Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Brakes real weak unless pumped a few times
  1. #1
    So my brakes in the sedan are annoying the crap out of me. A few weeks ago they seemed to be getting worse as it was getting colder, and didn't think too much of it because of the age, and temps. Well, it started getting to where I felt it unsafe, so I topped it off because it was a bit low, and it was fine for like a day. Both before I topped it off and after, it seems as though my brakes barely work, unless I pump them a few times coming up to where I need to brake, and if I do so they seem fine, but then next time I have to stop I have to do it again. Maybe I sucked air in and need to bleed them? any other thoughts?
    '92 5 speed GTP - Mod list _____ 95 Monte Carlo Z34 - DD _____ 91 GP Sedan - lent to GF as her DD
  2. #2
    Booster going bad?
    2004 Pontiac Grand Prix Comp G- ZZP 3" downpipe with high flow cat, U-bend delete, high flow mufflers, K&N drop in... The DD
    2008 Ford Ranger XLT- 2.3 DOHC I-4 5-speed- Street truck project in progress...
  3. #3
    ahh, that could be too! I've never done any brake work up by the booster, so I don't know what kind of symptoms I'd have.
  4. #4
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,149
    Thanks
    15
    The booster usually makes for a really hard pedal... Like braking when the car is off... If your fluid was low, it may be leaking out somewhere and thats where you are losing your pressure
    98 Regal GS - 260k, Aquamans sloppy seconds, for sale
    99 Silverado Z71 - 196k, BGA express
    04 Ford Focus ZTS 2.3L/5 speed - 176k, also for sale
    Quote Originally Posted by BXX View Post
    Al is a big sexy stud
    Quote Originally Posted by 95GPSE View Post
    But the Grand Prix is a Grand Prix, which automatically trumps all.
  5. #5
    94 olds vert's Avatar
    Join Date
    Sep 2009
    Location
    Eastpointe, Michigan
    Posts
    5,724
    Thanks
    420
    That's how my brakes felt before I swapped them. I thought they were supposed to feel like that.
    Nate
    1994 Cutlass Supreme Convertible
    1991 Grand Prix GT
  6. #6
    urbex's Avatar
    Join Date
    Feb 2011
    Location
    Flint, MI
    Posts
    2,074
    Thanks
    402
    I know whenever I have to move the car it feels like I'm going to crash into something because I have to push the brakes so hard and it doesn't do shit...
    1983 Chevy C-10 Scottsdale Pickup (166k miles) Built 4/83 in Flint, MI, Received 1/05
    1999 Chevy Lumina (163k miles) Built 9/9/98, Purchased 8/14/06 PAINT PEELING MOD!!!
    2006 HHR 1LT (53k miles) Built 5/24/06, Purchased 2/17/09
    Quote Originally Posted by virtuetovice View Post
    Sometimes when I'm home alone I lay in my closet and pretend I'm a carrot.
  7. #7
    kinger_13's Avatar
    Join Date
    Jan 2012
    Location
    Newfoundland
    Posts
    15
    Thanks
    0
    It sound like your Master cylinder is on its way out. I had this problem on an older vehicle once. If you pump the brake pedal and hold it, is there pressure first and then it goes down? If so I'd say Master cylinder.
  8. #8
    Did you loose any brake fluid after you topped it off?
    If not, it's the Master Cylinder.
    If you lost fluid, check the calipers, hoses, and brake lines for leaks.
    A bad booster makes the brakes hard.
    Make sure you use a good flare wrench on the fittings on the brake lines. Otherwise, you can round off the fittings. A cheap flare wrench can also round off fittings. For really tough fittings, I carefully use the vise grips made specifically for use on nuts.
    Good Luck!
    Joe
    '00 Olds Intrigue ; '94 Olds Achieva. DOHC-HO 5 Speed :-) ; '92 Olds Achieva ; 69 Firebird 350 ; '86 Mustang with 95 Cobra brakes and ABS.
    Gone, but never forgotten: '77 Cutlass 350. :-)
  9. #9
    x2 on checking the calipers first, including the sliders/pins too since that could create a similar effect. Given your sedan is a '91 I'd check the rears before anything else.
    Yeah, it's still on the road. 5/21/12 210,800+
  10. #10
    Join Date
    Jan 2006
    Posts
    533
    Thanks
    20
    Poor braking power with
    Low, squishy pedal = hydraulic problems especially air in the hydraulic system, but could be defective seals in the master cylinder.
    High, hard pedal = defective booster or seized calipers. Possible ABS problems, but not as likely.
    Both my '92 and my '93 had defective boosters. Neither has had defective calipers in the time I've owned them (bought '92 in November, '92; bought '93 about 5 years and 40,000 miles ago. I think the reputation for seized rear calipers is exaggerated--but I acknowledge that my sample size is pretty small.
    "The most negative fricken troll ever." --Bee Twenty
  11. #11
    Quote Originally Posted by Schurkey View Post
    Plus, it's easy to verify a bad booster. Remove the vacuum line at the check valve, plug the vacuum line with a bolt to prevent a vacuum leak, and see if there's any difference in the brakes. On my Intrigue, when the booster went, it also caused cylinder misfires because of the vacuum leak. BTW, when I plugged booster vacuum to verify a bad booster, it also got rid of the cylinder misfires.
    For my Intrigue, doing a booster R&R means fully removing the ABS/TC unit.
    Old Booster removed, ABS removed, EGR valve removed:
    New Booster, ABS (right), EGR valve(left) installed:
    Joe
  12. #12
    I'll have to check some things out tomorrow, maybe I can convince Eric to help me out. Food is a good negotiating tool
    It seems to hold pressure just fine when stopped, but I have to pump it again shortly after if stopping again. I do have a rotor or caliper messing up as well, but I don't think it's really related, just time to replace it anyways
  13. #13
    Join Date
    Jan 2006
    Posts
    533
    Thanks
    20
    Quote Originally Posted by Cutlass350 View Post
    Neither of my boosters leaked vacuum or caused misfire. Both boosters had "some" assist--the '92 had a bit more than the '93, but neither had PROPER, FULL assist.
    Truth is, I didn't know a booster could fail that way--to simply have reduced power assist without vacuum problems--but I'm two-for-two.
  14. #14
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,149
    Thanks
    15
    It sounds like a bad master cylinder because its not sending the proper pressure to the wheels
  15. #15
    Join Date
    Oct 2011
    Posts
    294
    Thanks
    20
    Did you bleed the brakes or just dump new fluid in ontop of the old stuff?
    '96 Pontiac Grand Prix SE coupe. 3100, stock until something breaks.
breaks dont work unless pumped
need to pump brakes to stop but brakes fine after pumped
intrigue abs
why dont my breaks work unless i pump themEGR valve 2004 gtp comp g
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
