Just picked up a nearly new set of aftermarket headlight assemblies with HIDs already installed and ready to go. The setup looks plug and play, but before I install them, a few questions:
1. You're supposed to be able to just plug these into the stock harness and go. Any idea how well the harness will take to the HIDs? should I add a relay in the line at all?
2. I'd like to kill the DRLs to prolong the HID ballast life, and it looks like pulling a specific fuse will do the trick. Are there any side-effects I should be aware of if I kill the DRL? (i.e.-killing DRL also kills the light sensor on the dash)
Thanks!
