Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
Thread: GEN 1 Coupe Door Handles
  1. #1
    Join Date
    May 2007
    Posts
    7,186
    Thanks
    605
    I didn't see a thread in the FAQ section, even though this problem seems to deserve its own FAQ. Is anyone planning on writing one up any time soon? My passenger side door doesn't open anymore and I'd like to fix it in case I ever have issues opening the driver side door.
    1995 Buick Regal GS(X) - Heavily modified. /modlist
  2. #2
    Join Date
    Aug 2008
    Posts
    114
    Thanks
    0
    Re: Door handles
    My passenger side doesn't open either, well, it does from the inside.
    1993 Buick Regal GS 3.8L&nbsp; Hydramatic 4T60E<br />
  3. #3
    Join Date
    May 2007
    Posts
    7,186
    Thanks
    605
    Re: Door handles
    Quote Originally Posted by Spilly
    Likewise. I haven't yet dug into the car since its 20 degrees out, so I'd like a good idea where to start so I spend as little time in the cold as possible.
  4. #4
    Galaxie500XL's Avatar
    Join Date
    Aug 2009
    Location
    Knoxville, Tennessee
    Posts
    847
    Thanks
    151
    Re: Door handles
    Personally, I prefer leaving the windows down, and entering the car a' la' Dukes of Hazzard.
    My chiropractor loves it.
    On a more serious note, I'd love to see such a writeup myself. The driver's side handle on my '95 convertible is getting flaky...it already leans outward about a half inch at the top...
    Quote Originally Posted by xtremerevolution
    1995 Cutlass LQ1 DOHC Convertible
    1993 Buick Century Station Wagon "The Refrigerator"
    2008 Chevrolet HHR 2LT
    One LQ1 in my driveway is plenty.
  5. #5
    Re: Door handles
    Are we talking about first generation coupe handles? If someone can take pictures for me, I would be willing to create a write-up.
  6. #6
    Join Date
    May 2007
    Posts
    7,186
    Thanks
    605
    Re: Door handles
    Quote Originally Posted by oscar_wilde
    Yep, 1st gen coupe writeups. I wish I could take a picture. If I had the time, I'd be fixing my transmission.
  7. #7
    Re: Door handles
    there is no real reason for a write-up though.
    you just take the two weird looking 10mm nuts off and remove the clip, turn a couple threads, and put the nuts back on.
    oh, there is a phillips screw or two. so you need a phillips screwdriver and a pliers.
    thats all I think.
  8. #8
    5speedz34's Avatar
    Join Date
    Feb 2003
    Location
    Islandview, Detroit, MI
    Posts
    10,447
    Thanks
    1
    Re: Door handles
    Quote Originally Posted by Garrett Powered
    thats all I think.
    Yup. Although there is a Torx that holds the lock cylinder in place.
    Tony.V
    1992 Lumina Z34 |3.4L 207ci DOHC 60º V6; Getrag 284|
    1994 Pontiac Grand Prix GTP |3.4L 207ci DOHC 60º V6; Hydra-Matic 4T60E|
    1999 Chrysler 300M |3.5L 214ci SOHC 60º V6; 42LE|
  9. #9
    Re: Door handles
    Don't forget spinning the adjusting screw to adjust it.
    I am sure information on how to remove the body screws would be helpful, I broke many before I learned.
    I am going to try and write this before my exam later today.
    On my quest for some pictures I could use as reference, I remembered this very site has a pretty good guide on them already.
    http://www.w-body.com/service/exterior-doorhandle.html
    /endthread
  10. #10
    Join Date
    May 2007
    Posts
    7,186
    Thanks
    605
    Re: Door handles
    /endthread
    Unlike what is described in the post, my door handle is not broken and does not flop around. It probably just needs adjustment, as I can keep yanking on it for a minute or so and it will eventually open the door if I pull hard enough...that is...if its not freezing cold outside. The problem is, I don't want to pull hard enough to break the door handle.
  11. #11
    Re: Door handles
    i've written how to do this many times. maybe I will do the write-up later. when pigs fly...
    BUILDER AND DESTROYER OF FINE(?) AMERICAN CARS.
  12. #12
    Re: Door handles
    Take off the bottom panel that is basically directly under the door handle on the inside. You can pop off the linkage, which will be a tapered rod. You rotate the holding nut thingy and pop it back on the handle. Trial and error for best results, hopefully your rod isn't bent. I think my rod was bent a little and made adjusting futile.
  13. #13
    PanamaZ34's Avatar
    Join Date
    Jun 2009
    Location
    Panama City, Panama
    Posts
    93
    Thanks
    0
    Re: Door handles
    How about this question then ........... how do you get round using replacement (Sherman) handles/panels that don't have threaded bolts? My original passenger side handle/panel was totally wrecked after the previous owner suffered an attempted break-in (and the driver's side was missing entirely). When I removed the passenger side panel, it was held on by a couple of domed nuts that threaded onto the bolts welded onto the panel. The Sherman replacements just have plain rods that locate (approximately) through the holes in the door frame. Am I missing something, or do I have to come up with some sort of botch (plenty or silicon sealant to try to keep them in place and then drill the rods and fit cotter-pins or something similar)?
  14. #14
    Re: Door handles
    the nuts CUT into the rods to make the threads....
  15. #15
    Join Date
    Aug 2009
    Location
    Posts
    847
    Thanks
    151
    Re: Door handles
    I just did this on my '95 convertible...now, the dome lights tend to stay on. What did I screw up? All I did was turn the threaded rod a couple of turns...
1994 buick regal door latch rod diagram
door handles on 94 buick regal coupe
94 buick regal door doesnt close tight
94gtp gm oem door hardware parts list
1993 buick regal coupe outside handle to lock rod
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
