Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
  1. #31
    Lurker Captain Ficho's Avatar
    Join Date
    Dec 2007
    Location
    Toronto Ontario
    Posts
    560
    Thanks
    10
    Re: Additive to quieten down piston slap??
    Quote Originally Posted by Psych0matt
    restore, I like it, but I wont tell everyone to use it. Just a personal preference i guess. I've noticed more on older more beat engines than on better taken care of engines
    Agreed, my car had 105k miles and had always been well-taken care of and Restore did nothing for it. However I know it has worked miracles of some of my friends cars which have much higher mileage and have taken a beating.
    DD's:
    2012 Ford F150 SuperCrew XTR, Blue Flame Metallic... 8000 miles.
    1997 Pontiac Bonneville SE Supercharged - 213k miles... original engine
    Toys:
    1987 Buick Grand National - 63k - Show car/garage queen... and fast
    1989 Pontiac Turbo Grand Prix - LQ1 turbo 284... in progress...
  2. #32
    Lurker Brian P's Avatar
    Join Date
    Aug 2002
    Posts
    13,126
    Thanks
    136
    Quote Originally Posted by montecarlodude
    its odd, the monte never get's lifter tap when it's cold, just when it has been started and shut off for half an hour to one hour, then started again. i am thinking it may be a drain back problem in the filter, im useing an ACD now. i think i am going to try a napa gold oil filter next time i do my oil.
    My cam makes things more obvious. They make a little more noise as it is.
    Yeah, it's still on the road. 5/21/12 210,800+
  3. #33
    SigEpCutlass's Avatar
    Join Date
    Dec 2003
    Location
    Arlington Heights, IL
    Posts
    4,019
    Thanks
    0
    OMGODZOR teh FRAM!
    j00 fail!
    But seriously...I've never found anything to get my 3100 to quiet down completely. It's quieter with the Amsoil Synthetic I use, but it's not perfect.
    - Mike K.
    '94 Oldsmobile Cutlass Supreme SL 4AT - For Sale
    '00 Subaru Outback AWD 5MT - Soccer Mom Pimpin'
    '04 Mazda Mazda6s 5AT - Wife's
  4. #34
    Its black and its rusted... I bet that failed for reasons other than being Fram (if it even is a Fram) Hence why I said post a pic of YOUR filter that failed, anyone can find a pic of a random failed filter.
    Jamie
    Can't Stand Idiots_MuNkY
    1991 OLDSMOBILE CUTLASS SUPREME INTERNATIONAL - 3.4L DOHC
    1999 GMC JIMMY SLE - 4.3L, 4x4
  5. #35
    Join Date
    Jan 2007
    Posts
    95
    Thanks
    0
    I actually had one "fail". I purchased the Fram Duraguard several years back...after the oil change and driving around for a few minutes I noticed the oil pressure was at zero at idle. Once you were above 1200 rpm or so you had pressure again. I thought the oil pressure sensor, failed. replaced it, same thing. Changed the filter, problem fixed. 1 year later I had bearing knock. this was on a chevy 350 engine. I will never ever buy a Fram ever again...it cost me a few thousand dollars
    96 Grand Prix Coupe L67
  6. #36
    19Cutlass94's Avatar
    Join Date
    Apr 2005
    Location
    Texas
    Posts
    10,140
    Thanks
    40
    I just changed the oil in my car today and it was still a golden brown color. Sometimes my car will get that noise, sometimes it wont.... its strange
    Jay
    1994 Oldsmobile Cultass Supreme SL
    3400/Getrag 284
    1995 Chevy K1500 350c.i. 5spd Z71
    Stock
  7. #37
    Join Date
    Jan 2008
    Posts
    17
    Thanks
    0
    I would think a thicker oil would help quiet the noise. Just last weekend I changed the oil in my 94 CS. It has 158,000 miles and makes some ticking noise, not terrible, but noticable. I put 2 quarts of 10w40 and 2 quarts of 20w50 along with a bottle of STP. Yeah, it might seem a bit thick, but the 3100 in this car uses about 2 quarts of oil between changes (every 3000 miles) and is just ready for another quart at the time of the oil change. The thicker oil should help slow down oil consumption.
    Also, I bought the 20w50 a couple years ago at Target for 68 cents per quart. I bought 24 or 25 quarts. I couldn't pass that deal up, especially since it was the grade of oil I was using in an old car at the time.
    As for filters, I only use AC Delco. I've heard too many bad stories about Fram, and I've seen the cutaways at Carquest showing how AC's are constructed better. But I guess that doesn't mean that if you use Fram, it'll fail. If you feel comfortable with a certain brand, then that's great.
  8. #38
    93CutlassSupreme's Avatar
    Join Date
    Nov 2003
    Location
    Detroit, Michigan
    Posts
    3,384
    Thanks
    0
    Quote Originally Posted by Big_Ed
    Yup, thick oil is a great band-aid for serious problems. My '88 cutlass wouldn't develop shit for oil pressure at hot idle unless it was filled with 20W50. Even filled with 20W50 it was just barely above the red mark, but at least it was above. I even considered dumping in some "Motor Honey" in to thicken up the oil even more
    1988 Oldsmobile Cutlass Supreme International 5-speed - RIP
    1993 Oldsmobile Cutlass Supreme SL - 3.1L
    1997 Pontiac Sunfire SE - 2.2L
    1984 Honda VF500C - 500CC DOHC V-4 - 62 HP @ 12,500 RPM - 6-speed - Harley-Davidson Killer
    1982 Kawasaki KZ550 LTD - 550CC DOHC I-4 - 50 HP @ 8,500 RPM - 6-speed
    "Cocaine is a hell of a drug." -Rick James
  9. #39
    Lurker paulo57509's Avatar
    Join Date
    Dec 2002
    Posts
    247
    Thanks
    0
    Quote Originally Posted by 5speedz34
    I wouldn't use the ACD filters. They redesigned them a year or two ago and the E-Core filter in them suck. They sometimes fail.
    I'd like to know how they fail because I use E-Core filters exclusively.
how to quiet piston slap
additive for piston slappiston slap additivepiston slap symptomsquiet piston slap
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
