Page 7 of 7 FirstFirst ... 5 6 7
Results 91 to 96 of 96
Thread: The Chronicles of the 94 Euro/Z - UPDATE 11-3!!
  1. #91
    Forum Moderator GOT2B GM's Avatar
    3D Quick Pool Champion!
    Join Date
    Aug 2004
    Location
    Kitchener, Ontario, Canada
    Posts
    10,750
    Thanks
    468
    verts = summertime win
    Matt Shantz
    '95 Oldsmobile Cutlass Supreme Vert LQ1
    '94 Oldsmobile Cutlass Supreme Vert LQ1
    '90 Pontiac Turbo Grand Prix #0058 of 2749
    '92 Pontiac Grand Prix GTP - 282
    '92 Chevrolet Lumina Z34 - 284
    '88 Pontiac Fiero GT - 282
    '01 Cadillac Seville STS - Corsa
    '01 GMC Yukon Denali - GM 22's
    Quote Originally Posted by Mach 5
    Car is machine, Matt is boss status trained precision task killer..
  2. #92
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Quote Originally Posted by GOT2B GM View Post
    True, of course if I ever get another one, I gotta make sure I haz good prescription sunglasses.
    Last summer I didn't enjoy it much with the sunlight causing bad migraines
    Meh, I just need to quit letting my mind wander, and keep going on my TGP
    -08 Kia Spectra SX -2.0L BetaII/Auto
    -07 Chevy Uplander LT -3.9L LZ9/4T65e
  3. The Following User Says Thank You to BXX For This Useful Post:
    Psych0matt (01-22-2012)
  4. #93
    Mach 5's Avatar
    Join Date
    Jun 2006
    Location
    West Islip, NY
    Posts
    1,257
    Thanks
    2
    you know whats scary??? those parts you bought if they were marked down that much I wonder how much it actually cost to manufacture..?
    Founder of the Radical Revs Racing Team- Radical Revs Modifications and Repairs
    Mach 5- 1989 Pontiac Grand Prix SE w/ Getrag 284, Plan is to build highest power twin turbo LG5 v6. stay tuned.. http://www.w-body.com/showthread.php...-60-degree-TGP
    Racer X- 1990 McLaren TGP- daily driver.. LG5, roller cam and GT3076R equiped http://www.w-body.com/showthread.php...w-build-dd-TGP!!
    Mach GOGOGO- AE86 track car- 4age 20v 1900lb [email]162hp@8200rpm
  5. #94
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Craaaaaaaaaaaaaaaaaaaaaaap!
    Well I knew this was coming, tried to ignore looking at everything engine related since I got the car. Quite nice today, so I decided to go check out the Euro under the hood. Ugh.
    Plug and wires = bad. Old and worn, but not the cause of all my issues. Only a small part at this point.
    ICM/Coils = 2 coils have slight arcing when when. ICM is causing somewhat weak spark once it heat soaks from me driving somewhere, shutting the car off. When I come back out and start the car once it sat for a few, the car runs like poop. Drive it around for a bit, it cools down and gets much better. No suprise here.
    IAC = Have had some stalling issues and even through a code. Its slow to respond and can keep up with the next issue...
    EGR = Likes to stick partially open after coming to a stop from cruise speed. It threw a code once too. Causing most of my occasional stalling issues and bad idle and of course, the idle speed code.
    Air Filter = Someone slapped a cone filter on some intake snorkle. Well its dirty and laying on the exhaust crossover.
    Injectors = I can see one injector is kinda damn from fuel seepage.
    TPS = Horray for a dead spot at .8-.9v and 1.1 to 1.3v. Low voltage is .64v, which is too high.
    MAP = This is the more lazy MAP sensor ever
    O2 sensor = Works when it wants to. I think this is a wiring issue or the sensor has seen better days/
    FPR = Havent tested, forgot my fuel pressure tester.
    See the trend here? Everything is just fricken old, yet somehow this car runs decent enough to drive to work and back without killing fuel mileage too much. The other week I saw 11mpg and aboot shit myself, then I remembed how much idle and warmup time it saw. After not letting the car warm up or idle long for the past week, i'm showing 16mpg, good enough for me with this engine.
    But it keeps getting better!!!!
    Radiator is shit, leaks. Gotta add aboot 1/4gallon coolant every 3-5 days. Leaks a bit more out on uber uber cold days. After flushing out the old crap, and refilling it, the amount of oil that keep getting into the system finally got me to notice. Im loosing a small amount of oil, its going in the cooling system. A quick look at the head sealing surfaces shows off a fair amount of coolant seepage. Yup, those are weak. LIM sealing surfaces show very minor oil, as expected for 150K.
    So yeah! Lets see how long this poor tired LH0 can go! No use doing a tune up, and replacing every sensor wouldn't be very cost effective giving the fact that the headgaskets are weak. Nothing coming out the tailpipe so I'm not concerned the slightest. I'll just keep the temp low and under control.
    So what happens next? Do I scrap it? Sell it? or trade it in? Fuck no! I like this awsome POS. Give her some TLC and some work, and it'll upgrade from POS status to fun and reliable daily driver.
    So it'll get an engine, prolly hold off until at least May. This LH0 should be able to do that no problem.
    Now I gotta figure out aboot the trans situation. Its a 91 4T60, so I can't go OBD2 with that so It looks like I may need a trans, Or get shit so I can tune OBD1 and keep this trans. It seems quite strong and shifts flawless, but who knows what lurks around the corner.
    So yeah, thats the update on this. Time to start getting something prepped and in order for this car.
  6. #95
    jman093's Avatar
    Join Date
    Dec 2007
    Location
    Wichita, KS
    Posts
    1,107
    Thanks
    11
    Why can't you go OBD-2 with that trans? I thought you had a tuner. There are plenty of OBD2 282/284 cars so I don't see why a 4T60 wouldn't work.
    Jesse M.
    2005 Chevrolet Corvette
    1987 Monte Carlo SS Aerocoupe.
    Former W's
    1996 GTP Special Edition.
    1993 Lumina Euro coupe.
  7. #96
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Quote Originally Posted by jman093 View Post
    I appears i can. Just some minor rewiring and pcm tuning aside from the TV cable hookup.
    Euro is now in the garage and deserves a good cleaning.
    Sent from my Transformer TF101 using Tapatalk
lx5 throttle body on 3x00
lx9 swap crank sensor
powered by vBulletin white trash jokes
lx5 throttle body bracket
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
