Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Thread: DOHC rear plugs, easy solution
  1. #1
    So after some fidgeting around I finally found the perfect combo to get the rear plugs out. This can be done without removing anythings, without rocking the engine, without cutting the firewall lip. I did all three of my rear plugs in under 15 minutes, and the hardest part was just getting the wires back in because of the goofy plastic tubey thingy that they go in.
    Here's what you'll need:
    1/2" socket wrench
    1/2" 5" extension
    1/2" to 3/8" socket adaptor
    3/8" universal joint
    3/8" 3" extension
    3/8" extension connected to your spark plug socket
    Here's what you do:
    First remove the plug wire. You may have to use a little bit of force and some twisting and wiggling, but it can be done. With the socket and first extension already connected, lower it into the plug hole enough so that you can still hold it with one hand (and not drop it in). Once you have it down far enough for the second 3" extension to be down past the lip, pop it on to the first extension. Drop it a little further so you can get the U joint on. At this point you should be able to get the socket most of the way down onto the plug. You should be able to now pop the adaptor on, and then the 5" extension. Once you do this, it's pretty self explanatory. You'll have to loosen the plug and then reverse the process (removing each section), but then you should have your plug out, and installation of the new plug is reverse. Again, took me all of 15 minutes to do all three, and half that time was probably fighting to get the wires back on
    '92 5 speed GTP - Mod list _____ 95 Monte Carlo Z34 - DD _____ 91 GP Sedan - lent to GF as her DD
  2. The Following User Says Thank You to Psych0matt For This Useful Post:
    94 olds vert (02-15-2011)
  3. #2
    94 olds vert's Avatar
    Join Date
    Sep 2009
    Location
    Eastpointe, Michigan
    Posts
    5,723
    Thanks
    420
    Good idea, if you don't want to rock the engine. I just removed my dog bone and rocked the engine, didn't take me that long either.
    Nate
    1994 Cutlass Supreme Convertible
    1991 Grand Prix GT
  4. #3
    Forum Moderator GOT2B GM's Avatar
    3D Quick Pool Champion!
    Join Date
    Aug 2004
    Location
    Kitchener, Ontario, Canada
    Posts
    10,750
    Thanks
    468
    Or, disconnect the dogbone, and back the car up onto ramps, shut it off, and put it in park or 1st gear allowing the weight of the car to roll the engine forward.
    Then you don't need a universal joint and the spark plug boots are much easier to get in.
    Also taping your socket / extensions together is a good idea so your socket doesn't fall off the extension when down there.
    Matt Shantz
    '95 Oldsmobile Cutlass Supreme Vert LQ1
    '94 Oldsmobile Cutlass Supreme Vert LQ1
    '90 Pontiac Turbo Grand Prix #0058 of 2749
    '92 Pontiac Grand Prix GTP - 282
    '92 Chevrolet Lumina Z34 - 284
    '88 Pontiac Fiero GT - 282
    '01 Cadillac Seville STS - Corsa
    '01 GMC Yukon Denali - GM 22's
    Quote Originally Posted by Mach 5
    Car is machine, Matt is boss status trained precision task killer..
  5. The Following User Says Thank You to GOT2B GM For This Useful Post:
    Brian P (02-18-2011)
  6. #4
    I know, I know, there are other methods! For me this is by far the easiest. I don't want to to use ramps to do spark plugs though, or disconnect the dogbone if I don't have to. I kinda did this writeup just so in a year or whenever I do this again, I don't have to do any of that, and I don't have to scratch my head trying to remember! Just seemed like a good alternative for someone who doesn't like taking crap apart to do something that shouldn't require taking crap apart
  7. #5
    Join Date
    Dec 2004
    Posts
    2,359
    Thanks
    3
    Quote Originally Posted by Psych0matt View Post
    You've pretty much nailed it. This is how I did my LQ1 plugs, and there's really nothing to it.
    1994 Pontiac Grand Prix SE sedan
  8. #6
    ON my LQ1, I have never had any real problems getting the back plugs out. tight squeeze yes but seems just enough room that with the right extensions you can get to them. Sometimes I rock the engine but even that is not really necessary. Is my 94 GTP set up in some fashion that is not usual?
    For rocking it, I just rock the car and apply the park brake when it is forward.
    1994 Pontiac Grand Prix GTP. 3.4 DOHC with 197,000 miles, 4 speed automatic.
  9. #7
    Join Date
    Oct 2007
    Posts
    1,277
    Thanks
    142
    Cut the half-circle slices out of the weatherstrip flange on the front of the cowl. Works like a charm and can be covered back up with the weatherstripping. Tis what I did on my '92 when I had it at school. I then did my engine-bay jamming/ painting, and it looks like they're supposed to be cut like that. No U-joints or adapters required as it's a straight shot at the plugs then. Just my .02
    Just here for the pizza
  10. #8
    Yeah, all good options, not arguing that, but again my main issue was the concept of why should you have to modify something that you should be able to do without modifying? Just my opinion on what's best/easiest for me
  11. #9
    1. Remove dash
    2. Put 3 holes in firewall
    3. Remove plugs
    4. Install new plugs
    5. ?????????????
    6. PROFIT
    this IS a General Motors product and the general rule is that nothing should make actual sense.
    Quote Originally Posted by pwmin View Post
    who knew a pansy-ass 2.8L V6 would sound so glorious
    This message was sent from my 2012 Cadillac CTS
  12. The Following User Says Thank You to virtuetovice For This Useful Post:
    Psych0matt (02-27-2011)
  13. #10
    Join Date
    Sep 2009
    Location
    Posts
    5,723
    Thanks
    420
    5. ????????????? = Install DIS and UB3.
    Nate
    1991 Grand Prix GT
  14. The Following User Says Thank You to 94 olds vert For This Useful Post:
    virtuetovice (02-27-2011)
  15. #11
    Thas' how I did mine. Just took the weather stripping off and went to town on it.
    1999 Buick Regal GS
    *Gone but not forgotten*
    1992 Olds Cutlass Supreme
    NHRA Oldsmobile Spring Nationals
    Limited Edition
  16. #12
    Yes very easy using the right socket extensions and swivel, designers should really have some knowledge in mechanics so they can design cars better. Something as easy as changing spark plugs should not be so difficult IMO
  17. #13
    Join Date
    Mar 2009
    Location
    Pittsburgh Pa
    Posts
    31
    Thanks
    1
    im having a hell of a time with the rear plug wires on my cutty...i got her back today and changed them but now it runs and spits n pukes, Iam thinking i didnt get the plug wires all the way down on the plug....So basically you disconnect the dog bone and it will rock forwards? Iam afraid of doing that but is it just that simple ( im no where near a mechanic is why i ask) i just like trying things first before i pay someone to do it
  18. #14
    Join Date
    Aug 2004
    Location
    Posts
    10,750
    Thanks
    468
    Unbolt the dogbone and you can pull it forward, try a ratchet strap, or park it facing downhill so the weight of the car pushes on the parking pin in the trans and rocks it forward. You won't hurt the car.
    Matt Shantz
  19. #15
    i once connected a strap to my brothers jeep and then threw the jeep into neutral and let the weight pull the engine a bit. Worked like a charm
dohc rear spark plugs
how to reach rear spark plugs on a fiero
how to change spark plugs on a 1992 oldsmobile cutlass 3.4 litre dohc
3.4 dohc white smoke coming from the back
Need spark plug boot for 01 so seville sts
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
