Results 1 to 11 of 11
  1. #1
    Lurker
    Join Date
    Oct 2005
    Posts
    161
    Thanks
    0
    New best times for the 3500 Lumina!
    Well I did not make it out to the track in the fall so I went yesterday for the opening weekend! weather was a nice and sunny, 14*c and a bout a 15-20km tail wind!
    here are some of the runs:
    15.447@92.45
    15.431@92.63
    dropped the tire pressure a bit and let it cool for 1/2h:
    r/t............ -.122
    60'........... 2.332
    330.......... 6.388
    1/8........... 9.757
    mph.......... 73.32
    1000'........ 12.616
    1/4.......... 15.020
    mph......... 93.58
    The it ran a 15.265@92.22
    and a 15.204@93.67mph
    only changes from last year are the 2.5" cat back (now full 2.5" maniflod back) and some 205/55r16 snow tires on some gp wheels!
    sooooo close to a 14.999! might try again in a few weeks, if not maybe later next month. really need a tune and to get the headers on!
    1992 Lumina 3.1v6 17.02@ 79.84mph, 3400 powered 15.67@ 92.05mph, Now 3500 powered! 15.020@ 93.58mph(still 3.1 tune)
    2002 Grand Am GT stock 2005 3500 15.651@ 87.81mph
    1984 type 10 Cavalier hatch 3100 5spd 14.96@91.47mph in the 1/4
    9.63@74.36mph 1/8th 14.30 full interior on slicks! (scrapped )
    1976 Cutlass (soon to have boost!)
  2. #2
    RobertISaar's Avatar
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,710
    Thanks
    984
    15.2 on a 3.1 tune....
    i don't suppose you at least monitor the O2 sensor (wideband or narrow)? you have to be seriously lean from about 3000 RPM and up.
    King of Code
    1995 Monte Carlo LS 3100, 4T60E... for now, future plans include driving it until the wheels fall off!
  3. The Following User Says Thank You to RobertISaar For This Useful Post:
    MonteCarloDude (04-08-2012)
  4. #3
    MonteCarloDude's Avatar
    Join Date
    Dec 2006
    Location
    Columbus, Ohio.
    Posts
    2,243
    Thanks
    585
    Agreed, I was starting to lean out a bit with just the mods I have, before I got a tune. That's on a 3100 tune to boot.
    1998 Monte Carlo LS, Dark Toreador Metallic.
    P&P 3400 UIM, LIM, And TB, 180*T-Stat.
    Custom FWI. Dyno Tuned.
    Polyurethane Dogbone Engine Mounts.
    Custom Shift Kit / Dexron VI.
    GMPP Front And Rear STB's, SS Rear Brake Lines.
    Quote Originally Posted by Twenty
    I don't always sell my GP, but when I do, I buy it back
  5. #4
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,710
    Thanks
    984
    you run on a MAF system though, which will recognize airflow changes. with speed-density, major mods requires adjusting the VE table to reflect that, otherwise the airflow isn't accounted for and significant enleanment happens.
    King of Code
  6. #5
    Lurker
    Join Date
    Oct 2005
    Posts
    161
    Thanks
    0
    Quote Originally Posted by RobertISaar View Post
    15.0 on a 3.1 tune! going to put the WB in within the next week or two to see where its at. Ran it on 94 octane with a bottle of octane boost to help keep things a little safer.
    3000rpm+ is where it starts pulling like mad! under 3000 it is a dog.
    I will try to get the vids up tomorrow night!
  7. #6
    tornado_735's Avatar
    Join Date
    Mar 2006
    Location
    Marengo, Ohio
    Posts
    2,257
    Thanks
    1,178
    You know what they say... Lean=Power
    Unfortunately, Lean also equals the potential for a V6 grenade
    ~Aaron
    1999 Buick Century Custom - 3100 V6 - 127k
    2001 Subaru Outback LL Bean - 3.0L Boxer-6 - 139k
    Quote Originally Posted by CrazyK
    I could do a better alignment on this car if i were Helen Keller with a tape measure...
  8. #7
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    7,710
    Thanks
    984
    Quote Originally Posted by 1QUICKHATCH View Post
    how missed the bolded text, i'll never know.
    94 octane will help keep away damage due to knock(that and it sounds like Sunoco, which i've had nothing but excellent results with), but cylinder temps are still going to be sky-high due to the lean AFR. and those bottles of octane booster are a joke. "8 point" bottles in actuality mean a .8 increase in octane. 3000 is where the factory UIM/LIM starts to come alive, but for the same reason, it's why it also starts leaning out there.
    Quote Originally Posted by tornado_735 View Post
    this is true. if you have an engine design that can run stoich ratios at WOT, you can do some impressive things, but that generates a lot of heat in a very small amount of time, which gets transfered to the pistons, heads and head gaskets. if you're lucky, the head gaskets pop before the pistons do.
    King of Code
  9. #8
    19Cutlass94's Avatar
    Join Date
    Apr 2005
    Location
    Texas
    Posts
    10,140
    Thanks
    40
    IDC what anyone says, I dont believe the "lean is mean" theory...
    Jay
    1994 Oldsmobile Cultass Supreme SL
    3400/Getrag 284
    1995 Chevy K1500 350c.i. 5spd Z71
    Stock
  10. #9
    Join Date
    Mar 2006
    Location
    Marengo, Ohio
    Posts
    2,257
    Thanks
    1,178
    Quote Originally Posted by 19Cutlass94 View Post
    I've seen it happen the track...friend of mine races karts, and the leaner he runs, he faster he is. Unfortunately, he's melted a few pistons that way by forgetting to check his EGTs.
    ~Aaron
  11. #10
    Join Date
    Feb 2012
    Location
    New Britain, Connecticut
    Posts
    58
    Thanks
    0
    nice times OP! get that thing tuned!!
  12. #11
    Lurker
    Join Date
    Oct 2005
    Posts
    161
    Thanks
    0
3.1 lumina port and polish
lumina 3100 melted piston
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
