Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
  1. #1
    Join Date
    Jun 2008
    Posts
    33
    Thanks
    0
    Had '95 inspected - Should I walk away based on what they found? (list here)
    Just had a 1995 Blue with white top, white interior inspected by CARCHEX at a dealer. 115,000 miles. 3.4L.
    I'm deciding whether or not to buy it (price is at $3000 right now). Here is what the inspector found (I used this board's advice to guide him what to look for. What I'd like to know is: 1) How much would some of this stuff cost to fix? 2) Based on what the inspector found, should I push for a lower price (it's a new car dealer, so he may not go much lower) or just walk away? I'm willing to spend some money to get the car up to snuff, but don't want to break the bank. Thanks!
    EXTERIOR
    ---Overall body/paint/wheels/tires are good
    ---Power top works Ok but needs repair ---seams ripping
    ---Top rear glass seems loose
    --- Rear window rubber seals need to be replaced.
    ELECTRICAL
    ---Power locks do not close both doors.
    ---Power antenna is inoperable.
    ---The right front power window switch is inoperable. (power window ok using main switch). The left rear power window is inoperable.
    INTERIOR
    ---Driver seat worn out and the others need cleaning. The carpets are worn and need cleaning.
    ---The A pilar cover is loose
    ---The center console top is broken loose
    MECHANICAL
    ---A/C doesn't blow cold
    ---Overall, the car runs well but the power steering is very noisy.
    ---The brake pedal gets harder after 3 or 4 pumps.
    ---Unable to verify timing belt condition (but a safe procedure when condition is unkown is to replace belt and tensioner and some cases water pump to get a 70K or so trouble free miles.)
    ---Smells oil burning (possible small leak driping on exhaust), but no exhaust smoke or oil on floor.
  2. #2
    Join Date
    Aug 2008
    Posts
    483
    Thanks
    0
    Re: Had '95 inspected - Should I walk away based on what they found? (list here)
    Your description of the car is pretty through, but some pics would help even more. Guess it depends on how much you want the car, but more important, how much of the work you can or want to do yourself. Top sounds more like it needs replacing. $800 to $1,200. Timing belt, tensioner, and pulleys around $800 to $900. Electrical switchs, antenna, and the like can be gotten at the junk yard cheap and easily changed. With a little luck and patience, good interior pieces can be gotten from the j/y also.
    New car dealers in particular will not hang onto a car that old for very long. Especially a vert at this time of year. The convertible season is pretty much over. They'll just send it off to the auction, where they'll probably only get about half as much as the asking price. Bottom line is, cash money talks. $2500 doesn't sound too bad, but I'd go in with the $2500 but show him $2000 to start and go from there.
    Tom
  3. #3
    Forum Moderator GP1138's Avatar
    Join Date
    Sep 2003
    Location
    Dayton, OH
    Posts
    11,057
    Blog Entries
    1
    Thanks
    798
    Why were they unable to verify the timing belt condition? Did they not posess a ratchet and socket?
    John C. Wallace
    1997 Pontiac Grand Prix GTP - L67 3800 Supercharged - 4T65E-HD - Sony MEX-DV2200 - Torquelaces FTW!!
  4. #4
    Join Date
    Jun 2008
    Posts
    33
    Thanks
    0
    I've attached a few pictures here. The inspector could not verify the timing belt because CARCHEX doesn't seem to take apart stuff - I think due to insurance reasons.
    So it seems I'm looking at about $2000 to do some of this work?
    UPDATE: The seller says his mechanic thinks the oil leak is the INTAKE MANIFOLD. Any thoughts on this? Cost?
    Also, any thoughts on the BRAKES being "hard to pump after 3 or 4 times" and the "power steering being noisy"?
    THANKS!
    Rob
  5. #5
    ManicMechanic's Avatar
    Join Date
    Dec 2004
    Location
    FEMA Region 6
    Posts
    7,807
    Thanks
    153
    Quote Originally Posted by djrobnyc
    Oil pump drive. A LOT to do it right...
    Sounds like a low vacuum problem which could be any number of things, the cheapest of which is an incorrect vacuum line. The PS pump will be a pain because the car has Magnasteer. IF it is the PS pump. My car makes a whining noise like a low PS pump and it's the A/C compressor.
    I think you can do a lot better for less. It's a pretty and rare car but probably not yet worth all the work it needs.
    Jay
    1988 GMC Sierra K1500 Indy 500 Support truck clone AWD "Syclone on steroids"
    1991 Chevrolet S10 Blazer with every option that can be added but never could have from the factory
    1995 Oldsmobile Silhouette that's my trusty companion and has followed me all over the country
    THE ANSWER TO 1984 IS 1776.
  6. #6
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,862
    Thanks
    20
    Honestly, that car sounds like its in pretty poor condition... It doesnt sounds like it was taken care of... Its not worth 2 or 3 thousand in my opinion. Its worth closer to 1200.
    98 Regal GS - 275k, on the race to 300k
    99 Silverado Z71 - 204k, BGA express
    03 Grand Prix GT - 81k, Hopefully will see the road again someday
    97 Grand Prix GTP - 173k, Sloppy Seconds V2.0
    Quote Originally Posted by BXX View Post
    Al is a big sexy stud
    Quote Originally Posted by 95GPSE View Post
    But the Grand Prix is a Grand Prix, which automatically trumps all.
  7. #7
    Join Date
    Nov 2003
    Posts
    147
    Thanks
    0
    The way I see it is this - 1995 was the last year for this car - if you plan to keep it and enjoy for a long time, then I would take the plunge for up to $ 2000.00. Other than the top, the exterior looks pretty good. Where is this car? and is it rust free for the most part? Most of the repairs seem to add up to a lot of money, but, if you are patient, can do some of the small stuff yourself with salvage yard finds, and then pay the right person to do the other jobs right, you will have a beautiful car that rides great for a fraction of the cost of anything new that is being produced today that is not as nice. Also, this car will some day be a collectable and the pricing on the good examples will start to appreciate slowly, so if you fix it right and keep it up, you will not lose anything.
    http://www.cardomain.com/ride/466769<br />1995 Oldsmobile Cutlass Convertible&nbsp;&nbsp; /&nbsp;&nbsp; Red with White Top and White and Graphite Interior
  8. #8
    Join Date
    Jun 2008
    Posts
    33
    Thanks
    0
    Thanks for everyone's comments. I spoke with 2 former Olds dealers in my area and I'm definitely looking at $2000 (at least) for the essential mechanical stuff (not counting the cosmetic things, which I'd do over time). The seller says he's got an offer at $2700; I told him I'd offer him slightly above wholesale $1500-$2000, so we'll see if he sells it. If not, maybe he'll come back to me. Again, thanks.
  9. #9
    Join Date
    Aug 2008
    Posts
    483
    Thanks
    0
    I wish you luck. There is a lot of information on this sight on most of the repairs you are looking at, should you buy the car. Post any questions about the repairs, and there are plenty of very knowledgeable people on this sight to help you out. That rear window weatherstrip in your photos is a good example. That's a common problem on the verts. There are a couple of threads on here that tell, with pics, how to adapt the door weatherstrips from a Camaro/Firebird to fix that problem. There are also people here that seem to be very generous with there time also, and willing to help fellow w-body members out with repairs, like the timing belt. Don't know where you live, but if your lucky, one of them may be in your area and willing to lend a hand. If you buy the car with the intention of keeping it, don't mind spending some money on it, and can get it for the right price, then I would seriously consider it. But that's just me.
    Tom
  10. #10
    Join Date
    May 2008
    Posts
    2,064
    Thanks
    12
    Good luck with the seals...they are discontinued and NOS is ridiculously expensive. You can find a better car for the money you'd have into this one. Just look around and be willing to go get it within good radius. I think this one has been mechanically neglected throughout it's life
    '01 Silverado W/T, 4.8 / 4L60E / 3.42 / 320k
    18" Z71 wheels, black leather Avalanche interior, Magnaflow muffler, Escalade cluster, Pioneer / Alpine sound, tinted tails, leveled, black bowtie, tinted windows, LS exterior conversion
  11. #11
    Join Date
    Aug 2008
    Posts
    483
    Thanks
    0
    Quote Originally Posted by oldscsc
    Definately wouldn't hurt to shop around. And if your not in a hurry, another one will probably come along later for the same money, in better condition. Always a possibility. Something to also think about.
    Tom
  12. #12
    Join Date
    Apr 2003
    Location
    Cincinnati, OH
    Posts
    17,684
    Thanks
    1,194
    Seriously, if you have any hands on knowledge, 90% of the above listed stuff can be fixed VERY easily.
    The console lid broken, good luck finding one, they ALL break. Poor design.
    A switch that's not good- $20 at the JY will fix that.
    Locks don't lock the doors- the rods just need adjusted a bit.
    The top, well, it's a convertible. Your going to have problems with it. And the weatherstripping, good luck finding any of those, and good luck finding a Cutlass vert who's weatherstripping isn't bad.
    If you own a 7mm socket, and have 5 minutes of your own time, pull off the timing cover. If the belt is good, it will look normal. If it's failing, you will see shreds, or just a failing belt. Pretty easy to tell.
    To me, the car sounds no different than the average 10-15 year old vehicle. And, keep in mind, convertible's tend to have a bit more issue's (interior electrically) than most, do to the extra moisture that does get inside of the vehicle.
    I'd offer $2500. If he doesn't like it, keep looking.
    Chris D.-
    '02 Buick Century- Wife's
    2012 Jeep Grand Cherokee- Company Car/DD
  13. #13
    Join Date
    Dec 2004
    Location
    FEMA Region 6
    Posts
    7,807
    Thanks
    153
    Quote Originally Posted by slick
    8mm
    Jay
  14. #14
    AL's Avatar
    Join Date
    Apr 2008
    Location
    Toledo, OH
    Posts
    8,862
    Thanks
    20
    This worries me... Was this being tested while the car was running?
  15. #15
    Join Date
    Apr 2003
    Location
    Cincinnati, OH
    Posts
    17,684
    Thanks
    1,194
    Quote Originally Posted by ManicMechanic
    8mm
    7, 8, who cares LOL!
    Chris D.-
powered by vBulletin information in walk for diaes
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
