally Posted by Schurkey View Post
  16. #14
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,860
    Thanks
    20
    Also check your auxiliary post nut to make sure it hasnt come loose
    98 Regal GS - 275k, on the race to 300k
    99 Silverado Z71 - 204k, BGA express
    03 Grand Prix GT - 81k, Hopefully will see the road again someday
    97 Grand Prix GTP - 173k, Sloppy Seconds V2.0
    Quote Originally Posted by BXX View Post
    Al is a big sexy stud
    Quote Originally Posted by 95GPSE View Post
    But the Grand Prix is a Grand Prix, which automatically trumps all.
  17. #15
    Join Date
    Apr 2012
    Location
    A, A
    Posts
    334
    Thanks
    17
    Quote Originally Posted by AL View Post
    My Auxillary post nut? Is that the one on the drivers side with the red cap on it that you use to jump the car's battery?
w-body.com 94 cutlass 3.4 change alternator
1995 olds 88 alternator problem
videos showing 3.4 alternator
How difficult is it to change a alternator in a 2007 Cadillac STS 3.4
video on how to replace a alternator on a 94 cutlass supreme
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
