Results 1 to 6 of 6
Thread: Drivetrain - 4T60
  1. #1
    RobertISaar's Avatar
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,391
    Thanks
    1,269
    Drivetrain - 4T60
    1988 W 2.8
    3.33FDR
    2095RPM stall
    1989-1990 W 2.8/3.1
    3.33FDR
    2060RPM stall
    1989-1990 TGP
    3.33FDR
    1895RPM stall
    King of Code
    1995 Monte Carlo LS 3100, 4T60E... for now, future plans include driving it until the wheels fall off!
  2. The Following User Says Thank You to RobertISaar For This Useful Post:
    jake91 (09-02-2010)
  3. #2
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,391
    Thanks
    1,269
    Re: Drivetrain - 4T60
    the 4t60 uses both a TV cable and a vacuum modulator: the TV cable determines shift points and the vacuum modulator determines the shift feel. an adjustable modulator meant for a TH-350 will work perfectly here. the TV cable is adjustable as well, though working in large steps is a bad idea.
    to reset the cable to it's intended position, there is a bracket bolted to the back of the motor. in the center of the bracket, there is a plastic piece with a flat, square tab that sits flush with the side that points upward. it's got enough pressure to it to require me to use a screwdriver to depress it far enough to allow reseting the cable. when it's depressed, you will have to push the little "cone" surrounding the cable inwards to allow the cable to reset. when it is pushed far enough in, get in the car and slowly push the throttle to the floor. once you get most of the way down, you should feel more resistance and then you will hear a ratcheting noise. that noise is the TV cable reseting.
    when the throttle is all the way down, release it and go back under the hood and look at the cable, it should have more tension on it now than it did. if not, the cable didn't need adjustment.
    if the shift points feel too late, you can make a shim and then reset the cable, then before applying the throttle, inset the shim where indicated, then apply full throttle. if you can't/don't want to make a shim, you WILL need a second person or very manueverable hands. you will have to reset the cable, have the second person step on the throttle, then pull on the TV cable while still at WOT until you feel/hear clicks. move 1 or 2 at a time. keep in mind you will need to reset the cable every time you want to adjust it due to the mechanism not allowing adjustment unless it's during the first WOT sequence.
    King of Code
  4. The Following User Says Thank You to RobertISaar For This Useful Post:
    jake91 (09-02-2010)
  5. #3
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,391
    Thanks
    1,269
    not going to edit since this post deserves it's own: REMOVE THE SHIM WHEN FINISHED! YOU DON'T WANT THAT SHIT POSSIBLY BOUNCING AROUND AND THEN GETTING STUCK SOMEWHERE YOU DON'T WANT, LIKE KEEPING THE THROTTLE HELD OPEN!
    King of Code
  6. The Following User Says Thank You to RobertISaar For This Useful Post:
    jake91 (09-02-2010)
  7. #4
    Join Date
    May 2007
    Posts
    7,186
    Thanks
    605
    Does anyone know the final drive ratios of other engines that were bolted to this trans?
    1995 Buick Regal GS(X) - Heavily modified. /modlist
  8. #5
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,391
    Thanks
    1,269
    Quote Originally Posted by xtremerevolution
    i have everything from 85-90, but after that, i would need RPOs...
    EDIT: i could check compnine, but i would need a list of what engine and year the car would need to be to have it...
    King of Code
  9. The Following User Says Thank You to RobertISaar For This Useful Post:
    jake91 (09-02-2010)
  10. #6
    Join Date
    Sep 2006
    Location
    Camden, MI
    Posts
    6,391
    Thanks
    1,269
    just checked it:
    91-92 regal 3.1 was 3.33
    91-92 regal 3.8 was 3.06
    after 92, it was 4t60-e...
    anything else? i'm confident all 3.1s got the same gears and nothing else got the 3.8 until Gen2...
    King of Code
  11. The Following User Says Thank You to RobertISaar For This Useful Post:
    jake91 (09-02-2010)
4t60 tv cable
4t60 vacuum modulator
vacuum modulator 4t60 location4t60 tv cable adjustment4t60e vacuum modulator location
Posting Permissions
  • You may not post replies
  • You may not edit your posts
