Hello and greetings. I am in the mist of planning an engine swap for my 95 cutlass supreme sl.
List of what i current have confirmed to make this work.
(comfirmed)
External crank tigger
new cam resized to fit new journal or lock the vvt cam
using the 3900 rail by using a fuel regulator with a bypass
north start throttle body and adapter
(unsure/ needing to know)
If i get the engine from a impala will the compressor line up so i can still retain my ac
Have been told that the engine mounts should all line up.
Injector connections from the donor car should work if i soder the connectos on
Any help to make my list more complete would be nice.
Thank you in advance.
