Here's the video, the description pretty much describes the situation.
The low oil sensor was unplugged from whoever changed the starter. So the previous owner filled it. Although it was full. And not just filled it... He FILLED IT.
9 Quarts of oil in there. Drained 4 and left 5 in.
After taking out 6 OIL DRENCHED plugs, and sticking in some nice old ones I had handy, I got it running again.
Ran really good! Burned a lot of oil out the exhaust!
Then once it warmed up some it developed this ticking....
http://www.youtube.com/watch?v=5F0LmG3zp8I
Being that is was way way way overfilled, and the pistons were slapping the oil around. I'm sure there was a bit of foam in the oil.
Air isn't the greatest lubricator. Is it possible the foamy oil could have spun one of the cam bearings? :-(
Is it worth replacing?
The Alternator is bad,
P/S is bad,
The intake gaskets are shot,
It needs a full tune up,
A mysterious leak starting half way down the crank pulley,
and the dist. drive o-ring is leaking pretty bad it looks like.
Could this be just a bad exhaust manifold gasket???
Or is it a bad bearing or even a bad cam...
It needs about $300 to $400 in repairs as of now,
And if this ticking is going to be the death of the thing, I really would rather not put $300-$400 into a garbage engine...
Thank you all. I really do appreciate the input from this forum, even the stupid simple input! (As most solutions are stupid simple).
-Tim
EDIT---
If it's any help, the cylinder closest to the brake booster was the worst as far as the plug being oil soaked...
