Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 92
  1. #16
    Re: Tubular Front Control Arms- 1st gen
    These are actually 17% lighter. Probably more so, because I weighed the factory ones without bushings. So probably closer to 20%. Not sure how much you are looking to save, not to be a dick but maybe you should make your own. Not trying to be rude at all here.
    I will shoot some pics of the heim joints up later on. Might be able to get it PC as well.
    Mark-OEM
  2. #17
    Join Date
    May 2007
    Posts
    7,232
    Thanks
    601
    Quote Originally Posted by dohc v6
    What will these do? These will be lighter, stronger and a solid steel arm with no rubber.
    That's what had me confused Mark. That and the mere 1.1lb difference between them. I imagine the bushings will make some difference. Thanks for clarifying that.
  3. #18
    You thought that I mean solid bar? Oh yeah that would not be 1lb lighter lol. Yes these are 1" tubing with 1/8 or 3/16 wall I cant remember.
  4. #19
    Join Date
    May 2007
    Posts
    7,232
    Thanks
    601
    Sorry I doubted you, haha.
    These look good. I'm assuming that plate in the middle will be used for mounting the sway bar?
  5. #20
    Yes, also stiffens the arm up quite a bit.
    Mark
  6. #21
    Sorry if I missed it, but do you know the final price for these? I'd likely be down for a set, it would save me from making my own.
    Glad to see you made tubular ones Mark, sorry about the hard time i gave you in the other thread.
    Jamie
    Can't Stand Idiots_MuNkY
    1991 OLDSMOBILE CUTLASS SUPREME INTERNATIONAL - 3.4L DOHC
    1999 GMC JIMMY SLE - 4.3L, 4x4
  7. #22
    Forum Moderator GOT2B GM's Avatar
    Join Date
    Aug 2004
    Location
    Woodstock, Ontario, Canada
    Posts
    11,634
    Thanks
    591
    *Andrei inserts foot in mouth*
    Matt Shantz
    '95 Oldsmobile Cutlass Supreme Vert LQ1
    '94 Oldsmobile Cutlass Supreme Vert LQ1
    '90 Pontiac Turbo Grand Prix #0058 of 2749
    '92 Pontiac Grand Prix GTP - BAM -282
    '92 Chevrolet Lumina Z34 - 284
    '88 Pontiac Fiero GT - 282
    '01 Cadillac Seville STS - Corsa
    '01 GMC Yukon Denali - GM 22's
    '92 Subaru SVX -101k mi FOR SALE $2000
    Quote Originally Posted by Mach 5
    Car is machine, Matt is boss status trained precision task killer..
  8. #23
    Its cool Jamie. I totally understand. Price is $350 Powdercoated. I will shoot some final pics tonight. Then we can start with orders.
    Mark
  9. #24
    I will likely order a set somewhere towards the end of Feb, I gotta get some money saved up because I want to order the Camber plates too.
    Jamie
  10. #25
    Sounds good.
    Mark-OEM
  11. #26
    Join Date
    Apr 2003
    Location
    Cincinnati, OH
    Posts
    17,684
    Thanks
    1,194
    Hmm.... the camber plates would go nicely with the control arms.
    Mark, you should make a package deal!
    Not that I own a W thats worth putting it on, but a suggestion!
    Chris D.-
    '02 Buick Century- Wife's
    2012 Jeep Grand Cherokee- Company Car/DD
  12. #27
    Quote Originally Posted by slick
    I AGREE! LoL There is a chance I will talk Matt into buying at the same time as me too!
    What color powder coat are these going to have?
    Jamie
  13. #28
    Black. I always do Black lol. We can work a deal I am sure.
    Mark
  14. #29
    Join Date
    Aug 2004
    Location
    Posts
    11,634
    Thanks
    591
    Quote Originally Posted by Bob's Yer Uncle!
    Quote Originally Posted by Garrett Powered
    PLease put your name down if truly interested.
    1. Garrett Powered
    2. Bob
    3. GOT2B GM
    4.
    5.
    One suggestion that I would like to make, would be some reinforcement welded on the underside of the plate (flatbar welded perpendicular to the plate on the bottom) to keep the plate from flexing under load of the swaybar.
    Other than that, looks great!! I'm in.
    Matt Shantz
  15. #30
    Join Date
    May 2007
    Posts
    7,232
    Thanks
    601
    How much not powdercoated?
lowered gmc acadia
measuring tube control arms
1990 ford ranger front rubber bushings
ford ranger lowering control arms
iroc z tublar control arm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
