Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
  1. #1
    Gen1 Monoleaf pad isolators - damages spring
    So I'm about a year & 10k miles down the road from installing the Moog monoleaf pad isolators on my car, and have made a disturbing discovery. These things are abrasive. There's this white powder all over the spindle, and the nylon has worn away the gelcoat and eaten into the spring.
    Also, the K6000 "spring helpers" I installed four years ago have developed a damaging quirk as well. The rubber picks up small rocks and compresses it into the spring, breaking through the gelcoat and pitting it.
    I pulled a replacement monoleaf off a '96 GP sedan in the yard yesterday as insurance in case anything happens to mine, but now I wonder - is the rear monoleaf the same between coupe & sedan? And installing it is gonna be a mofo...
  2. #2
    Community Manager White93z34's Avatar
    Join Date
    Jan 2004
    Location
    Pittsburgh, PA
    Posts
    10,458
    Thanks
    46
    Same setup between coupe and sedan. It seems that the pre 1992 leaf springs dont seem to sag nearly as much.
    leaf spring install is not too bad provided you have the correct spring compressor.
    -Chris D. - Your Community Manager
    Quote Originally Posted by Breakdown View Post
    Clearly you are living in some sort of stupid delusional world where our group cannot organize itself out of a wet paper bag, come to a consensus on anything.
    1992 Chevrolet Lumina Z34 3.4L TDC v6 Getrag 284
    1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
    1997 Pontiac Bonneville SSE Supercharged 3.8L v6, Hydramatic 4T60E
    1987 Chevrolet Camaro Z28/IROC-Z 5.0L v8, Hydramatic 700R4
  3. #3
    94 olds vert's Avatar
    Join Date
    Sep 2009
    Location
    Eastpointe, Michigan
    Posts
    7,264
    Thanks
    283
    This is now the second time I've heard about these Moog monoleaf pads eating or chewing up the monoleaf on one of these cars.
    I'll have to watch mine and see what they do. Beautiful car by the way.
    Last edited by 94 olds vert; 05-30-2012 at 03:56 PM. Reason: iPhone auto correct fail
    Nate
    1994 Cutlass Supreme Convertible [2Q 2012 COTQ]
    1991 Grand Prix GT
  4. #4
    Quote Originally Posted by White93z34 View Post
    I thought it was the 94+ monoleafs that were better? After having removed one and actually held it in my hands, these things are unbelievably lightweight, easily less than a single coilspring, and the rollbar is also a lot smaller. A coilover conversion must add some significant weight...
    As for the spring compressor, I didn't know there was one for a monoleaf. That's gotta be a strange-looking tool.
  5. #5
    Quote Originally Posted by 94 olds vert View Post
    This is now the second time I've heard about these Moog monoleaf pads eating or chewing up the monoleaf on one of Hester's cars.
    Who's Hester??
    Thanks, these cars can be a real struggle at times, but I think the 7-year resto was worth it. I'm going to try a spray-on rubber coating to see if that helps.
  6. #6
    Come to think of it, gluing a square piece of innertube onto the pad would probably work too.
  7. #7
    Penglii's Avatar
    Join Date
    Sep 2009
    Location
    Portage, WI
    Posts
    913
    Thanks
    232
    Quote Originally Posted by crazyd View Post
    http://www.ebay.com/itm/Kent-Moore-J...639385&vxp=mtr
    Quote Originally Posted by RobertISaar View Post
    in a W, sometimes, it's easier to pull the engine than it is to pull the battery.
  8. #8
    Join Date
    Jan 2004
    Location
    Pittsburgh, PA
    Posts
    10,458
    Thanks
    46
    Thats the one I have. Awkward tool to say the least but man does it make removing and installing springs a breeze.
  9. The Following User Says Thank You to White93z34 For This Useful Post:
    LuminaPower92 (05-30-2012)
  10. #9
    Join Date
    Jan 2004
    Location
    Pittsburgh, PA
    Posts
    10,458
    Thanks
    46
    All I know for sure is pretty much most 92+ cars are totally dragging the rear at this point where most the 88-91 stuff is still riding where it should be (if not too high).
  11. #10
    Check out my suspension tuning post for weight difference of coil over vs monoleaf. If you need a back up back up i have monoleaf avail
    1978 Ford F150
    1994 Oldsmobile Cutlass Supreme Vert
    2001 Honda Accord EX
    2010 Mercury Milan Premier
    Gone: 88 F150, 89 Grand Am, 95 Caravan, 01 Jetta VR6, 03 Neon, 98 Regal
  12. #11
    Penglii's Avatar
    Join Date
    Sep 2009
    Location
    Portage, WI
    Posts
    913
    Thanks
    232
    I have one as well, never had to use it yet though.
    It is quite large and heavy, but the usage instructions are dead simple and i'm sure it beats losing a finger/face/etc. any day of the week.
    $120 shipped for one is a great deal.
  13. #12
    Garrett Powered's Avatar
    Join Date
    Jul 2005
    Location
    OREGON
    Posts
    4,373
    Thanks
    90
    I thought you guys were talking about Schurkey's spring compressor. that thing looks like a ripoff.
    yeah, there is a guy on here that designed one that can easily be made in a few minutes with a few dollars and a welder.
    anyway if the springs gelcoat is the only problem. that is EASY and super cheap to re- gelcoat. evercoat has pints and all you would have to do is brush on a couple coats. might have to degrease it quick first. don't know if it would work but its an idea.
  14. #13
    Quote Originally Posted by topless94style2 View Post
    Wow, surprised to see it's pretty much a negligible weight difference... Gotta think though that those massive strut assemblies must give some benefit over the small coilover shock. The Delco gas-charged units I have in there now are heavier than the stock oil units, but they ride & handle way better.
  15. #14
    jman093's Avatar
    Join Date
    Dec 2007
    Location
    Wichita, KS
    Posts
    1,268
    Thanks
    17
    The spring will fit, but the spring rates may be different. Here are the codes. Check the rpo between your car and the one you're pulling from.
    Transverse leaf spring codes:
    Highest
    RHU
    RFL
    RFK
    RFJ
    RFH
    RFF
    RHN
    RDN
    RDM
    RHH
    RDK
    RDJ
    RDH
    RDF
    RDD
    Lowest
    Jesse M.
    2005 Corvette - Stock. 55,000 miles.
    1987 Monte Carlo SS Aerocoupe. Stock 305. 180,000 miles. 15.62 @ 90mph.
    Former W's
    1996 GTP Special Edition
    1993 Lumina Euro coupe
  16. #15
    Join Date
    Oct 2004
    Posts
    2,618
    Thanks
    348
    Meh, this is why i purchase a birchmount.
    Your Source for Auto Recon and Lumina Customization.
cutlass supreme leaf spring install
mono leaf springs 93 chevy lumina
mono leaf diagram for 96 lumina
how to install leafspring pads on cutlas supreme
93 pontiac grand prix mono leaf spring
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
