Page 1 of 2 1 2 LastLast
Results 1 to 15 of 29
Thread: This is what happens when you get bored......
  1. #1
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Lets face it, our stock control arms are kinda weak, but also just plain out suck. Even new, they look like a car crusher mangled them Worse we are stuck with crappy heavy ass knuckle assemblies and mediocre brakes.
    What your looking at is aboot 1.5hrs worth of work including texting and sitting on my ass
    Before anyone pops up 'why don't I just buy a gen 2 car?' the answer is simple, I don't like them. What I like is having better/upgraded stuff on the most awsome W-bodies ever, Gen 1!!!
    If I have time at work tomorrow, I will run around the block to Aztec Steel and get some steel so I can finish the mounts, and then on the way home, stop by Sears and get a plumb bob so I can reference the other side for proper balljoint location when doing the front LCA mounts.
    -08 Kia Spectra SX -2.0L BetaII/Auto
    -07 Chevy Uplander LT -3.9L LZ9/4T65e
  2. #2
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Evil Genius, Mad Scientist, or just a Retard?
    You decide
  3. #3
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,149
    Thanks
    15
    All of the above?
    98 Regal GS - 260k, Aquamans sloppy seconds, for sale
    99 Silverado Z71 - 196k, BGA express
    04 Ford Focus ZTS 2.3L/5 speed - 176k, also for sale
    Quote Originally Posted by BXX View Post
    Al is a big sexy stud
    Quote Originally Posted by 95GPSE View Post
    But the Grand Prix is a Grand Prix, which automatically trumps all.
  4. #4
    Join Date
    May 2007
    Posts
    7,190
    Thanks
    605
    Minus the part where you had to butcher the subframe, nice!
    1995 Buick Regal GS(X) - Heavily modified. /modlist
  5. #5
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Quote Originally Posted by xtremerevolution View Post
    Butcher? There was no butchering It's not 100% trimmed. All will come together once its done.
    Can't wait to pick up some stock and get welding.
  6. #6
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Where I had to cut out, will prolly be 'boxed in' and take car of any weak points whatsoever.
  7. #7
    gpchris's Avatar
    Join Date
    Mar 2005
    Posts
    1,134
    Thanks
    3
    Very cool and worthwhile upgrade! Not only do you drop a ton of weight with aluminum parts you also gain like twice the braking power if you upgrade to the f-body brakes.
    -GREEN 1995 Pontiac Grand Prix SE - ???/???
    -White 1995 Pontiac Grand Prix GTP - LQ1/F40 6SPD MTX
    -Green 1996 Pontiac Grand Prix SE - L82/282 5SPD MTX
  8. #8
    Join Date
    May 2007
    Posts
    7,190
    Thanks
    605
    Quote Originally Posted by gpchris View Post
    Its not a serious amount of weight. I think the idea is to allow for better shocks options (KYB AGX) and better brakes. I'm curious as to how this will affect wheel offset.
    w-body brakes, when working well, can still brake perfectly well for just about anyone. The factory dual piston brakes can lock up the wheels all too easily unless you start track racing.
    Sent from my HTC Awesome using Tapatalk
  9. #9
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Wheel offset? Why do you think I gotta get a plumb bob so the balljoint is in the same location when I do the front mount.
    And yeah, going F-body brakes or whatever the latest and greatest 'bolt on' brake upgrade is
    And Andrei, not stock Gen 1 brakes are gonna be able to lock up my wheel/tire combo And I don't like having to use all my damn leg power to make a car stop.
    Needz to get a nice fat Gen 2 swap bar as well.. GMPP bar should do nicely.
  10. #10
    white4d96's Avatar
    Join Date
    Sep 2010
    Location
    Pleasant Prairie WI
    Posts
    1,390
    Thanks
    246
    Meh.
    On the forums I'm on that are more 2G and 3G-oriented, they hate their front LCA's and the fact that you can only get one poly bushing for them, and that the other bushing apparently likes to fail often.
    http://i475.photobucket.com/albums/rr118/jfleck91/untitled-1.jpg
  11. #11
    Join Date
    May 2007
    Posts
    7,190
    Thanks
    605
    All I know is that my brakes stop on a dime and people who I've given rides to will attest to that, and they don't require gobs of pedal to make it happen.
    That said, a larger brake rotor would be beneficial, no doubt. I've had smoke coming out of my front brakes on a few occasions on some hard 60-0 stops.
  12. #12
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Quote Originally Posted by white4d96 View Post
    Meh.
    http://shop.zzperformance.com/store/...for-WBody.aspx
  13. #13
    Join Date
    May 2007
    Posts
    7,190
    Thanks
    605
    $513 for a pair of control arms?
  14. #14
    Join Date
    Jan 2006
    Posts
    533
    Thanks
    20
    Is the ball joint-to-rear bushing location the same for both control arms? I'd think if it wasn't, you'll have caster/camber issues depending on how different they are.
    I'd love to see that front bushing after it's been run through a band saw. That bushing scares me. I think I'd prefer poly inserts with the stock geometry so the control arm hinges freely--I expect that front bushing has some bind in it. Maybe I'm wrong.
    What is it about the new control arm that allows bigger brakes than the old control arm?
    "The most negative fricken troll ever." --Bee Twenty
  15. #15
    Community Manager White93z34's Avatar
    Join Date
    Jan 2004
    Location
    Pittsburgh, PA
    Posts
    9,647
    Thanks
    31
    I think its largely the balljoint placement that allows for running gen2 knuckles/struts
    -Chris D. - Your Community Manager
    "Insanity has no brand loyalty" - Got2b GM
    1992 Chevrolet Lumina Z34 3.4L TDC v6 Getrag 284
    1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
    1997 Pontiac Bonneville SSE Supercharged 3.8L v6, Hydramatic 4T60E
    1987 Chevrolet Camaro Z28/IROC-Z 5.0L v8, Hydramatic 700R4
  16. The Following User Says Thank You to White93z34 For This Useful Post:
    xtremerevolution (01-09-2012)
Nobody landed on this page from a search engine, yet!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
