Results 1 to 8 of 8
Thread: Question on wiring a 3.5mm jack into a Monsoon or any factory radio
  1. #1
    Been wanting to run a 3.5mm jack on my Monsoon radio to play my mp3 player. I've been reading up on how to do it and so far this is what I have gathered.
    So basically, all you really need to do is splice into the channel and ground wires on the tape deck to send the audio and keep a cassette in the deck to allow for switching and powering the tape deck, right? If so, which wire is which?? I haven't pulled the radio out yet so I haven't seen what to do.
    I have a Monsoon (as stated), so it has a source switch button and I won't need to put a toggle switch on to change from radio to the tape/aux correct??
    1999 Buick Regal GS
    *Gone but not forgotten*
    1992 Olds Cutlass Supreme
    NHRA Oldsmobile Spring Nationals
    Limited Edition
  2. #2
    Join Date
    Oct 2007
    Posts
    1,277
    Thanks
    142
    Google is your friend in this case. I have since added a aux input into a mid-to late 90's/ early 00's factory CD player, and a 2003+ RDS radio/ cd player (my brothers and my trucks, respectively.) So far I only know how to do these two types, and a Ford radio that I'm currently working on for my dads F250 Superduty.
    Here's some pics of my brothers radio and mine that I did. The only thing I would do different is to double check the placement, as on both, they are a little tight to the dash panel trim when everything is put back together. Everything works fine though. On the older radio in my brother's truck, the input is installed so that it interrupts the CD player audio when plugged in, but replaces the cd audio as soon as it is unplugged. A cd has to be playing for the mp3 player audio to play. On my radio, pretty much the same thing, except I can interrupt the XM signal, and simply have to press the band button until I change it to XM to get the signal. And no, you don't have to be subscribed to XM for it to work.
    Attached Images Attached Images
    Just here for the pizza
  3. #3
    Join Date
    Apr 2008
    Posts
    1,109
    Thanks
    6
    Got any write-ups for that or a link?
    <br />1998 Olds Intrigue | 1993 Bonneville SSEi SOLD!| 1996 Acura Integra GSR 4dr
  4. #4
    Yes, a write up would be great!
    Can't wait to try it out! What ga. wire did you use? And what plug did you use?
    1999 Buick Regal GS
    Limited Edition
  5. #5
    Join Date
    Oct 2007
    Posts
    1,277
    Thanks
    142
    I could do a write-up, though I got most of my info from the following links:
    Older radios:
    http://www.ls1tech.com/forums/stereo...t-adapter.html
    Newer, RDS radio:
    http://www.chevyavalanchefanclub.com...?topic=93646.0
    And this is the jack I used. Can be purchased at radio shack:
    http://www.radioshack.com/product/in...tId=2103451&cp
    And for the cable, I (under advice from the write-ups,) used cat5 cable.
    I might add my own little tips though. Firstly, I realized the first pic I posted is a copy right from LS1tech that I used for reference, but the radio I worked on is near identical. Secondly, I think I'm one of the only, if not the only person, to mount the jack in the faceplate. I did this for a factory look. Also, I hated the idea of drilling a hole for it somewhere randomly in the dash panel, or have a cable dangle out of the dash. I must warn you though, there is VERY limited space, if any (depending on your radio model) to mount it in the faceplate. You have to choose very carefully so as to have clearance around everything. With both, I had to cut small pieces out of the metal case of the radio, and trim some plastic out of the plastic on the inside of the faceplate. If you want to see how I did these two, I can post pics, otherwise I may do a full write-up. Feel free to ask me any questions, as both radios I have done work perfectly.
  6. #6
    Awesome! Must sticky this!
    Seems fairly simple to do. Think I will be doing this on Monday.
    1999 Buick Regal GS
    Limited Edition
  7. #7
    Join Date
    Oct 2007
    Posts
    1,277
    Thanks
    142
    I'll do a write-up if you all think it'd be worthy of a sticky. Then the pics will be my own and be more applicable and stuff.
  8. The Following User Says Thank You to carkhz316 For This Useful Post:
    99screaminregal (10-20-2011)
  9. #8
    If it saves us a few bucks to not go aftermarket then I'm a yes. I usually like the sound from stock units unless I'm doing some massive sound system.
    1999 Buick Regal GS
    Limited Edition
how to wire a 3.5 mm audio plug to a factory ford radio
3.5mm jack for monsoon 6
Powered by Article Dashboard 228 area code
wires 3.5 mm jack radio shack
buick regal 1999 monsoon aux input
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
