Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
Thread: DOHC rear plugs, easy solution
  1. #16
    Join Date
    Mar 2009
    Location
    Pittsburgh Pa
    Posts
    31
    Thanks
    1
    and im guessing to get it back to its desired spot you just drive it forwards and line the dogbone back up?....I didnt know it was so easy! i hope it goes this easy in the morning LOL thanks guys!
  2. #17
    Forum Moderator GOT2B GM's Avatar
    3D Quick Pool Champion!
    Join Date
    Aug 2004
    Location
    Kitchener, Ontario, Canada
    Posts
    10,750
    Thanks
    468
    you should be able to rock it by hand once the weight of the car is off the park pin.
    Matt Shantz
    '95 Oldsmobile Cutlass Supreme Vert LQ1
    '94 Oldsmobile Cutlass Supreme Vert LQ1
    '90 Pontiac Turbo Grand Prix #0058 of 2749
    '92 Pontiac Grand Prix GTP - 282
    '92 Chevrolet Lumina Z34 - 284
    '88 Pontiac Fiero GT - 282
    '01 Cadillac Seville STS - Corsa
    '01 GMC Yukon Denali - GM 22's
    Quote Originally Posted by Mach 5
    Car is machine, Matt is boss status trained precision task killer..
  3. #18
    Join Date
    Feb 2010
    Location
    burlington, ontario
    Posts
    113
    Thanks
    16
    Quote Originally Posted by Psych0matt View Post
    So after some fidgeting around I finally found the perfect combo to get the rear plugs out. This can be done without removing anythings, without rocking the engine, without cutting the firewall lip. I did all three of my rear plugs in under 15 minutes, and the hardest part was just getting the wires back in because of the goofy plastic tubey thingy that they go in.
    Here's what you'll need:
    1/2" socket wrench
    1/2" 5" extension
    1/2" to 3/8" socket adaptor
    3/8" universal joint
    3/8" 3" extension
    3/8" extension connected to your spark plug socket
    Here's what you do:
    First remove the plug wire. You may have to use a little bit of force and some twisting and wiggling, but it can be done. With the socket and first extension already connected, lower it into the plug hole enough so that you can still hold it with one hand (and not drop it in). Once you have it down far enough for the second 3" extension to be down past the lip, pop it on to the first extension. Drop it a little further so you can get the U joint on. At this point you should be able to get the socket most of the way down onto the plug. You should be able to now pop the adaptor on, and then the 5" extension. Once you do this, it's pretty self explanatory. You'll have to loosen the plug and then reverse the process (removing each section), but then you should have your plug out, and installation of the new plug is reverse. Again, took me all of 15 minutes to do all three, and half that time was probably fighting to get the wires back on
    thanks matt,
    that is going to save me some time and cut knuckles. hat's off to you.
    cheers,
    gryfan
  4. #19
    Join Date
    Mar 2009
    Location
    Pittsburgh Pa
    Posts
    31
    Thanks
    1
    I connected a strap to the engine after i parked it on the ramps and loosened the dogbone, connected the strap to my jeep and pulled it did the trick...Got the wires in with no problems, it started up and ran real well untill i got on the highway, it started to spit n puke, I wonder if the bit of water down in the thing would cause that
  5. #20
    Join Date
    Aug 2004
    Location
    Posts
    10,750
    Thanks
    468
    Plugs gapped properly?
    Matt Shantz
  6. #21
    Join Date
    Mar 2009
    Location
    Pittsburgh Pa
    Posts
    31
    Thanks
    1
    Yup...theres white smoke coming from the pipes when i first start it it eventually goes away, driving it around though it runs rough and smells of exaust at times...Im afraid to drive it!...Looks like it will be going back to the shop just again, looks like this summer i wont be enjoying it if this keeps up
  7. #22
    not to sound rude, but shouldn't the exhaust smell like exhaust? I would check your plug gaps again, and did you put new wires on? If not, maybe you busted a wire taking them off/putting them on? Maybe they're not connected all the way?
    '92 5 speed GTP - Mod list _____ 95 Monte Carlo Z34 - DD _____ 91 GP Sedan - lent to GF as her DD
  8. #23
    Join Date
    Mar 2009
    Location
    Pittsburgh Pa
    Posts
    31
    Thanks
    1
    lol it smells real rich smelling and does it for a very long time, More than normal...Will def check the other stuff again, Thanks for the advise
  9. #24
    Join Date
    Mar 2009
    Location
    Pittsburgh Pa
    Posts
    31
    Thanks
    1
    Changed the plugs again, It ran great for 2 days now its back to running rough n crap...The check engine light is still on , But every place i take it too says they cant check the checkengine light because the car is too old
  10. #25
    Community Manager White93z34's Avatar
    Join Date
    Jan 2004
    Location
    Pittsburgh, PA
    Posts
    9,646
    Thanks
    31
    I have a scanner that should be able to read your car no problem. PM me, I'm local.
    -Chris D. - Your Community Manager
    "Insanity has no brand loyalty" - Got2b GM
    1992 Chevrolet Lumina Z34 3.4L TDC v6 Getrag 284
    1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
    1997 Pontiac Bonneville SSE Supercharged 3.8L v6, Hydramatic 4T60E
    1987 Chevrolet Camaro Z28/IROC-Z 5.0L v8, Hydramatic 700R4
  11. #26
    Join Date
    Mar 2009
    Location
    Pittsburgh Pa
    Posts
    31
    Thanks
    1
    Happy to announce that it was my EGR valve, And a few sensors, Nothing major, My cutlass is back to running normal, Well as normal as a 3.4L can get ( im still not used to this engine, i am more fond of the 3800 series2 that was in both of the lumina LTZs i owned).....Are there any meetings planned anytime soon it would be nice to meet up with other gearheads, Even if you dont gota cutty convertible
  12. #27
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,140
    Thanks
    15
    Check out the events section... On the 21st there is a mod weekend in Lorain OH, thats about 2 hours for you I think... And June 10th is Wbody Nationals in Dayton and if theres any event that you need to come to, its that one
    98 Regal GS - 260k, Aquamans sloppy seconds, for sale
    99 Silverado Z71 - 196k, BGA express
    04 Ford Focus ZTS 2.3L/5 speed - 176k, also for sale
    Quote Originally Posted by BXX View Post
    Al is a big sexy stud
    Quote Originally Posted by 95GPSE View Post
    But the Grand Prix is a Grand Prix, which automatically trumps all.
dohc rear spark plugs
how to reach rear spark plugs on a fiero
how to change spark plugs on a 1992 oldsmobile cutlass 3.4 litre dohc
3.4 dohc white smoke coming from the back
Need spark plug boot for 01 so seville sts
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
