Hello there all,
I just thought I’d share some of my “useless knowledge” that you might want to consider when changing or upgrading your Delco Audio System in your W-body vehicle. First of all, the basics: From the 80s on up, GM/Delco/Delphi Audio System wiring has hardly changed, especially for the speakers. Each speaker is wired with it’s own positive and negative like a traditional home stereo system. This is an important fact to keep in mind when installing a new head-unit, amp, subwoofer, or crossover.
Secondly, almost 80% of all Delco/Delphi head-units from the 90s on up have a full wattage output of 200 watts, or, 50 watts per channel. This is especially true for any logic control cassette, or, all CD player systems. However, with a system with this much supposed output, you may be wondering why the sound maybe, quite frankly, a bit crappy.
The answer is no further than at the other end of those speaker wires and is in the speakers themselves. Since the mid 90s, GM has been installing 10 ohm rear speakers in almost 90% of it’s vehicles, including most of the W-body. Remember, ohms are a measure of resistance to the power that the object is receiving. The higher the number, the higher the resistance, and in this case, the less sound you’re going to get out of those speakers.
Note: The “Monsoon” systems have all 4 or 2 ohm speakers. Also, a “Monsoon” system is simply a modified amplified system which also means that some “Monsoon” systems did not seem to have a traditional amp in the head-unit plus an external amp. However, you are certainly welcome to add a pre-amped head-unit instead and get twice the boom.
The key difference between a "Monsoon" head unit and a traditional Delco/Delphi head unit was a signal called "Amp Sense." Some head units without the "Monsoon" label were designed with this feature disconnected inside the unit. RDS head units all have this feature connected by default. What this feature actually does is disable the head unit's internal amp whenever the external amp is connected along with this signal wire. Here's a really cool trick; If you have a "Monsoon" head unit or have this feature connected anyway, cut the amp sense wire. You'll notice that your system will get alot louder.
Now, onto the lesson: You maybe wondering if there is an alternative factory solution to this speaker problem other than going “Monsoon,” and, as it turns out, there is with no cutting or splicing of wires required. Remember those old Delco Sound 4 ohm, 2 way, 6X9 speakers of the 80’s that made the cars go boom out of a factory system? Well, as it turns out, there is a viable, plug n play, slightly updated version of those speakers. They were the rear speakers commonly used in 1988-1993 Grand Prixs. The model number is 16051790.
Thirdly, you know that little 9 pin AUX port on the back of a newer 90's Delco/Delphi head unit? It turns out that this little port makes your audio system expandable for a multitude of accessories. Also, there are a lot more accessories for the 9 pin port than there are for the newer 12 pin thus far.
A quick note about this port also is that all Pontiac and Chevrolet -Delco Cassette head - units with this port are CD changer compatible, however, only about a few standard CD player head-units are fully compatible with a CD changer.
Also, want to update your system and get the newer features like a 6 disc in dash MP3/CD and RDS, keep the wattage, keep it factory, but do not want to have to update to Class II Data bus, or GM LAN? Look no further than Saturn, or, should I say, Panasonic. All GM Saturn Audio Systems from the mid 90s to 2006 were made by Panasonic. Even though these systems appeared to use the newer GM plugs, they did not use Class II data bus due to the fact that this bus type was a Delphi exclusive and not really released to any third party companies (like Panasonic). True, you may have to find a way to change the Saturn Yellow match your vehicle, but, at least you can have the newer features of the GM Audio systems without having to get a whole new car.
These systems also have the 12 pin AUX port which more and more accessories are being made for.
Here is a Saturn/Panasonic in action in my vehicle: http://www.w-body.com/showthread.php...48#post1019348
Well, I hope this helps you all when considering changing that factory system, or, ripping it out because you don’t think that there is enough boom.
*Update hot off the press: Did you know that the Class II radio locking feature can be disabled and the 12V ignition on can be re-enabled? All you have to do is de-solder a pin on an EEprom inside the head unit. Here are the deets:
http://www.automotiveforums.com/vbul...d.php?t=899623
Great info if you want to give your older W-body vehicle and even a newer one an updated factory head unit.*
Thank you,
Starflare5.![]()
