Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: Mysterious coolant leak 94 3.4L DOHC
  1. #16
    GEN1Z34's Avatar
    Join Date
    Oct 2011
    Posts
    85
    Thanks
    17
    I can't see why it would'nt.. I have used the Mity vac for brakes before..
    I think you'll be okay with that..
    Yup, mine leaked too.. A year and a half later I desided to dig into it..
    Just keep an eye on your coolant level till you deside to bust knuckles..
  2. #17
    Join Date
    Aug 2002
    Location
    Battlefield, MO
    Posts
    10,437
    Thanks
    53
    Your head gasket had an external coolant leak? It was the first thing I suspected when nothing up top appeared to be leaking because it happened to my 89 and usually what happens to one W-body often happens to others too!
  3. #18
    GEN1Z34's Avatar
    Join Date
    Oct 2011
    Posts
    85
    Thanks
    17
    Quote Originally Posted by GnatGoSplat View Post
    No, no, It turned out to be that stupid hard line that later crumbled..
    But it leaked for a while and I just kept an eye on my coolant level till I tore into it..
    I honestly have'nt seen LQ1's pop head gaskets tho I know it can happen of course.
    I have the old set from another LQ1 I am working on and they (aside from being used) are in excellent shape..
    I wont reuse them but, they came off looking very good for being nearly 20 years old and 130k+ on them..
    Basicly I am willing to go out on a limb here and say it's likely something other than a head gasket..
    There are so many coolant lines/connections running around under our hoods that I bet it's one of them or a heater core/line issue..
    Remember coolant is under pressure especially when you're driving, it can come from one place and squirt clear to another, pool up and drip later..
  4. #19
    Its likely your lower intake gasket, had that exact thing happen to me on a 92 lumina Z34
  5. #20
    Join Date
    Aug 2002
    Location
    Battlefield, MO
    Posts
    10,437
    Thanks
    53
    Yep, I think you guys who suspected the LIM are right. It's gotten worse, and now there is visibly green coolant pooling up in the valley along with the oil that was already there from the oil pump drive. I need to change it soon, because it's now leaking about a quart a week. I guess they only last about 9-years, the Fel-Pro replacement I put in it only lasted as long as the OEM did.
    Think it would be better to use RTV, or should I just install it dry as GM recommends? I don't remember what I did last time, probably installed it dry.
    Gotta think up some clever way to seal the oil pump drive leak again as well. Might as well do it with the LIM off of it.
coolant leak on a 3.4
Heater core 02 grand am 3.4
mysterious coolant leak
94 grand prix leaking antifreeze
3.4l dohc oil leak
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
