Results 1 to 12 of 12
Thread: 2001 Regal GS Engine Tick
  1. #1
    Join Date
    Sep 2009
    Posts
    140
    Thanks
    9
    I usually don't drive my Regal in the winter, but a few weeks ago since it was so warm I took it out. After driving for about five minutes the engine started making a ticking noise.
    I searched this forum and found a post suggesting to use Rislone engine treatment. So I changed the oil and added a quart of that, but after a couple days of driving it still makes the ticking noise. The ticking doesn't start immediately upon starting -- it takes a few minutes.
    I saw a lot of posts about the supercharger coupler causing a rattling, and I figured with 170,000 miles that needed to be replaced anyway. So I went to do that, but discovered that it must have been done by the prior owner because the coupler looks perfect.
    One note: I had the lower intake gasket and supercharger gasket replaced in May. (Preventative maintenance -- it wasn't leaking that I was aware of.) I had only driven the car about 3,000 miles since. So it was on the oil change that was done when the intake gasket was replaced. I had monitored the oil level since the gasket was replaced and there were no signs of any leakage.
    Here is a video. The noise sounds louder in the video than it does in person. In fact the normal engine noise sounds a lot louder in the video as well. I guess it's just he microphone on my camera.
    I'm not planning to drive the car regularly for a month or two. So I could take a shot at fixing something myself before taking it to a shop. But I'm not sure what to try.
    Have any of you heard this noise before? (The noise starts at 1:30 on the video.)
    Thanks!
    1994 Cutlass Supreme Convertible
    2001 Buick Regal GS
    2000 Chrysler Town & Country AWD
    2000 Lincoln Continental
  2. #2
    I heard it best around 1:50-2:00 in the video.
    From what I heard, it sounds like a lifter?
    Is the noise coming from the top or bottom of the engine? It didn't sound like a bearing.
    If you had a Tech2 scanner (~$1,200 for a China mod/clone/referb/whatever), you could likely do an cylinder balance test (disable each cylinder one by one). I don't know what exactly each engine supports. Also, with the ticking sounding not too bad, I think that it's questionable that you would be able to accurately diagnose the bad cylinder/lifter. Yes, you always replace all of the lifters. But, a weak cylinder along with the tick would lead more towards a bad lifter.
    Be aware that lifters in OHV engines often "mushroom" and can sometimes be a massive pain to remove.
    You could also bring it to a dealer (not a local shop), and have them diagnose the problem. My guess is maybe ?$300? for the basic scan/testing.
    It's likely cheaper to just put in new lifters.
    Good Luck!
    Joe
    '00 Olds Intrigue ; '94 Olds Achieva. DOHC-HO 5 Speed :-) ; '92 Olds Achieva ; 69 Firebird 350 ; '86 Mustang with 95 Cobra brakes and ABS.
    Gone, but never forgotten: '77 Cutlass 350. :-)
  3. The Following User Says Thank You to Cutlass350 For This Useful Post:
    bg35765 (02-04-2012)
  4. #3
    Night Fury's Avatar
    Join Date
    Sep 2007
    Location
    St. Joseph MO
    Posts
    7,814
    Thanks
    1,223
    It kinda sounds like an exhaust leak..
    -1991 Pontiac Grand Prix GTP 3.4 5-speed 174k, 'project'
    -1988 Pontiac Grand Prix SE 2.8 5-speed 256k, DD
    -2006 Chevrolet Monte Carlo LT 3500 211k, Kenny's DD
  5. The Following User Says Thank You to Night Fury For This Useful Post:
  6. #4
    Join Date
    Sep 2009
    Posts
    140
    Thanks
    9
    Quote Originally Posted by Cutlass350 View Post
    Thanks. That's what I was thinking, but I didn't want to put that idea in anyone's mind before they watched the video.
    It sounds like it's from the top of the engine to me, especially from inside the car. But my ears have played tricks on me before.
    Quote Originally Posted by Night Fury View Post
    Hmmm...I hadn't thought of that. Does it make sense that the noise wouldn't be there for several minutes and then would start?
    2001 Buick Regal GS
  7. #5
    Addicted to eaton's Avatar
    Join Date
    Oct 2007
    Location
    Chillicothe mo
    Posts
    5,639
    Thanks
    257
    Nope thats a lifter.. i would put sea foam it and let it idle for 30 mins then change the oil
    2006 Kia rio, 114k miles
    2002 Grand Prix GTP. 40th Anv edition, 3.8L Supercharged V6, 130$ BBQ special. 111,000k
    2001 Chevy Impala, 3.4L SFI. 141,000k
    1997 Chevy Silverado 350 5.7L vortec z71, 250k
    1997 Grand Prix GTP, 3.8L supercharged V6 -Knocking motor mod. 189,000k
    1995 BMW 325I Slow, old, and high tech.
  8. The Following User Says Thank You to Addicted to eaton For This Useful Post:
  9. #6
    3pt1lumina's Avatar
    Join Date
    Feb 2005
    Location
    Ontario, NY
    Posts
    2,133
    Thanks
    21
    Just from my personal experience I will never use Rislone in any of my engines ever again. I was told by my cousin (who builds race car engines) to put some in. WRONG. I put it in my Chevelle , 305 2bbl with 82k on it, and it opened Pandora's box. That used to be a quiet running engine, now I have all sorts of noises and it developed an oil leak. It was in there maybe 50 miles then I changed the oil, but now I have a rod knock on start up.
    Not sure if that was a special scenario, but I'll NEVER use that stuff in any of my cars ever again.
    ---The Cavalry---| 1975 Laguna | 1977 Chevelle | 1977 Monte Carlo |1990 Lumina | 1996 Lumina | 1997 Lumina | 1999 Lumina LS | 1999 Monte Carlo Z34 | 1999 Regal GSE | 2009 Malibu LT | 2012 Chevy Cruze (wife's) | It's a sickness...
  10. #7
    Euro's Avatar
    Join Date
    Jan 2004
    Location
    Streamwood, IL
    Posts
    12,935
    Thanks
    375
    Yeah it kind of sounds like a lifter to me. My lifter(s) are noisy when the engine's cold, but it goes away after a couple of minutes of running. I've ran sea-foam through it but it didn't really help.
    -Matt
    2000 Regal GS - Stock is the bestest...stock is the fastest...
    2000 Grand Prix GT - Yeah sure, I miss you too
    1994 Lumina Euro - Miss you..
  11. #8
    Galaxie500XL's Avatar
    Join Date
    Aug 2009
    Location
    Knoxville, Tennessee
    Posts
    851
    Thanks
    155
    Using additives (seafoam, Rislone, transmission fluid, etc) in the oil to try to quiet a noisy lifter is a chancy prospect at best, one I prefer not to take, because of the potential to create new problems. Most common cause of ticking lifters is either dirt at the check ball seat, a galled check ball seat, or a weak/broken lifter spring.
    What you're hoping by using the additives is that it's dirt in the lifter, preventing the check ball from completely sealing, which is causing the lifter to leak down...but usually, in my experience, by the time you get to the point of hearing the lifter, the damage is already done, and the only real fix is to replace the lifter.
    1995 Cutlass LQ1 DOHC Convertible
    1993 Buick Century Station Wagon "The Refrigerator"
    2008 Chevrolet HHR 2LT
    One LQ1 in my driveway is plenty.
  12. #9
    Join Date
    May 2007
    Posts
    7,190
    Thanks
    605
    Quote Originally Posted by Galaxie500XL View Post
    X2
    And do it fast before you start beating the cam lobe and wearing out the pushrod.
    1995 Buick Regal GS(X) - Heavily modified. /modlist
  13. The Following User Says Thank You to xtremerevolution For This Useful Post:
    Galaxie500XL (02-08-2012)
  14. #10
    Join Date
    Aug 2009
    Location
    Posts
    851
    Thanks
    155
    Xtreme:
    I realized after I walked away from the post that I had forgotten to mention that...you're exactly right. The "ticking" sound isn't actually the lifter per se, but the slack being taken out of the valvetrain as the lifter rises, due to the lifter being leaked down. In other words, the lifter is slamming into the slack at the pushrod over and over...eventually, something is going to give...whatever's weakest.
    Quote Originally Posted by xtremerevolution View Post
    X2
  15. #11
    Join Date
    May 2007
    Posts
    7,190
    Thanks
    605
    Xtreme:
    I realized after I walked away from the post that I had forgotten to mention that...you're exactly right. The "ticking" sound isn't actually the lifter per se, but the slack being taken out of the valvetrain due to the lifter being leaked down. In other words, the lifter is slamming into the slack at the pushrod over and over...eventually, something is going to give...whatever's weakest.
    Precisely. Ask me how I know.
    Actually, don't. I had a lifter get stuck and the ticking noise started. Its not just the pushrod that starts to give; its the lifter roller. Those things are only designed to take so much impact. Mine cracked and the cam lobe started beating it to death. Eventually, the crack on the roller opened up, the needle bearings fell out, and the cam lobe started getting shredded as it beat the roller flat against the lifter.
    The end result was a thrashed cam at 217k miles, after which the L67 was swapped in to keep my car running.
    Its good that you realized this. Just be aware that you can potentially have a very expensive problem on your hands if you prolong this repair.
  16. #12
    I say lifter as well. Use this as an excuse to upgrade your rockers while you are in there!
    00 GTP - mine | 05 Mariner - hers | 95 F150
2001 buick regal gs engine noise when warm
99 buick regal engine ticks after 30 minutes
99 regal gs ticking from engine
when to userislone
02 regal engine ticking
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
