Results 1 to 8 of 8
  1. #1
    Join Date
    Aug 2002
    Posts
    167
    Thanks
    0
    Transmission swap???
    I have a 95' olds cutlass supreme with an automatic on the column...this winter i planned on converting the tranny to an automatic on the floor, but then i got to thinkin' and heres the question i got....would a manual transmission out of a lumina z34 fit into my car with some modifications?
  2. #2
    Join Date
    Aug 2002
    Location
    Battlefield, MO
    Posts
    10,621
    Thanks
    94
    You don't want that tranny. You can't get parts for it, not through GM, not through Getrag, nobody will sell parts for it. Damaged trannies must be replaced AS A UNIT.
    If you want a 5-speed, use the HM-282 found in the 88-90 Grand Prix and 88-89 Cutlass Supreme. You CAN get parts for it.
  3. #3
    TurboSedan
    qa
  4. #4
    Join Date
    Aug 2002
    Posts
    167
    Thanks
    0
    I already planned on gettin a set of tenzo r racing seats and trying to find a console out of a grand prix or another cutlass, where would i be able to get one of the transmissions that you were talking about?
  5. #5
    Good luck adding a clutch pedal as well. I would use the 282 as well, not because its "evil" like shawn thinks but because of the gearing. Its made for the 3.1 which means its decent for the 3100 as well.
    It would be easier to swap your interior onto a 90 with the 5 speed and dropping your motor in.
    Ben
    WOT-Tech
  6. #6
    TurboSedan
    qa
  7. #7
    Not on a 95 though. They have a bar welded across the bottom of the dash I believe. Im going by what has been said before. I just know its not the same as the 91-93 cars which you can see where the clutch pedal would go.
    Ben
    WOT-Tech
  8. #8
    Join Date
    Sep 2002
    Posts
    117
    Thanks
    0
    I am buying a 88 Cutlass International 2.8l 5spd manual this weekend for parts. That means I may have a manual trans for sale if I dont do the swap myself on my 89 Cutlass. If I were to sell it does anyone have any idea what it would be worth with the clutch pedal and cylinder and even the console... the complete conversion package. Thanks!
lumina z34 manual transmission swap
how to convert a 93 lumina into a manual transmission
lumina z34 manual transmission for sale
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
