Page 7 of 7 FirstFirst ... 5 6 7
Results 91 to 103 of 103
Thread: **** Official Coilover Strut Mount Buy!!! Prices And Info!! ****
  1. #91
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Re: **** Official Coilover Strut Mount Buy!!! Prices And Info!! ****
    Quote Originally Posted by dohc v6
    I dont know how that is possible, I am running the same shocks and they are 1/2" for the kyb's. Send those slides back to me and I can see if I can modify them or remake them. Also I will check with a local story on sizes.
    Overkill Engineering Motorsports
    Attn: Receiving
    853 Waterway place #125
    Longwood fl 32750
    i will try to have them out to ya tomorrow. i will also include a strut rod(from an oe strut assy) the kyb has identical dimensions
    -08 Kia Spectra SX -2.0L BetaII/Auto
    -07 Chevy Uplander LT -3.9L LZ9/4T65e
  2. #92
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Nevermind mark..
    I decided that I would try a wild goose chase for different strut cartridges that would work. I remember when I was with Autozone they stocked like 6 different ones. So I took the mounts there and started comparing. Found one that fit the mount nice and the body and rod length were appx the same as the stock Gen 1 strut. The body diameter was obviously smaller though.
    I figured why not, ill buy it and the guy said to return it if it wont work and we will try ordering a few others to see if they would work.
    I get home, slap it in the housing and realize its loose in there. Low and behold, in the new struts hardware kit is a centering collar. WORKS PERFECT!!! What luck!!!!
    As of yet, I dont know the true application for this cartridge, but I know where its gonna be used now
    All I need to do is get a few smaller spacers for the mount (so the top mount nut doesnt hit the mount, but seats on the bearing) and prolly drill out the lower piece you sent me to the next size bigger so that will work.
    So I will update this later. I need to get the spacers dealt with and see if I need a lower centering collar for the strut too (doesnt look I need to since the housing and the strut are both rounded at the bottom)
  3. #93
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Ok. Found out the strut I got that will work actually goes to older VWs.. Who knew there would finally be a practical use for those pieces of scrap
  4. #94
    Well if it is 5/8 I will have to change the drawing, but thats bigger than my Konis. None the less I need to know.
    Mark
  5. #95
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Mark
    I think I have Monday off. I will just ship you out a Gen 1 strut rod (Factory Struts just had the rod, seals, and valve, i.e. no body)
    Im having huge problems trying to find a spacer to use between my tophats and the bearing, and the bearing to the nut.
    I think im gonna order some ES bushings and highjack the sleeve from one and cut to length or try a Fastenal in this area.
  6. #96
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Ok.. I just need to order a set of Energy Suspension flange bushings and highjack the inner sleeve and cut to the lengths I need to act as a spacer. Only $8 for the kit, so that'll save me a lot of time trying to track down something at hardware stores.
    Mark, on the off chance that I cant get a proper fitting spacer (the ES kit should have the exact size though) what would be the turn around to get a set of mounts to fit the stock struts after you receive these ones back and a stock strut rod to go off of as reference??
    Just wanting to know the worse case scenario.
  7. #97
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    And just another question.. I know im kinda rambling on here.
    But the mounts I got use the Com9 bearing, which is a 9/16" ID. What size is the ID for Koni inserts???
    If they are 1/2" (would just use the reducer you sent to me with the mounts) or 9/16" than me keeping these mounts gives me an excuse later down the road when these stock VW struts do blow out to upgrade to Konis Im just not in the mood to purchase a minimum of $400+ for 2 front struts right now. I wanna see how the car is gonna act and be roadworthy (kinda rough roads around here) being lowered first
  8. #98
    Bob, u should just PM me,lol. For the konis, they are 9/16 or .5635". Turn around time is normally 3 weeks or so as I build them to order. I should have my machines up and running by this week sometime. Not sure if you know but we moved into a new building.
    Mark
  9. #99
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Ok, these will work perfect for me. Ready to install as we speak
    I do have a very important question though. Not to sound like a bloody retard or anything. But will the new coilover mounts bolt to the top of the strut tower or the bottom??
  10. #100
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Ok, for those interested.
    I have these one. They are absolutely awsome!! I still need to align the car but from what I can tell I have plenty of positive caster to use. I have it jacked clear up right now and it acts like I have 3-4 degrees worth (perfect!) and I have camber in the middle and it seems about close. So there is plenty of camber adjustment.
    I just put over 200 miles on them in the past 2 days. I have no rubbing from the coilovers, and no noise from the mounts of binding. I was a little worried about how strong they are but after not paying attention and hitting some large potholes hard at 70mph with 325lb springs, they didnt break. If they didnt fail after that, they arent gonna fail period.
    Mark, I am very very happy with these. The front end is super responsive!! You can tell the stock mounts have way too much slop and degrade steering response.
    And anyone who wants to know, with these and a 325lb/in 12" spring, your drop isnt enough to have tire issues or even tuck the tire and the ride is very very very firm. Im actually gonna change to a 250lb spring to give me more drop and a slightly better ride.
  11. #101
    Yep, we sell alot of them. We also have them in stock for those of you interested.
    Mark
  12. #102
    OK, so 5/8" bearing is whats correct.
  13. #103
    BXX's Avatar
    Join Date
    Aug 2006
    Location
    Lorain, Ohio
    Posts
    8,196
    Thanks
    23
    Yeah.. best bet is to go buy a stock strut to use a test unit and just return it when your done. Just to be on the safe side
pontiac grand prix gtp 1996
96 pontiac grand prix black
coil over strut package for wbody grand prix gtp
3.1l LH0 L82 v6
coilover strut mounting hats
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
