Page 5 of 5 FirstFirst ... 3 4 5
Results 61 to 68 of 68
Thread: New TGP Owner
  1. #61
    Join Date
    Oct 2009
    Posts
    119
    Thanks
    1
    Thanks mfewtrail, i appricate that. Everything looks stock, i've had a new accumlator for a while and never put it on, i hope it works.
  2. #62
    Forum Moderator mfewtrail's Avatar
    Join Date
    Nov 2002
    Location
    GA
    Posts
    6,001
    Thanks
    4
    Quote Originally Posted by Nyshadow View Post
    Go here: http://arrc.epnet.com/autoapp/8800/8800.htm It has all the PMIII info and much more. I forgot I had posted this in the FAQ's section and didn't actually need to scan anything.
    Note text under "system bleeding" where it states that accumulator replacement may only require bleeding the bleeder valves @ the PMIII unit itself and not the entire system. After accumulator replacement on my car, I only bled the PMIII unit bleeder valves on each side of the master cylinder and didn't need to bleed the entire system.
    matt f. - '93 SE, '90 Black/tan TGP(#101 of 2,749), & '90 Red/tan TGP
    http://s2.photobucket.com/home/mfewtrail
    TGP 1/4 mile times
    1990 TGP coupe VIN database
  3. #63
    Join Date
    Oct 2009
    Posts
    119
    Thanks
    1
    Ok Replaced The Accumlator, the new accumlator's O'ring was smaller than the original accumlator's O ring. Didn't think much of it and installed it with the o'ring that came with the new one. Performed a manual bleed, and noticed the pump stayed on, looked under the hood and brake flud was pissing out all over the place from the accumlator. Took accumlator back off and put the o ring from the old accumlator which was still good, put everything back together and it was all gravy. Anti Lock and brake lights both when out and the brake pedal felt normal again.
    So i drove the car a little while, the Anti Lock light came back on a few hours later and when i looked under the hood i noticed brake fluid was coming out from the top of the reservior, too much fluid maybe???
    HEre are the pics of the new tail lights i installed. Got then for $20 each from ebay, brand new in the box.
  4. #64
    94 olds vert's Avatar
    Join Date
    Sep 2009
    Location
    Eastpointe, Michigan
    Posts
    5,715
    Thanks
    420
    I'm not really a fan of those tail lights. They do look really really nice.
    Nate
    1994 Cutlass Supreme Convertible
    1991 Grand Prix GT
  5. #65
    white4d96's Avatar
    Join Date
    Sep 2010
    Location
    Pleasant Prairie WI
    Posts
    1,388
    Thanks
    246
    I like it
    Which seller did you get them from and does he have more?
    http://i475.photobucket.com/albums/rr118/jfleck91/untitled-1.jpg
  6. #66
    Join Date
    Oct 2009
    Posts
    119
    Thanks
    1
    seller is "neatcollectibles" not sure if he has anymore. Good feedback score too, Over 3K with 99.9 postive. I know they are not the Original tail lights for the TGP since they do not have the black cross lace on them but i never was a fan of the black cross lace anyway. these are for a standard 1990 Grand prix.
  7. #67
    white4d96's Avatar
    Join Date
    Sep 2010
    Location
    Pleasant Prairie WI
    Posts
    1,388
    Thanks
    246
    Yup. I have a pair but if I can find a NIB pair that would be killer.
  8. #68
    Forum Moderator GOT2B GM's Avatar
    3D Quick Pool Champion!
    Join Date
    Aug 2004
    Location
    Kitchener, Ontario, Canada
    Posts
    10,741
    Thanks
    465
    Nice work so far!
    Matt Shantz
    '95 Oldsmobile Cutlass Supreme Vert LQ1
    '94 Oldsmobile Cutlass Supreme Vert LQ1
    '90 Pontiac Turbo Grand Prix #0058 of 2749
    '92 Pontiac Grand Prix GTP - 282
    '92 Chevrolet Lumina Z34 - 284
    '88 Pontiac Fiero GT - 282
    '01 Cadillac Seville STS - Corsa
    '01 GMC Yukon Denali - GM 22's
    Quote Originally Posted by Mach 5
    Car is machine, Matt is boss status trained precision task killer..
junk rocks tgp
FELLOW TGP
oh my tgp
junk roks tgp
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
