REMOVE OR DISCONNECT
- Disconnect negative battery cable.
- Relieve fuel system pressure.
- Refer to Fuel System / Service and Repair.
DISASSEMBLE
- Upper manifold assembly.
INSPECT
- Fuel pressure regulator bracket attaching screw.
- Regulator assembly and O-rings. Discard O-rings.
If fuel pressure regulator is to be reinstalled, inspect filter screen (if equipped) for contamination. If contaminated, remove and discard filter screen.
ASSEMBLE
Tighten
- Lubricate new O-rings with clean engine oil and install.
- Regulator and attaching screw.
Pressure regulator screw to 9.5 Nm (84 lb. in.).
INSTALL OR CONNECT
- Negative battery cable.
