The top pump seams weak is it will not lower the top all the way down. It will not raise the top up, once the top is helped up the first foot the pump raises the top just fine. This was with the engine running.
The pump resivoir is full and I asume you check it with the top up?
Is a pump rebuild kit available or just a pump/motor assy?
Would it help enough to lubricate the pivot pionts on the top?
The outside Temp. was about 60 deg. F.
Any ideas? Thanks.
