Results 1 to 3 of 3
Thread: fuel pressure at wot?
  1. #1
    I had a low tank and while idleing heard my fp make a bit of a howling noise. It is OE with 238k miles. I put gas in and no more sound , but have noticed full throttle is a bit weak. I tested pressure at idle..it is around 35 line off. I need to test drive at wot and get a reading, what do yall think it should be?
    Thanks
    ps- its a 1994 regal 3.8
  2. #2
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,149
    Thanks
    15
    You dont test pressure at WOT
    FUEL PRESSURE:
    Ignition ON Engine OFF 40.5 to 47.0 psi
    98 Regal GS - 260k, Aquamans sloppy seconds, for sale
    99 Silverado Z71 - 196k, BGA express
    04 Ford Focus ZTS 2.3L/5 speed - 176k, also for sale
    Quote Originally Posted by BXX View Post
    Al is a big sexy stud
    Quote Originally Posted by 95GPSE View Post
    But the Grand Prix is a Grand Prix, which automatically trumps all.
  3. #3
    Quote Originally Posted by AL View Post
    FUEL PRESSURE:
    I wanted to to see if it sags under full demand...but, Im shy of the spec range you give , so ill go by that and r/r the pump. The tester i have does have a bleed line and when its opened the pressure drops alot, but there's nothing to compare it to.
    thanks for the spec.
wot fuel pressure test
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
