Results 1 to 5 of 5
Thread: cooling fans
  1. #1
    Join Date
    May 2008
    Posts
    174
    Thanks
    0
    cooling fans
    does anybody know the best way to put in A toggle switch to run your cooling fans i remember reading somewhere how to do it using the relay port if some one can explain it would be greatly appreciated
  2. #2
    What is this witchcraft? WhatTheFehl's Avatar
    Join Date
    Jan 2010
    Location
    Kennedy Township, PA
    Posts
    2,327
    Thanks
    489
    First of all... does your state have emissions testing? Because if you do a manual override for your cooling fans it WILL NOT pass emissions...
    Mike F
    2004 Subaru Outback Wagon - 123,000 miles, 2.5 H4 EJ251, 4EAT, DD
    1999 Pontiac Grand Prix GTP - 191,000 miles, L26/L67 hybrid, lowered, Comp-G wheels, SD headers, FWI, Toy/Money Pit
    Love: it's what makes a Subaru, a Subaru
    Confidence in Motion
  3. #3
    gpchris's Avatar
    Join Date
    Mar 2005
    Posts
    1,134
    Thanks
    3
    Quote Originally Posted by 95GPSE View Post
    Explain???
    heres the diagram
    -GREEN 1995 Pontiac Grand Prix SE - ???/???
    -White 1995 Pontiac Grand Prix GTP - LQ1/F40 6SPD MTX
    -Green 1996 Pontiac Grand Prix SE - L82/282 5SPD MTX
  4. #4
    Join Date
    Jan 2010
    Location
    Posts
    2,327
    Thanks
    489
    If you leave the switch on, the fans will run constantly and the vehicle most likely will never get up to operating temperature for the emissions testing. That is a fail right there. If you leave the switch off, the fans won't run, causing your car to overheat. Either way it will fail emissions. At least that's the way I understand it. The inspection mechanic isn't going to sit there and flip cooling fan switches for you.
    Mike F
  5. #5
    gpchris's Avatar
    Join Date
    Mar 2005
    Posts
    1,134
    Thanks
    3
    Actually you have it wrong. The fans operate normally when the switch is off. The switch just allows you to override the pcm and turn the fans on at any temperature.
95 pontiac grand prix fan relay position
2005 pontiac grand prix wiring diagram
1995 PONTIAC GRAND PRIX GTP PCM
1996 pontiac grand prix cooling fan wiring diagram
wire diagram for cooling fan relay 1997 pontiac grand prix se 3100 v6
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
