Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: rear struts
  1. #1
    Join Date
    Oct 2011
    Posts
    294
    Thanks
    20
    rear struts
    Just did the front struts (bearings/cartridge/mount) and now I aim to do the rear ones, it's been taking bumps real hard in the rear lately. They're original AFAIK. Mounts are probably shot.
    Is there anything to the rear strut besides the shock, strut to knuckle hardware, and upper mount? Am I forgetting anything?
    It's getting a new leaf spring too...it sags in the rear pretty bad (one isolator is missing and the spring is starting to break on the other side.) Should ride like a new car by the time I'm done.
    Since complete strut assemblies are available for these cars I might just get a pair of those, depending on price locally. RockAuto prices are great but shipping a big strut is expensive as shit.
    disclaimer: no, I am not converting to coilovers.
    '96 Pontiac Grand Prix SE coupe. 3100, stock until something breaks.
  2. #2
    94 olds vert's Avatar
    Join Date
    Sep 2009
    Location
    Eastpointe, Michigan
    Posts
    5,724
    Thanks
    420
    Theres four bolts. 2 up top and two at the knuckle. The top ones you don't want to break. Spray them a couple nights before and heat it up if you can the night before. Those are 15 mm.
    The bottom ones are 1" and with a good sized breaker bar you should be able to break them free. They are splined at the ends so leave the nut on past the threads and hit them out. Be careful not to damage the threads.
    It's the strut and mount. The cartridge should already be attached to the knuckle mount.
    Hope that helps. If you have any more questions I might be able to help. I recently did this too.
    Nate
    1994 Cutlass Supreme Convertible
    1991 Grand Prix GT
  3. The Following User Says Thank You to 94 olds vert For This Useful Post:
    brake (02-01-2012)
  4. #3
    Join Date
    Oct 2011
    Posts
    294
    Thanks
    20
    Thanks man. I don't need to get at the top bolts through the trunk, do I?
  5. #4
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,149
    Thanks
    15
    I believe you do
    98 Regal GS - 260k, Aquamans sloppy seconds, for sale
    99 Silverado Z71 - 196k, BGA express
    04 Ford Focus ZTS 2.3L/5 speed - 176k, also for sale
    Quote Originally Posted by BXX View Post
    Al is a big sexy stud
    Quote Originally Posted by 95GPSE View Post
    But the Grand Prix is a Grand Prix, which automatically trumps all.
  6. The Following User Says Thank You to AL For This Useful Post:
    brake (02-01-2012)
  7. #5
    Yes, the two up top can be accessed inside the trunk when you pull the carpeting away from the sides of the trunk.
    2004 Pontiac Grand Prix Comp G- ZZP 3" downpipe with high flow cat, U-bend delete, high flow mufflers, K&N drop in... The DD
    2008 Ford Ranger XLT- 2.3 DOHC I-4 5-speed- Street truck project in progress...
  8. #6
    Join Date
    Sep 2009
    Location
    Posts
    5,724
    Thanks
    420
    When you remove the carpet you will see two bolts coming up from the strut tower. Spray those with PB blaster or similar. The bolts actually come out from the wheel well because the head is inside the wheel well.
    Nate
    1991 Grand Prix GT
  9. #7
    Join Date
    Oct 2011
    Posts
    294
    Thanks
    20
    thanks guys. looks like quick struts are ~$90 a side locally. it's expensive but shipping makes buying big items like these online cost prohibitive.
  10. #8
    Join Date
    Sep 2009
    Location
    Posts
    5,724
    Thanks
    420
    Having a rear quick strut will make things a little easier. Plus you won't need the tool to put the mount on.
    Nate
    1991 Grand Prix GT
  11. #9
    Join Date
    Oct 2011
    Posts
    294
    Thanks
    20
    huzzah. found a canadian ebay seller. the parts are probably cheap but whatever...$128.12 with free shipping for a pair of complete rear strut assemblies.
  12. #10
    Join Date
    Sep 2009
    Location
    Posts
    5,724
    Thanks
    420
    That's a good price.
    Nate
    1991 Grand Prix GT
  13. #11
    Join Date
    Oct 2011
    Posts
    294
    Thanks
    20
    not at all. I'll have to hold off on buying them for a couple of weeks, need an alignment after my new inner tie rods this week.
  14. #12
    Join Date
    Sep 2009
    Location
    Posts
    5,724
    Thanks
    420
    You might need an alignment after doing the rear struts.
    Nate
    1991 Grand Prix GT
  15. #13
    Join Date
    Oct 2011
    Posts
    294
    Thanks
    20
    Quote Originally Posted by 94 olds vert View Post
    good call. i'll get the front end as close as possible at school and have a shop do the front and rear when i finish up with the rear struts.
  16. #14
    Lurker radray64's Avatar
    Join Date
    Dec 2010
    Location
    central Kentucky
    Posts
    22
    Thanks
    7
    Advance auto parts website has the Monroe Econo-matic quick strut, it came out to $137 with a promo code and free shipping or pickup at store, I think I may get those.
  17. #15
    Join Date
    Dec 2010
    Location
    central Kentucky
    Posts
    22
    Thanks
    7
    I haven't priced all the stuff for the front struts, How much are we looking at here?
    Where are you getting the leaf spring too?
w-body.com rear struts for a 94 cutlass
1991 grand prix rear struts
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
