Results 1 to 12 of 12
Thread: Rear wheel bearing
  1. #1
    Rear wheel bearing
    I've suspected for a long time that my rear passenger wheel bearing is shot, but at $100 for a new one I'll live with it. I've noticed lately on left curves it feels like the back end floats out, but not right turns. Could this be a symptom of a bad bearing? Alternately, could a bad bearing cause this sensation? Now that I've realized when/how it does that I can be careful, but knowing that it's potentially dangerous makes me want to figure out what it is and fix it.
    Does anyone have a wheel bearing around they'd wanna sell? If only I had kept the one off the GTP
    '92 5 speed GTP - Mod list _____ 95 Monte Carlo Z34 - DD _____ 91 GP Sedan - lent to GF as her DD
  2. #2
    Join Date
    Jan 2006
    Posts
    533
    Thanks
    20
    Jack up the wheel, check for play/binding/roughness???
    "The most negative fricken troll ever." --Bee Twenty
  3. #3
    55trucker's Avatar
    Join Date
    May 2007
    Location
    Oshawa, Ontario
    Posts
    185
    Thanks
    0
    Well, if indeed the wheel bearing has failed, then the longer you drive on that bad bearing the more possible damage you may do to the brake assembly at that corner.
    A bad bearing will naturally induce positive camber on the top of the wheel as it will tend to lean in. The entire wheel/rotor is now out of proper position, and, every time you apply the brakes the caliper/pads are pushing the rotor trying to get it back to vertical which puts undue stress on the caliper. Not a good thing.
    Rockauto has a selection of hubs for the car & many of them are less than $100 for the rear. Get a new (fresh) hub, even if you choose one of the very inexpensive items, that is still better than driving on a failed one.
    Steve
  4. #4
    I've grabbed several of these bearings in excellent condition from the junkyard for cheap..... you might be good trying that...
    no abs? I can have one in the mail for you asap.
    BUILDER AND DESTROYER OF FINE(?) AMERICAN CARS.
  5. #5
    are the abs and non ones different? I don't care if I don't have working abs, as long as I have a working wheel
  6. #6
    55trucker's Avatar
    Join Date
    May 2007
    Location
    Oshawa, Ontario
    Posts
    185
    Thanks
    0
    Well, does the ABS function properly on your car? If you choose to install a non ABS hub then the ABS system will start throwing alerts at you seeing as the harness for that corner is not returning a signal the controller as it is supposed to. As for the hubs themselves both will mount but the ABS unit has a cap mounted to back of the bearing that also has an electrical socket in the centre that the harness plugs into.
    Steve
  7. #7
    Matt, call me. I cannot take texts right now.
  8. #8
    IF I have abs it doesn't work, and my e brake is busted so I already have a brake light on the dash, so as long as they both physically fit. Ken I'll try to call you around 330 when I get off
  9. #9
    It's a 91... open hood and see if you have a power master. no powermaster, no abs... douche
  10. #10
    urbex's Avatar
    Join Date
    Feb 2011
    Location
    Flint, MI
    Posts
    2,074
    Thanks
    402
    Quote Originally Posted by Psych0matt View Post
    when I get off
    Quit trying to get off.....
    1983 Chevy C-10 Scottsdale Pickup (166k miles) Built 4/83 in Flint, MI, Received 1/05
    1999 Chevy Lumina (163k miles) Built 9/9/98, Purchased 8/14/06 PAINT PEELING MOD!!!
    2006 HHR 1LT (53k miles) Built 5/24/06, Purchased 2/17/09
    Quote Originally Posted by virtuetovice View Post
    Sometimes when I'm home alone I lay in my closet and pretend I'm a carrot.
  11. #11
    Quote Originally Posted by Crazy K View Post
    I'm sorry I don't have the infinite knowledge you do. What was I thinking.
  12. #12
    tornado_735's Avatar
    Join Date
    Mar 2006
    Location
    Marengo, Ohio
    Posts
    2,054
    Thanks
    1,496
    Best bet is the boneyard Matt. I pulled one off of a 70k LQ1 Cutlass at the yard that still felt like new.
    ~Aaron - "Jack of all trades, Master of none."
    1992 Chevrolet Lumina Euro 3.4 - 209k "Rockstar"
    1994 Pontiac Grand Prix SE Coupe - 214k - Rescue/DD
    Quote Originally Posted by GOT2B GM
    I can lodge a formal complaint.....or I can leave his truck on blocks and call it a day.....
W BODY REAR WHEEL BEARING
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
