Results 1 to 9 of 9
Thread: Rear Brake question
  1. #1
    Join Date
    Aug 2011
    Location
    Allen Park, MI
    Posts
    8
    Thanks
    2
    Rear Brake question
    So I know that to get the piston back in to the rear calipers, they have to be threaded in with a special tool.
    Question I have is, do both sides have to be turned to the right (clockwise) or do they alternate from each side (one side clockwise, the other counter)?
    If they alternate, which side goes which way?
  2. #2
    95 vert's Avatar
    Join Date
    May 2008
    Location
    Kingsville Mo.
    Posts
    655
    Thanks
    5
    Both clockwise. Push in as you turn
  3. The Following User Says Thank You to 95 vert For This Useful Post:
    TheDeacon (01-24-2012)
  4. #3
    Join Date
    Jan 2006
    Posts
    533
    Thanks
    20
    Quote Originally Posted by TheDeacon View Post
    WHAT YEAR?
    The first design caliper--to at least '93--it is MUCH easier to pull one nut and one washer on the back of the caliper, remove the park brake cable lever--and then squeeze the piston STRAIGHT IN.
    The park brake shaft will spin instead of the piston. WAY EASIER.
    Re-connect the park brake cable lever, install washer and nut just like they were before. Done.
    This "may" work for the later caliper--I've never dicked with the newer ones.
    "The most negative fricken troll ever." --Bee Twenty
  5. #4
    95 vert's Avatar
    Join Date
    May 2008
    Location
    Kingsville Mo.
    Posts
    655
    Thanks
    5
    Quote Originally Posted by Schurkey View Post
    WHAT YEAR?
    There is a chance you will cause a fluid leak by removing the lever and knock the park brake out of adjustment.
    Push and turn can't be harder to do. Even if you don't have the "special tool". A pair on needle nose pliers works.
  6. #5
    Join Date
    Aug 2011
    Location
    Allen Park, MI
    Posts
    8
    Thanks
    2
    WHAT YEAR?
    The vehicle in question is a 1995 Pontiac Grand Prix SE, 3.1
  7. #6
    Join Date
    Aug 2002
    Location
    Battlefield, MO
    Posts
    10,438
    Thanks
    53
    I would highly recommend one of those brake caliper tool sets that will rotate and push the caliper piston in at the same time. It's awesome. I got it for $10 from Harbor Freight when it was on sale. I couldn't find it on the website, but if you have a local store, it's worth looking for. Way better than that stupid cube (though I have one of those too).
  8. #7
    19Cutlass94's Avatar
    Join Date
    Apr 2005
    Location
    Schenectady NY
    Posts
    9,491
    Thanks
    27
    Ive always used pliers and a screwdriver
    Jay
    1994 Oldsmobile Cultass Supreme SL
    -Modded
    1995 Chevy K1500 350c.i. 5spd Z71
    -Modded
  9. #8
    Join Date
    May 2007
    Posts
    7,190
    Thanks
    605
    Quote Originally Posted by 19Cutlass94 View Post
    Precisely what I've always done. 248k miles and my original rear brakes are working just fine...
    1995 Buick Regal GS(X) - Heavily modified. /modlist
  10. #9
    Autozone rents that tool in their loaner program. easy to use!
    BUILDER AND DESTROYER OF FINE(?) AMERICAN CARS.
Nobody landed on this page from a search engine, yet!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
