Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 68
Thread: Passkey I/VATS and Passkey II fuel enable signal generators
  1. #31
    urbex's Avatar
    Join Date
    Feb 2011
    Location
    Flint, MI
    Posts
    2,074
    Thanks
    400
    What happened to Saar? Hopefully on his internet hiatus he's making one of these for me!!!!
    1983 Chevy C-10 Scottsdale Pickup (166k miles) Built 4/83 in Flint, MI, Received 1/05
    1999 Chevy Lumina (163k miles) Built 9/9/98, Purchased 8/14/06 PAINT PEELING MOD!!!
    2006 HHR 1LT (53k miles) Built 5/24/06, Purchased 2/17/09
    Quote Originally Posted by virtuetovice View Post
    Sometimes when I'm home alone I lay in my closet and pretend I'm a carrot.
  2. #32
    RobertISaar's Avatar
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,398
    Thanks
    1,272
    Quote Originally Posted by urbex View Post
    learning unrelated stuff mostly, but grabbing library wifi when i can.
    at the very latest, i'll be putting in an order for all of the parts for at least the ones that have been spoken for by the end of next week(plus whatever parts i need to make the minimum order requirements).
    King of Code
    1995 Monte Carlo LS 3100, 4T60E... for now, future plans include driving it until the wheels fall off!
  3. #33
    Artemis's Avatar
    Join Date
    Apr 2008
    Location
    Toronto, ON
    Posts
    335
    Thanks
    42
    Assuming this will work with a 95/96 GTP and its fairly simple to install I'm in. I already have a vats bypass in place using the inline resistor... but sometimes it doesn't work and I sit there like a jackass for 10 minutes trying to turn over the car and then it suddenly works.
    Clayton H.
    1995 Pontiac Grand Prix GTP| OBD2 swap| 96 LQ1| Front Coilovers
    1987 Chevrolet Chevette Scooter | Automatic | Power brakes | Slow-mod
    1981 Chevrolet Camaro Berlinetta | Automatic | Stock
    ______________________________________________________________
  4. #34
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,398
    Thanks
    1,272
    sounds like your PK module itself is going out.
    i'll be dealing with these very soon, i promise this time.
    King of Code
  5. #35
    urbex's Avatar
    Join Date
    Feb 2011
    Location
    Flint, MI
    Posts
    2,074
    Thanks
    400
    O HAI!
  6. #36
    Artemis's Avatar
    Join Date
    Apr 2008
    Location
    Toronto, ON
    Posts
    335
    Thanks
    42
    Quote Originally Posted by RobertISaar View Post
    Where is the PK module located? Can I replace it fairly easily? I suppose it would have a different resistance if I replaced it...
    Clayton H.
  7. #37
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,398
    Thanks
    1,272
    Quote Originally Posted by Artemis View Post
    the passkey module in the 95MC is behind the glovebox. on a 95GTP, same relative location. not sure how much you'll need to remove to get to it, but i pulled the glovebox and was able to get to it. it's held in with a metal bracket, which i just bent the hell out of to get the module out since it wasn't going to be reused. the module itself is a little black plastic box.
    also, first update in far too long:
    i have 10 circuits built, will be testing soon(hopefully tomorrow), then since it's been so damn long, anyone who wants one: reply after the post with my test results.
    anticipated shipping costs: around $2.30 to pretty much anywhere in the continental US. not sure about international rates.
    King of Code
  8. #38
    passkey
    i can build these things stupid-cheap, so much so that i would need to buy parts for about 30 of them from my favorite supplier to meet their minimum order requirement of $5. and i know how much we all LOVE the PK2 systems.
    this would take care of the signal to the PCM part of the passkey module, the other half is the starter enable relay.
    you could either bypass it entirely by connecting two wires together or if you want to keep the relay for some reason, connect a single wire to ground. it's fairly simple to show on a diagram.
    i can probably make these for ~$10 USD + shipping and in an almost waterproof box and still turn a decent profit. i may even add a LED to indicate operation, though that would certainly remove the waterproof aspect.
    anyways, if even one or two people is interested, i'll go ahead and order the parts to make all 30 or so since i would likely cover my costs from that alone. all W-bodies would need is a 50Hz setup, though some of the earlier passkey setups in mid 80s vettes/f-bodies used a 30Hz setup, either can be made easily enough. it's certainly possible to make one module that can produce either signal as well, would just need a SPDT switch to switch between the resistor necessary to create the frequency you want.
    any interest? as you can see, i'm certainly not in this for the money.
    1. Urbex, 50Hz
    Hey, do you happen to have the schematics for the 30 and 50hz wave generator?, I would love to build one since my passkey box gave up, and also would love to get rid of all this security crap that makes my life a nightmare with my camaro everytime the fixed resistor goes bad. send me the schematics if you can, if not build me one of those devices that can generate either one with the flip off a switch. let me know I really need them.
  9. #39
    Join Date
    Feb 2012
    Posts
    12
    Thanks
    0
    Do you have a tdm bypass board already built for a 1995 monte carlo...my security light is flashing won't start tried spare key tried turn on/off 3 times 30 min..I can jump the starter with key on it will hit and die...i think it is in the vat sys...was gonna try to bypass completely whats the best option? Thanks..
  10. #40
    Join Date
    Feb 2012
    Posts
    12
    Thanks
    0
  11. #41
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,398
    Thanks
    1,272
    yeah, either your module or the wiring is FUBAR'd and is causing that.
    i'll throw the VATS option back on the MC today and get it tested, results in the next few hours.
    King of Code
  12. #42
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,398
    Thanks
    1,272
    got the modules tested today, buying a BUNCH of project boxes tomorrow.
    King of Code
  13. #43
    Join Date
    Feb 2012
    Posts
    12
    Thanks
    0
    did you happen to read my post in the general forums basically the 1995 monte carlo is running with the collar ingnition (orange cable unplugged..how is this happening? Thanks but still interested...in bypass module
  14. #44
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,398
    Thanks
    1,272
    the PK2 module will kick into fail-enable mode when you disconnect the connector after the engine is running. i skimmed your thread, but wasn't paying too close of attention.
    the module SHOULD stay in that mode indefinitely if you don't reconnect or hook in any other resistor, though if the module itself craps out or the theft deterrent relay dies, then you'll have problems again.
    King of Code
  15. #45
    Join Date
    Feb 2012
    Posts
    12
    Thanks
    0
    Thank you for your response....question...if i unhook battery will it still stay in that mode? but anyway the tdm bypass systems you are building are they hard to install is it plug and play...and what will be the cost i am interested in one Thanks..
vats passkey full bypass
diy vats passkey full bypass schematics
build your vats passkey full bypass
fuel enable signal
passkey signal generator
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
