Results 1 to 12 of 12
Thread: anybody ever done this?
  1. #1
  2. #2
    AWeb80's Avatar
    Join Date
    Nov 2002
    Location
    Nebraska
    Posts
    9,191
    Thanks
    178
    I've read about some of the TDi guys notching their heads on some of their Jetta builds....
    Quote Originally Posted by Crazy K
    I LOVE AWEB
    Quote Originally Posted by Woll Smoth
    I'm a sexy bitch, but I can't hold a candle to you
  3. #3
    Join Date
    May 2007
    Posts
    7,188
    Thanks
    605
    I looked at the pictures and said "bullshit" instantly. You're creating ridges with hot spots and effectively causing predetonation.
    Not too bad of an idea for diesel engines, but a bad idea for gasoline engines and a terrible idea for performance gas engines.
    Seems the guys over on the Corvette forum think so too.
    http://forums.corvetteforum.com/c3-tech-performance/1634484-notching-cylinder-heads.html
    I think the following comment pretty much hits it dead on:
    Think about the world of racing. Its a multi billion industry with billions of test hours and counting. If something as simple as this worked, dont you think every team would be doing it? Sometimes you just have to use a little common sense.
    1995 Buick Regal GS(X) - Heavily modified. /modlist
  4. #4
    This is a common 20 some year old idea
    All alki burning sprint cars run 13.8 - 17 to 1 compression. some engine builder figured out that the high domed pistons were actually impeading the flame travel over the dome crown.
    We would hand machine every piston before installing them. The notch we did was actually larger than this as shown.
    quoted off that same thread
  5. #5
    Join Date
    May 2007
    Posts
    7,188
    Thanks
    605
    Quote Originally Posted by Garrett Powered View Post
    Last I checked, only the LQ1 pistons look anywhere close to having that deep of a valve recess. We also don't run as high of a compression. By notching the actual cylinder head, you
    A. permanently ruin a perfectly good cylinder head
    B. create hot spots that cause predetonation
    C. reduce compression
    D. risk hitting a water jacket
    E. risk weaking the walls near a water jacket
    In otherwords, don't do it. You're not running alcohol injection, nor do you have pistons that allow that high of a compression ratio.
    But, if you want to be the test dummy who chips or blows a hole through a piston due to predetonation, by all means go for it. I'll be the first to tell you I told you so.
  6. #6
    Community Manager White93z34's Avatar
    Join Date
    Jan 2004
    Location
    Pittsburgh, PA
    Posts
    9,646
    Thanks
    31
    It just seems like either a bad idea or a zero gains idea or a zero gains idea.
    -Chris D. - Your Community Manager
    "Insanity has no brand loyalty" - Got2b GM
    1992 Chevrolet Lumina Z34 3.4L TDC v6 Getrag 284
    1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
    1997 Pontiac Bonneville SSE Supercharged 3.8L v6, Hydramatic 4T60E
    1987 Chevrolet Camaro Z28/IROC-Z 5.0L v8, Hydramatic 700R4
  7. #7
    Its like this. I JUST saw that for the first time yesterday. I was not going to build a motor that way tomorrow or something.
    I wasn't aware of the predetonation issue with them yet but I also know that the fuel nowadays has alcohol which wasn't in it when TGP's were first made. back then they ran on gasoline and the engine was designed to run on gasoline. not ethanol.
    that was why I thought to post it up here for discussion.
  8. #8
    Mach 5's Avatar
    Join Date
    Jun 2006
    Location
    West Islip, NY
    Posts
    1,257
    Thanks
    2
    I have heard places doing this to the pistons if they have a high crown mainly to make sure the fire burns more evenly also puts less stress on the skirts. I learned this from s-k speed. I have done this mod on my r/c engines on the cylinder head but thats a 2 stroke
    Founder of the Radical Revs Racing Team- Radical Revs Modifications and Repairs
    Mach 5- 1989 Pontiac Grand Prix SE w/ Getrag 284, Plan is to build highest power twin turbo LG5 v6. stay tuned.. http://www.w-body.com/showthread.php...-60-degree-TGP
    Racer X- 1990 McLaren TGP- daily driver.. LG5, roller cam and GT3076R equiped http://www.w-body.com/showthread.php...w-build-dd-TGP!!
    Mach GOGOGO- AE86 track car- 4age 20v 1900lb [email]162hp@8200rpm
  9. #9
    Join Date
    May 2007
    Posts
    7,188
    Thanks
    605
    I don't think the amount of alcohol in the fuel will make a significant difference. Its the octane rating you're concerned with. Many people run water/alcohol injection to cool the charge and allow them to run more boost.
    I could be wrong, but so long as the fuel has the same octane rating regardless of how much ethanol is in it, it will still have the same tendancy to predetonate.
    Most people who do extensive port work will smooth their combustion chamber to remove any and all ridges or spikes to prevent predetonation as a result of hot spots. I did this when I ported the L27 heads, and the combination of porting and smoothing gained me massive power gains. I'm dying to pull the L67 heads to do the same thing again.
    Sent from my HTC Awesome using Tapatalk
  10. #10
    Euro's Avatar
    Join Date
    Jan 2004
    Location
    Streamwood, IL
    Posts
    12,933
    Thanks
    374
    Quote Originally Posted by AWeb80 View Post
    Jetta builds. Lol.
    -Matt
    2000 Regal GS - Stock is the bestest...stock is the fastest...
    2000 Grand Prix GT - Yeah sure, I miss you too
    1994 Lumina Euro - Miss you..
  11. #11
    AWeb80's Avatar
    Join Date
    Nov 2002
    Location
    Nebraska
    Posts
    9,191
    Thanks
    178
    hey, the power they are getting out of the little TDi motors is crazy
    I LOVE AWEB
  12. #12
    Join Date
    May 2007
    Posts
    7,188
    Thanks
    605
    Hence my anticipation of the Cruze diesel.
Nobody landed on this page from a search engine, yet!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
