Page 7 of 10 FirstFirst ... 5 6 7 8 9 ... LastLast
Results 91 to 105 of 140
Thread: Nick's 1991 LQ1/284 5-Speed GTP
  1. #91
    AWeb80's Avatar
    Join Date
    Nov 2002
    Location
    Nebraska
    Posts
    9,191
    Thanks
    178
    Great job Nick!
    Quote Originally Posted by Crazy K
    I LOVE AWEB
    Quote Originally Posted by Woll Smoth
    I'm a sexy bitch, but I can't hold a candle to you
  2. #92
    19Cutlass94's Avatar
    Join Date
    Apr 2005
    Location
    Schenectady NY
    Posts
    9,490
    Thanks
    27
    Before you put the heads back on, put a small amount of oil on the cylinder walls. If there that clean you dont want piston ring on cylinder wall with no lube i.e. oil. itll smoke a tad at start up, but helps protect everything.
    Jay
    1994 Oldsmobile Cultass Supreme SL
    -Modded
    1995 Chevy K1500 350c.i. 5spd Z71
    -Modded
  3. #93
    I did spray down the cylinder walls and tops of the pistons with the combustion chamber cleaner, so they aren't dry, but I'll probably put some oil down each spark plug hole before I put in the spark plugs
    Thanks Adam!
    Also, as with every time I have a car sitting for a while, I pull the fuel pump fuse and crank the engine over a couple times until I have good oil pressure pumped up. Then I put in the fuel pump fuse and start it.
    2004 Pontiac Grand Prix Comp G- ZZP 3" downpipe with high flow cat, U-bend delete, high flow mufflers, K&N drop in... The DD
    2008 Ford Ranger XLT- 2.3 DOHC I-4 5-speed- Street truck project in progress...
  4. #94
    What is the procedure for the hydraulic tensioner for the timing belt? I remember something about it needing to be filled with oil.
  5. #95
    I don't remember ever having to fill one? Theres a screw to retract it, put a pin in to hold it, get the belt on, then remove the pin to release it.
    '92 5 speed GTP - Mod list _____ 95 Monte Carlo Z34 - DD _____ 91 GP Sedan - lent to GF as her DD
  6. #96
    Community Manager White93z34's Avatar
    Join Date
    Jan 2004
    Location
    Pittsburgh, PA
    Posts
    9,646
    Thanks
    31
    pop the rubber plug out the end of it, rewind it with a small flat head, stick a paperclip in through the hole on the side to lock it down, fill with synthetic oil, replace rubber cap, install.
    -Chris D. - Your Community Manager
    "Insanity has no brand loyalty" - Got2b GM
    1992 Chevrolet Lumina Z34 3.4L TDC v6 Getrag 284
    1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
    1997 Pontiac Bonneville SSE Supercharged 3.8L v6, Hydramatic 4T60E
    1987 Chevrolet Camaro Z28/IROC-Z 5.0L v8, Hydramatic 700R4
  7. The Following User Says Thank You to White93z34 For This Useful Post:
    Addicted To Boost (02-07-2012)
  8. #97
    That's it! Thanks Chris
  9. The Following User Says Thank You to Addicted To Boost For This Useful Post:
    Psych0matt (02-07-2012)
  10. #98
    Night Fury's Avatar
    Join Date
    Sep 2007
    Location
    St. Joseph MO
    Posts
    7,814
    Thanks
    1,223
    Today's FINISHIN DAY!!! EXCITING!
    -1991 Pontiac Grand Prix GTP 3.4 5-speed 174k, 'project'
    -1988 Pontiac Grand Prix SE 2.8 5-speed 256k, DD
    -2006 Chevrolet Monte Carlo LT 3500 211k, Kenny's DD
  11. #99
    It's all back together now and runs great, but still wants to run hot With the thermostat in, it takes about 45 seconds of running to get to 230*.
    I removed the thermostat and it took about 10 minutes to get to 230*. Cooling fans don't turn on when the gauge was reading that hot. If I jump the ALDL port with a paper clip, both fans will fire up and run at full blast. Heat was blowing good and hot inside the car and both bleeders were pushing out streams of coolant. Upper radiator hose didn't get very hot though and the radiator cap wasn't hot at all...
    So... What. In. The. Hell?!
  12. #100
    WTF?
  13. #101
    I dunno... I feel like the coolant isn't circulating. Water pump?
  14. #102
    worth a shot? Do you have a spare lying around? At least thats relatively easy...
  15. #103
    No I don't. It's pretty much the only thing I *haven't* replaced on this engine.
  16. #104
    well, if you wanna sell it... x2!
  17. #105
    Night Fury's Avatar
    Join Date
    Sep 2007
    Location
    St. Joseph MO
    Posts
    7,814
    Thanks
    1,223
    IT'S MINE, BACK OFF!!!
gm hydraulic timing belt tensioner 3.4 v6 dohc
nick 1991
1991 grand prix gt 5spd
Changing Alternator LQ1
1991 pontiac grand prix gtp
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
