Results 1 to 3 of 3
Thread: Injector O-Rings
  1. #1
    Lurker radray64's Avatar
    Join Date
    Dec 2010
    Location
    central Kentucky
    Posts
    22
    Thanks
    7
    Injector O-Rings
    you have a starting or running problem and suspect a fuel problem, I suggest changing the Injector O-Rings,
    Ive done this and well worth the ten dollars I spent not to mention the gas mileage you get back!
    Anyone Have any input to this?
  2. #2
    Join Date
    Jan 2006
    Posts
    533
    Thanks
    20
    Quote Originally Posted by radray64 View Post
    Anything can go bad. Everything wears out eventually.
    That said...I haven't seen a lot of fuel injector O-rings wear out. They don't get that hot, they're not under much compression--and they don't seal against enormous pressure.
    So if changing the O-rings made a big difference for you...great. Hasn't been an issue for me.
    "The most negative fricken troll ever." --Bee Twenty
  3. #3
    Join Date
    Oct 2011
    Posts
    294
    Thanks
    20
    Just spray around your O rings with WD 40 or carb cleaner. If your idle changes, replace 'em.
    '96 Pontiac Grand Prix SE coupe. 3100, stock until something breaks.
Nobody landed on this page from a search engine, yet!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
