Results 1 to 13 of 13
Thread: The Parts Number Thread!!
  1. #1
    Community Manager White93z34's Avatar
    Join Date
    Jan 2004
    Location
    Pittsburgh, PA
    Posts
    9,639
    Thanks
    31
    Someone suggested we have a Thread dedicated to parts numbers, And that is an excellent Idea. I'm going to keep this open and you can post whatever you feel is helpful to the community. I will be deleting the replys after I paste them into this Post to keep it uncluttered.
    Unless noted these are Manufacturer Part numbers and will be the same regardless of who you buy from
    Brakes:
    Power Master III Parts:
    88927271 / 18M874 - accumulator
    88927270 - pressure switch
    SIA Electronics - Call for pricing and parts (800) 737-0915
    Goodridge SS brake lines:
    '88-'90 W - GS12264
    '94-'97 W - GS12237
    Suspension:
    GMPP rear trailing arms - 12498649 <- On indefinite national backorder
    Police Package Impala trailing arms- 15856683 - QTY2
    Hub to knuckle bolts(1 and 1.5 gen front only) - 10104548
    KYB GR2/Excel G Front Sturts - 366004
    KYB GR2/Excel G Rear Struts - 236003
    Energy Suspension greasable poly sway bar bushings (when using 34mm front sway bar) - 9.5160G and 9.5167G
    Rear sway bar bracket - 10259660
    Engine:
    Oil Filters:
    2.8/3.1/3x00/3800 - PF47
    3.4 - PF52
    Note: You can use the PF52 on just about anything that calls for a PF47.
    Knock Sensor (genII 60*)- 10456208
    Crank Position Sensor (CPS) (GenII 60*) - 10456555
    oil/distributor drive O-Ring - 10477565
    Oil plug bolt thread size - M12-1.75
    Oil drain plug - 10017615
    aftermarket Magnetic plug - Motormite "Oil-tite!" 65372
    Dorman Quick Disconnect 800-401 - Cooling System Connector that screws into the LIM of 3.1mpfi, earlier 3100sfi, earlier 3400sfi, and 3.4DOHC cars.
    3.4 DOHC Timing Belt Parts:
    24502982 - Belt
    24503561 - Tensioner Pulley
    10162013 - Tensioner Pulley Bolt
    24503859 - Idler Pulley, 2 needed
    24503860 - Tensioner Actuator
    24503861 - Tensioner Actuator mounting plate.
    89017825 - Improved aluminum Series II 3800 intake gaskets
    2.8/3.1 Throttle Body gasket - Fel-pro 60728
    91-97 LQ1 Solid rubber engine mount - DEA/Pioneer P/N - A2555 (Available from Autozone)
    88-93 2.8/3.1 Solid rubber engine mount - DEA/Pioneer P/N - A2660 (Available from Autozone)
    94-96 3100 Solid rubber engine mount - DEA/Pioneer P/N - A2796 (Available from Autozone)
    97-04 W-Body Solid rubber engine mount(EXCEPT 3.5L Intrigue) - DEA/Pioneer P/N - A2796 (Available from Autozone)
    2.8/3.1 Oil Pressure Sending Unit w/ Gauge (Seems to be for any 60 degree W from 89-90): GM part number 10201491.
    Transmission:
    4T60-E VSS - 10456034
    4T60-E Parking Brake Actuator - 24213560
    Getrag 284
    Spec Stage II Clutch - SC272
    Output Shaft Seals Timken P/N - 2003N
    284 select cable - 10192248
    284 Slave Cylinder - 12550806
    282/284 Clutch pedal bushing - 14091384
    Interior:
    GM W-body Door Key "C": 12390306
    GM W-body Ingition Key "D": 26002688
    GM W-body Ignition key "E": 26024974
    Body/Misc:
    97-00 - Regal GS and Grand Prix GTP fuel pump resistor - 88951182
    1st gen Hood release cable - 10167401
    94-96 GP Fender flare Clips - 10229345
    Power steering rack pressure switch - 10238816
    Subframe Bushings
    14088025 - QTY2
    14088026 - QTY2
    14088027 - QTY2
    14088028 - QTY2
    Subframe Bolts
    10220561 - QTY4
    Subframe Retainers
    10139080 - QTY2
    10203413 - QTY2
    Fuel Tank Lines for 88-91 W bodys
    10062887 PIPE ASM FUEL RTN
    10062888 PIPE ASM FUEL FEED
    AC Accumulator:
    4 Season's PN# 33206 - VERY useful for 284 cars and Turbo Grand Prix
    -Chris D. - Your Community Manager
    "Insanity has no brand loyalty" - Got2b GM
    1992 Chevrolet Lumina Z34 3.4L TDC v6 Getrag 284
    1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
    1997 Pontiac Bonneville SSE Supercharged 3.8L v6, Hydramatic 4T60E
    1987 Chevrolet Camaro Z28/IROC-Z 5.0L v8, Hydramatic 700R4
  2. #2
    Forum Moderator mfewtrail's Avatar
    Join Date
    Nov 2002
    Location
    GA
    Posts
    6,001
    Thanks
    4
    Re: The Parts Number Thread!!
    Maybe add a link to my GP Parts catlalog scans since there are TONS of GP part #'s there along with a lot of generic w-body part #'s from 88-96?....and since nobody goes to the 2nd page of the FAQ.
    http://s44.photobucket.com/albums/f14/platjblser/
    ^Click the "GP parts catalog scans" album at the left of the screen after following that link.
    matt f. - '93 SE, '90 Black/tan TGP(#101 of 2,749), & '90 Red/tan TGP
    http://s2.photobucket.com/home/mfewtrail
    TGP 1/4 mile times
    1990 TGP coupe VIN database
  3. #3
    Lurker
    Join Date
    Feb 2004
    Location
    RI
    Posts
    3,955
    Thanks
    0
    I have the GP sedan parts catalog pages finally that I have been meaning to scan and post up as well. The GP coupe pages cover a lot but for the few body components that are different, the sedan pages should be a nice addition
    -Tony
    gtsdurango.net
    '90 Turbo Grand Prix STE - Crane H260 Cam, Getrag 282 Swap, 1.6 Rockers, Intrax Front Lowering Springs, KYB GR2s, 34mm Sway Bar, CS FSTB, AWeb RSTB, ES Poly Sway Bar Bushings, Cooper Cobra 245/50s, Speed Primer, Hail Speed Dents, NFG Keyless Entry, Lots of Extra Wiring - Running once again! Sorta!
    '92 Gutless Supreme SL - RIP 5-10 | '90 Turbo Grand Prix - RIP 6-15-05
  4. #4
    Injector O-rings:
    multitech 1
    BWD 274573 (formerly GP Sorensen 800-9220) brown silicone
    *kit contains 12 o-rings, not 8 as sometimes listed
    *half the kit will do the top half of multitech 2 injectors.
    (carried by Advance autoparts)
    *** BWD 274572 contains 8 rings... buy two and it can be cheaper than buying the 12 box
    mutlitech 2
    ACD# 217-1427 GM#12570621
    BUILDER AND DESTROYER OF FINE(?) AMERICAN CARS.
  5. #5
    Dark Ride's Avatar
    Join Date
    Dec 2005
    Posts
    1,129
    Thanks
    14
    Poly Dogbone bushings, these require drilling:
    Energy Suspension: 3-7103 R
    R is for Red, you can get them in black is well which is G
    These are torque arm bushings for a fiero
    -Mitch Reed
    1998 Grand Prix GTP Supercharged
    A Few Mods
    1990 Turbo Grand Prix
    Project Car
    1995 Chevy Lumina
    Winter Beater, Complete with no OD mod
  6. #6
    Join Date
    Apr 2008
    Posts
    1,109
    Thanks
    6
    94/95 GP Driver Information Center: 16149822 068000-7111
    96 GP Driver Info Center (DIC): 16203912 068000-7120
    <br />1998 Olds Intrigue | 1993 Bonneville SSEi SOLD!| 1996 Acura Integra GSR 4dr
  7. #7
    viable source of rear trailing arms?
    http://gmperformancepartszone.com/tu...Path=8_188_191
  8. The Following User Says Thank You to Crazy K For This Useful Post:
    RobertISaar (09-02-2010)
  9. #8
    Intake Vacuum 'T' Connector - GM Part # 24502852
    1997 GP SE | 3.8L 3800 Series II "L36" | 4T60E
  10. #9
    Dorman - OE Solutions Suspension Trailing Arm Part No: 905-501
    SQUARE TUBE - CHEAPEST AT ADVANCE AUTO PARTS! looks just like OEM arm used on impala SS...
    P.S. NOW CARRIED BY ROCKAUTO FOR CHEAPER!!!!!
  11. The Following User Says Thank You to Crazy K For This Useful Post:
    94 olds vert (12-05-2010)
  12. #10
    MOOG suspension bushings for GEN 1/1.5 sway bars (blue rubber? ones)
    (34mm bar) inner: MOOG Part # K6457 {Sway Bar Bushing Kit} Front Suspension; To Frame; w/1-5/16" Bar
    outer: MOOG Part # K6641 {Sway Bar Bushing Kit} Front Suspension; To Control Arm
  13. #11
    Door panel retainer clips:
    Auveco Part #: AP16695
    Mike F
    -2004 Subaru Outback Wagon, 2.5 liter H4, 4EAT, 107,000 miles, All Weather Package. DD.
    -1999 Pontiac Grand Prix GTP (fomerly BGA's BGGTP), Supercharged 3.8 liter V6 (blown), 4T65E-HD, 191,000 miles, lowered, Comp-G wheels, ZZP shift kit. What the hell was I thinking?
    Quote Originally Posted by AL View Post
    And I need to point something out... Mike Fehl is a genius...
    | Picture-Project Thread | Cardomain | Parts For Sale |
  14. The Following User Says Thank You to WhatTheFehl For This Useful Post:
    white4d96 (06-06-2011)
  15. #12
    gen 1/1.5 Energy Suspension polyurethane front control arm bushings (requires modification to fit)
    3.3171R or 3.3171G
    as seen:
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    http://www.amazon.com/Energy-Suspens...1957174&sr=1-7
    http://www.summitracing.com/parts/ENS-3-3171R/
    http://www.summitracing.com/parts/ENS-3-3171G/
  16. #13
    I just tried to order a new vac spider #10114903 for my TGP from gmpartsdirect.com and the order was cancelled because the part is no longer available.
    Figured that might be good info to get out there. These vac spiders are becoming harder to get.
88927270
gm 88927270
245038601993 Bonneville Quad driver circuitgm cooling system connector
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
