Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
  1. #1
    What is this witchcraft? WhatTheFehl's Avatar
    Join Date
    Jan 2010
    Location
    Kennedy Township, PA
    Posts
    2,319
    Thanks
    487
    Torque Converter Intermittent Lockup Problems
    Just as the title says. I'm sure the question has been asked before, but I couldn't find anything through the search feature. The issue is that sometimes the torque converter in my car locks up perfectly and functions just fine, then other times it doesn't lock up at all. Pulling up on the brake pedal doesn't have any effect. The transmission shifts perfectly otherwise. What could be the issue here? A failed sensor somewhere? I'm not sure.
    It's a 1995 Grand Prix 4T60E
    Mike F
    2004 Subaru Outback Wagon - 123,000 miles, 2.5 H4 EJ251, 4EAT, DD
    1999 Pontiac Grand Prix GTP - 191,000 miles, L26/L67 hybrid, lowered, Comp-G wheels, SD headers, FWI, Toy/Money Pit
    Love: it's what makes a Subaru, a Subaru
    Confidence in Motion
  2. #2
    Join Date
    Apr 2003
    Location
    Cincinnati, OH
    Posts
    17,684
    Thanks
    1,194
    Whats the engine temperature when it does and does not?
    Chris D.-
    '02 Buick Century- Wife's
    2012 Jeep Grand Cherokee- Company Car/DD
  3. #3
    Join Date
    Jan 2010
    Location
    Posts
    2,319
    Thanks
    487
    I've never noticed any sort of pattern with engine temperature or anything to be completely honest.
    Mike F
  4. #4
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,860
    Thanks
    20
    When I drove this car it was after we had been driving around for a good portion of the night and it was at operating temp and it still wouldn't lock up on the highway
  5. #5
    Join Date
    Jan 2010
    Location
    Posts
    2,319
    Thanks
    487
    Quote Originally Posted by AL View Post
    Yes, but Friday night driving home from work it locked up perfectly on the highway the whole way.
    Mike F
  6. #6
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,860
    Thanks
    20
    I was just answering slicks question
  7. #7
    Join Date
    Jan 2010
    Location
    Posts
    2,319
    Thanks
    487
    I know, but I was reinforcing the randomness of the situation
    Mike F
  8. #8
    Galaxie500XL's Avatar
    Join Date
    Aug 2009
    Location
    Knoxville, Tennessee
    Posts
    1,209
    Thanks
    430
    My '95 LQ1 Cutlass does the same thing once the trans temp rises above 180 degrees. Seems to be a common problem with the 4T60E, I believe it's related to either the PWM solenoid, or the TCC clutch solenoid, which are inside the transmission. A poster a few months ago reported success with cutting the lead at the transmission wires for the PWM solenoid, but myself, I'm planning a rebuild for the transmission before warm weather arrives.
    1995 Cutlass DOHC Convertible
    3rd Quarter 2012 COTQ
    232,000 miles, and counting.
    Got 3 kids----it IS their father's Oldsmobile...
  9. #9
    Lurker Brian P's Avatar
    Join Date
    Aug 2002
    Posts
    13,126
    Thanks
    136
    The PWM solenoid should not be confused with the TCC apply/release solenoid. The PWM in simplest terms acts as a fluid pressure (or flow) regulator to the torque converter clutch to soften the application of the TCC. The PWM solenoid has a very high failure rate during its early years of introduction in the W-line (1994-1997 or so). They tend to act up and cause slipping or lack of clutch activity when the transmission has been warm for a period of driving and eventually will fail altogether.
    The PCM controls the ground circuit to this solenoid via "pulsations". You could try cutting the control wire, or if you want to be neat about it, pull the terminal out of the plug. This wire is located in pinout "C" of the transmission harness connector just above the vacuum modulator (under the airbox, front of tranny). The wire is "dark brown".
    It's worth a shot if nothing else. With the PWM solenoid out of the equation, the application of the torque converter clutch will be abrupt but it should be consistent.
    Yeah, it's still on the road. 5/21/12 210,800+
  10. #10
    Join Date
    Aug 2009
    Location
    Posts
    1,209
    Thanks
    430
    True, but a bad PWM solenoid can lead to the symptom. The PCM monitors "slip" from the torque converter. If the PWM is too slow in allowing full hydraulic pressure for lockup (I think 3-5 seconds), the PCM will detect the excess slip, and disable further lockup attempts until the next start cycle.
  11. #11
    Join Date
    Jan 2010
    Location
    Posts
    2,319
    Thanks
    487
    PWM = Pulse Width Modulation Solenoid? (ACDELCO Part # 2141861 on RockAuto)
    I'm assuming that even though it is a fairly cheap part ($40), it is such a pain in the ass to replace that unless I'm planning a transmission rebuild it isn't worth the trouble?
    Mike F
  12. #12
    Join Date
    Aug 2009
    Location
    Posts
    1,209
    Thanks
    430
    Well, starting in '95, the side cover was redesigned to allow a transmission mount to be attached...which means there's lots of fun to be had.
    I figured my Cutlass has 207,000 miles on it, and the torque converter sounds like a coffee can full of rocks on takeoff, so I'm just going to rebuild the transmission.
  13. #13
    Join Date
    Jan 2010
    Location
    Posts
    2,319
    Thanks
    487
    With any luck this engine/transmission combination won't be in there a whole lot longer (really want a 3500 and haven't decided on transmission), though I'm not sure how much longer it will be before the car will be promoted from DD to project. In the meantime, I sure wish I could have the few MPGs that I'm losing because of this back.
    Mike F
  14. #14
    FOLLOW WOOL SMITHS ADVICE.
    The difference you feel or see of having or not having a working PWM is minimal. SIMPLE. EASY. STRAIGHT FORWARD. DO ET!!! I've done this on three transmissions and never looked back.
    you may also benefit from an auxiliary(external) transmission cooler... though saying that will bring someone like Bob out of the woodwork to argue.......
    BUILDER AND DESTROYER OF FINE(?) AMERICAN CARS.
  15. #15
    Join Date
    Aug 2009
    Location
    Posts
    1,209
    Thanks
    430
    X2 on the cooler...I added one from a 3.8 Regal to my '95 LQ1, the cost was minimal, and keeps the transmission temp down long enough for me to make my usual commute back and forth to work each day without encountering the lockup issue. On long trips, though, especially in summer, 30 miles is about as far as I can drive before the PCM disables the TCC.
torque converter lockup problems
torque converter lock up problems
buick lesabre torque converter problems
grand prix torque converter problems
lock up torque converter problems
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
