Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
  1. #1
    Large Front disk brake conversion?
    according to this page, http://www.w-body.com/upgrades/brakes-rotors.html my 1995 allready has 4 wheel disk, correct? I think i am going to price out a set of rear disks for the monte... kind of embarising having rear drums behind my 17's.
    But the next questions is... for the fronts all i need is the knuckles and a new set of rotors correct? Can I use my KYB GR-2's with the new knuckle/strut assembly? can i swap my hubs over because i just got BRAND NEW ONES about a week ago.. don't want to waste them.
    it looks sweet with my rear disk brakes peaking out from behind my monte carlo wheels on my lumina. now i need my fronts to do the same. I think i am going to powder coat the brake caliper housing.
  2. #2
    Join Date
    Aug 2002
    Posts
    299
    Thanks
    0
    What the christ is "powder coating" anyways?! I always hear about it and I'm oblivious to it's meaning...
    -MaD-
  3. #3
    Quote Originally Posted by MaD
    -MaD-
    basicly its a way of painting things. when you spray the Powder coat on, then it needs to be baked. it makes the paint hard and VERY durable, any colored wheel is powder coated and clear coated from factroy.
  4. #4
    Join Date
    Aug 2002
    Posts
    299
    Thanks
    0
    ok, but what is the "powder coat" is it actually powder? like talcum powder? lol
    -MaD-
  5. #5
    Join Date
    Aug 2002
    Posts
    1,499
    Thanks
    0
    Yeah, it's real powder. Pretty much dry paint. It's sprayed onto a prepared surface [mostly metal]. It is then baked in an oven. After it is finished, the powder becomes very hard and shiny. If it's done right, it also prevents rust. You can get powder coat paint in almost any color you want.
    2007 Pontiac Solstice GXP<br />Stock for now...
  6. #6
    Join Date
    Aug 2002
    Posts
    299
    Thanks
    0
    How much do you suppose it would cost to powder-coat a cutlass sedan.
    I'd like neon green, or maybe lemon yellow.
    ...I'm kidding, I want black.
    Is this something you should do as body work? Isn't the exterior paint baked on anyways, like from the factory?
    -MaD-
  7. #7
    Join Date
    Aug 2002
    Location
    Minnesota
    Posts
    892
    Thanks
    0
    a whole car?? Probly like 4-5K
    just for a Frame its 1000
    <br />tgp/ste part numbers<br />1990 STE turbo white/gray leather Power Roof <br />1996 Dakota 4x4 ext cab w/71 360ho<br />2000 Dakota Sport V8 4x4 ext cab on 32&quot; bfg&#39;s<br />1978 Coupe DeVille<br />&quot;Friends help you move, Good friends help you move bodies.&quot;
  8. #8
    Join Date
    Aug 2002
    Posts
    299
    Thanks
    0
    Eh, that's what I figured. That's similar to a OEM paint job, right?
    -MaD-
  9. #9
    Anonymous
    -MaD-
    I would say better than a factory paint job. No runs and no orange peel in the paint causr it's not sprayed on as a liquid.
  10. #10
    Join Date
    Aug 2002
    Location
    Minnesota
    Posts
    892
    Thanks
    0
    I am acctually hopping to get into the powdercoating Buisness Im going to a Grant meeting this weekend to see if I can get a Grant to start a Small Buisness.
  11. #11
    Join Date
    Aug 2002
    Location
    Battlefield, MO
    Posts
    10,621
    Thanks
    94
    Re: Large Front disk brake conversion?
    Quote Originally Posted by RedZMonte
    No, the Monte Carlo is an exception. The 95 Monte's and Luminas have rear drums. I think rear disc brakes started with the 96 Monte Z34, but regular Monte's got drums.
    On the fronts, yes, all you need is knuckles and rotors. You should be able to use the GR2's with your new strut/knuckles. You can swap your hubs over, no probs.
  12. #12
    TurboSedan
    i'm wondering how much the front brake upgrade will improve braking performance. i'm guessing the front brake upgrade would be more noticable than the rear brake upgrade (performance wise) since the front does like 75% of the braking? it just seems like the rear brake upgrade is done more for reasons with caliper design and reliability than the bigger rotor itself, whereas the front brake upgrade really only means bigger rotors. of course, i still want to get carbon fiber pads and crossdrilled or slotted rotors too and hopefully that makes big differences also.
    joshua
  13. #13
    Join Date
    Aug 2002
    Posts
    122
    Thanks
    0
    I imagine there malibuolds that the advantage to bigger rotors in the front is better heat dissipation because of the larger surface area. This means your brake parts, especially the pads, will last longer. If you want to improve, performance wise, stopping distance then the best place to look to for that are the tires. It's a question of adhesion to the road since even a small set of modern rotors and calipers can easily lock a wheel without breaking a sweat.
  14. #14
    Quote Originally Posted by GnatGoSplat
    DUH, i dunno what i was thinking when i typed that.. but i know my car has rear drums.. I think what i ment was..
    Does my monte allready have the large front disks?
    I Must have been smoking something when i wrote that!
    RedZ
  15. #15
    Quote Originally Posted by crc
    Correct. the 1997+ GTP guys are upgrading the fronts using a "Olds Intreuge Autobaun brake package" which are all stock parts for the Intreuge and just going with a larger rotor and stock gp calipers see a noticable difference. again because of heat dispersment. it should make a noticeable diff.
    If not it looks cooler having the big disks as well as makes your mod list longer.
    RedZ
part number: br1990 brake rotor
disk brake conversion 96 monte carlo
96 monte carlo disk.brake conversion
monte carlo front large disc brake conversion
larger front brakes for 95 monte carlo
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
