Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 79
  1. #16
    skitchin's Avatar
    Join Date
    Apr 2011
    Location
    St. Louis, MO
    Posts
    1,006
    Thanks
    464
    Ah, I understand - so getting into the realm of my noobness, where does the coolant flow when the thermostat is closed?
    1995 GRAND PRIX SE 2 DR >278,000 miles - 2nd owner, Daily driven since 2004
    Mod List
    1975 GMC Sierra K25 w/ 454 Swap - Brownie
    1995 Pontiac Grand Prix SE coupe 3100 SFI - Old Faithful
    2011 Chevrolet Camaro 2SS/RS L99 A6 - MJ
  2. #17
    RobertISaar's Avatar
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,836
    Thanks
    997
    coolant constantly circulates whenever the engine is running. when the thermostat is closed, it just constantly cycles through the block/heads. when it opens up, then it will flow out and into the radiator.
    King of Code
    1995 Monte Carlo LS 3100, 4T60E... for now, future plans include driving it until the wheels fall off!
  3. #18
    skitchin's Avatar
    Join Date
    Apr 2011
    Location
    St. Louis, MO
    Posts
    1,006
    Thanks
    464
    OBD 1(.5?), can a scanner read transmission temp?
    Mod List
  4. #19
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,836
    Thanks
    997
    how to do you think i scan and reprogram mine?
    a GOOD scanner or pretty much any ALDL cable will work to read off temps.
    King of Code
  5. #20
    Join Date
    Jan 2006
    Posts
    793
    Thanks
    28
    Quote Originally Posted by RobertISaar View Post
    I admit that I'm surprised that there's a temp sensor in the transmission pre OBD-II. I'm reasonably certain that neither my '92 nor my '93 (both OBD-I) will display trans temp on my scanner.
    "The most negative fricken troll ever." --Bee Twenty
  6. #21
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,836
    Thanks
    997
    just depended on the platform. certain GM cars had them all the way back to 91 IIRC. W-bodies got them with the newer style of 4T60E in 93 for 3100s, 94 for 3.4/3.8.
    King of Code
  7. #22
    skitchin's Avatar
    Join Date
    Apr 2011
    Location
    St. Louis, MO
    Posts
    1,006
    Thanks
    464
    OT here but how do you reprogram? I've always thought you hd to pull the computer and actually reflash a chip. Any info/links appreciated.
    Mod List
  8. #23
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,836
    Thanks
    997
    another "depends on the application" situation. 93-95 3100 cars (except for the A-bodies) use a reflashable PCM, similar to how the OBD2 units flash through their DLC, we flash via the ALDL connector.
    PM me for specifics, lets try to keep this OT.
    King of Code
  9. #24
    rich17's Avatar
    Join Date
    Mar 2005
    Posts
    434
    Thanks
    51
    If it were me I would go to the treasureyard and look through the truck section. You can find most for trucks with a small oil cooler and probally pick it up cheap. And it'll have sme sort of mounting bracket on them
    1996 Chevrolet Lumina 9C3 Police Package|L26 4T65 swapped
  10. #25
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,836
    Thanks
    997
    for real fun, hit up the diesel section. some of them have trans coolers the size of our radiators.
    King of Code
  11. #26
    Join Date
    Jan 2006
    Posts
    793
    Thanks
    28
    Quote Originally Posted by rich17 View Post
    Don't forget to add in the cost of flushing the cooler.
    If the transmission those coolers are attached to is blown-up or worn-out, the coolers will be full of wear particles.
  12. #27
    virtuetovice's Avatar
    Join Date
    Aug 2010
    Posts
    1,138
    Thanks
    391
    I've had a trans cooler from a Chevy Caprice police car on my junkyard trans, in my Cutlass for about a year now and the trans never shows any signs of being too hot, and the fluid is still a nice pretty red color. I see no problem with it. I just did NOT trust my stock trans cooling system after my old trans assploded, god knows what kinds of chunks are floating around in the lines and cooler assembly.
    this IS a General Motors product and the general rule is that nothing should make actual sense.
    Quote Originally Posted by pwmin View Post
    who knew a pansy-ass 2.8L V6 would sound so glorious
    This message was sent from my 2012 Cadillac CTS
  13. #28
    AWeb80's Avatar
    Join Date
    Nov 2002
    Location
    FEMA Region 7
    Posts
    9,478
    Thanks
    304
    I put a cooler on the GP and the Aurora. I'll see if I have pics of it mounted on the GP....
    I do know that at idle on a 95* bright sunny day, my trans cooler will be around 175*. I use my dads infrared thermometer. I'd say at idle w/ no airflow, 175* is pretty good. I do know that it takes a bit for the trans to warm up and get into OD. So if you drive on the Hwy right away every morning, it will take 5 mins or so to shift in to OD.
    '09 Triumph Daytona 675 - 4,800 miles - Toy
    '94 GP SE - 136k miles - Owned for 12 years - In storage
    '03 Maxima SE 3.5 6-speed - 82k miles - Nice Car
    '94 Civic EX - 224k miles - Daily Beater
    Quote Originally Posted by Crazy K
    I LOVE AWEB
    Quote Originally Posted by Woll Smoth
    I'm a sexy bitch, but I can't hold a candle to you
  14. #29
    AWeb80's Avatar
    Join Date
    Nov 2002
    Location
    FEMA Region 7
    Posts
    9,478
    Thanks
    304
    *** At first I had it mounted using the zip-tie things that go through the radiator and condensor. PLEASE don't do it this way, it really fucks up the fins*****
    I remounted it as shown below:
    found the pics
    I mounted mine on the drivers side. I used 1/8" alum strips and cut them to fit...nothing fancy....and hold the cooler. I found short bolts in my scrap can and use nylock nuts to mount it. I hasn't moved in the ~8k miles since. On the bottom mounts, There are little notches in the bottom of the rad support where the bolts slip right in to.
    On the top mounts I used one of the bolts for the engine mount and used another already existing hole and just tapped it for a bolt to thread in.
    Then spray painted everything black to hide it a bit.
    I LOVE AWEB
  15. The Following User Says Thank You to AWeb80 For This Useful Post:
    skitchin (04-27-2012)
  16. #30
    skitchin's Avatar
    Join Date
    Apr 2011
    Location
    St. Louis, MO
    Posts
    1,006
    Thanks
    464
    Awesome pics Adam - really do like your mounting method way more than those stupid zip ties. This just looks so much cleaner and sturdy. Definitely think I'll try to replicate what you've done here. Thanks!
    Mod List
93 chevy lumina 4t60e transmission
2004 grand prix transmission cooler
transmission coolers bigger the better
1993 3.1 grand prix adx
normal operating temperature for 1005 bonneville pontiac
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
