Results 1 to 10 of 10
  1. #1
    COnvertible top help!!
    ok so ive had my cutlass 1995 for about a month now, and when i used to put the top down only one side would go down so i would manually pull the other one down. Now the problem is when i was raising it, the left side was going up, and it bursted or something, lije a hydraulic line thing that looks like a strut had a bunch of fluid, so now when i try to push up or doen it just squirts something. and the right side one never worked, how would i go about fixing this?? thanks.
  2. #2
    White92Cutlass's Avatar
    Join Date
    Aug 2010
    Location
    Springfield, Mo
    Posts
    405
    Thanks
    11
    Sounds like you need a couple of convertible top cylinders- unless the fluid is just coming out of the line that leads into the cylinders. The cylinders run about $75.00 a piece used.
    1992 Oldsmobile Cutlass Supreme Convertible
    White Body, White Top, Black Interior
    3.1 Liter Engine
    1993 Oldsmobile Cutlass Supreme Convertible (now a parts car for the '92)
    Red Body, Black Top, Black Interior
    3.1 Liter Engine
  3. #3
    Quote Originally Posted by Red93Cutlass View Post
    ok thanks for the quick response, and are those the same things as rams?? and where would i find them? any websites or do i have to hunt them down? thanks again
  4. #4
    Rick's Avatar
    Join Date
    Jun 2011
    Location
    Misery, Missouri
    Posts
    181
    Thanks
    11
    Check to see if a brass looking connection connecting the cylinder to the arm...thats the best way I can think of describing it. Should be around a 2" Brass peice that the cylinder arm threads into I believe. Both of mine broke, cylinders were still good but it was the cause of the top not going up since the cylinder was not connected to the arm or something..ill take a look at mine tomorrow to try and give a better description lol.
    1994 Cutlass Supreme Convertible Red with Black Top and Interior --- Blown Transmission
    1995 Cutlass Supreme Convertible Green with Tan Top and Interior --- 112K 3.4DOHC No Rust Great Condition
    http://www.youtube.com/LordRichardIV <--Have videos of my Cutlass(s) on there
  5. #5
    Join Date
    Aug 2010
    Location
    Springfield, Mo
    Posts
    405
    Thanks
    11
    Quote Originally Posted by pimpin213 View Post
    I've occasionally heard them referred to as rams. Salvage yards, ebay, and this board are your best bets for them used. www.convertibletopguys.com has them for $140 apiece.
    Do you have fluid coming out from both cylinders or just one?
    3.1 Liter Engine
    3.1 Liter Engine
  6. #6
    oldsfever's Avatar
    Join Date
    Nov 2011
    Location
    Coppell, Tx.
    Posts
    127
    Thanks
    5
    I think you need to replace the hydralic cylinders and possibly the hoses as well. I've done it on two different verts and it's not that difficult.
    DUH! For some reason I didn't see any responses to this pot when I first looked at it. Sorry for repeating what had been said. I've gotten both of mine on ebay for $60 a piece used but I've had good luck with them. The web site Red93Cutlass referred you too is an excellent choice for new ones. I've dealt with them and they are good.
    Good Luck.
  7. #7
    Quote Originally Posted by Rick View Post
    Are those under the cylinders??
  8. #8
    Thanks for the link, im going to try to find some used ones first. Do you guys know if cylinders from any other car will work?? the cutlass ones are hard to find on ebay used.
  9. #9
    Join Date
    Aug 2010
    Location
    Springfield, Mo
    Posts
    405
    Thanks
    11
    I don't think cylinders from other cars will work. You'll come across some somewhere soon.
    3.1 Liter Engine
    3.1 Liter Engine
  10. #10
    ok i hope so, i had another question too, would anyone of you happen to know why when i close the top, the front doesnt seal all the way? like thewres a big gap and i have to put a garbage bag so it doesnt leak in the rain. any help thanks
convertible top not going up
packard convertible top cylinders will not work. fluid is going to them
1992 cutlass supreme convertible top rams
1995 cutlass supreme convertible front top seal
how to change cylinder convertible top cutlass 1993
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
