Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
Thread: Wonky sunroof!
  1. #1
    Wonky sunroof!
    Every summer I try to fix my crazy sunroof, and every summer it still does the same thing. It almost always opens UP. But when I try to close it, it takes three or more button presses for it to close. And when I try to get it to slide back, it has to drop down and close up twice before it will slide back - if it does at all, which is rarely.
    I've replaced the switch and I've replaced its little controller board. What else is there??
  2. #2
    Psych0matt's Avatar
    Join Date
    Jun 2004
    Location
    Flint, Mi
    Posts
    10,098
    Thanks
    1,080
    Mine will always slide back and then slide forward, but a lot of the time wont go into vent mode, but when it does will close just fine I grabbed a spare switch last weekend at the junkyard, I didn't know anything about a controller board...?
    '92 5 speed GTP - Mod list __ 95 Monte Carlo Z34 - DD ___ 91 GP SE - Parting out/scrapping
  3. #3
    Sounds like you've got the same problem in reverse, doubt that switch will fix it...
  4. #4
    Psych0matt's Avatar
    Join Date
    Jun 2004
    Location
    Flint, Mi
    Posts
    10,098
    Thanks
    1,080
    Quote Originally Posted by crazyd View Post
    I kinda figured that, which is why I haven't put it in yet. Maybe just a wire rubbed through or something
  5. #5
    urbex's Avatar
    Join Date
    Feb 2011
    Location
    Flint, MI
    Posts
    2,328
    Thanks
    563
    Although that switch you have in the car doesn't look too great anyways with how loose it is. It probably wouldn't be that bad to have a new one anyways.
    1983 Chevy C-10 Scottsdale Pickup (167k miles) Built 4/83 in Flint, MI, Received 1/05
    1999 Chevy Lumina (171k miles) Built 9/9/98, Purchased 8/14/06
    2006 HHR 1LT (56k miles) Built 5/24/06, Purchased 2/17/09 FOR SALE
  6. #6
    Nobody else has had this problem?
  7. #7
    tornado_735's Avatar
    Join Date
    Mar 2006
    Location
    Marengo, Ohio
    Posts
    2,257
    Thanks
    1,178
    I did on my old '94 sedan. I'm willing to bet money it's the sunroof relays.
    Go to the junkyard, and find a couple of GP's with a sunroof. Yank the headliner, and harvest the wiring with the little relays. That wiring harness with the relays has connectors on both ends IIRC. Get a couple of them, and install them on yours. I say get a couple of different ones because you could pull one with the same failed relays.
    ~Aaron
    1999 Buick Century Custom - 3100 V6 - 127k
    2001 Subaru Outback LL Bean - 3.0L Boxer-6 - 139k
    Quote Originally Posted by CrazyK
    I could do a better alignment on this car if i were Helen Keller with a tape measure...
  8. #8
    I did that already, but you're right I may have pulled one with the same failed relays. I'll see if I can find another one and try it again, maybe that's it.
  9. #9
    Psych0matt's Avatar
    Join Date
    Jun 2004
    Location
    Flint, Mi
    Posts
    10,098
    Thanks
    1,080
    Good to know, and that would make perfect sense too
  10. #10
    Scoured the junkyard today and found a couple Eldos with a sunroof, an Aurora, and a '98 GP with HUD, but I doubt any of them would've had compatible wiring. Even found a '95 with a manual sunroof, which must've been aftermarket.
    I think I've still got my old harness somewhere, is it repairable?
  11. #11
    iroc2's Avatar
    Join Date
    Jul 2010
    Location
    Lansing, IL
    Posts
    279
    Thanks
    46
    if anything ive had issues with it going back so its open. mostly when its like 50 degrees (early spring, i wanted my windows down after a 0 degree winter lol)
    -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    There are 1 1995 GRAND PRIX 2 DR vehicles (0.002%) matching your exact options list. There are 4 (0.007%) with at least as many options.
    Quote Originally Posted by virtuetovice View Post
    I had planned on keeping it till the wheels fell off
    ...then supergluing them back on and driving it until it rusts away.
  12. #12
    Bringing this one back, I've been checking the yards around here every time I go and have had a tough time finding the replacement relay box. I found a similar one in a Saturn, but it didn't work. If anyone comes across one let me know, it barely works now.
  13. #13
    Join Date
    Aug 2002
    Location
    Battlefield, MO
    Posts
    10,621
    Thanks
    94
    If relays are the problem, you could always open the relays and fix them. Most people don't think to open them, but usually they come apart using a small flathead screwdriver and are really easy to clean any oxidation or burnt spots off the contacts. I always repair relays rather than replace them.
  14. #14
    It's actually a little box with a circuit board inside. I've inspected it, repaired some cracked solder joints and it was WORSE than when I started!
  15. #15
    Join Date
    Aug 2002
    Location
    Battlefield, MO
    Posts
    10,621
    Thanks
    94
    You might also check the condition of the limit switches. I have a vague memory of my sunroof not working right due to crud in one of the limit switches. I cleaned it out with a pin and that fixed it.
w-body.com 98 lumina sunroof open
1994 grand prix sunroof cf5
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
