Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Thread: 3100 coolant leaking onto starter
  1. #1
    Looked at somebody's 3100 today and appears to have coolant leaking onto the starter vacinity, but it might be from the bleader valve. The thermostat housing doesn't appear to be leaking and doesn't look like anything is leaking from any nearby lines. Wondered what other possibilities exist. Oil is clean. Car is a 96 with 190K on the clock.
    <br />92 coupe and 93 vert LQ1&#039;s<br /><br />I own 2 so I have one to drive when the other breaks
  2. #2
    Join Date
    Aug 2007
    Posts
    420
    Thanks
    0
    Re: 3100 coolant leaking onto starter
    Upper Radiator hose, or quite random but a crack in the thermostat inlet pipe... are you running dexcool?
    1999 Lumina Ls 3100<br />-GMPP Front STB<br />-MMI WAI<br /><br /><br /><br />Obama For President!!
  3. #3
    cutty's Avatar
    Join Date
    May 2004
    Location
    Pittsburgh, PA
    Posts
    1,138
    Thanks
    2
    could be a water pump also
    -Jim
    1995 Oldsmobile Cutlass Supreme SL | 3.1L(3100 SFI) 191ci 60º V6; 4T60E
    2008 Dodge Grand Caravan SE | 3.3L V6
  4. #4
    Join Date
    Aug 2007
    Posts
    420
    Thanks
    0
    Quote Originally Posted by cutty
    water pump is on other side of the motor, if it was leaking it would end up on the vally between the ac compressor or on the ac compressor
  5. #5
    Bad freeze plug?
    Jay
    1988 GMC Sierra SportSide "Indy Hauler" clone|350 TPI (project in pieces)
    1991 Chevrolet S10 Blazer Sport 4x4|4.3 TBI (Winter driver)
    1995 Oldsmobile Silhouette|3.8 TPI (Summer driver)
  6. #6
    Lurker
    Join Date
    Nov 2007
    Posts
    96
    Thanks
    0
    Check the coolant hoses/pipes under the TB. It could drip onto the trans and down onto the starter. Best bet is to put a pressure tester on it. Autozone rents them.
    1991 Cutlass Supreme 3.1L 109k<br />
  7. #7
    cutlassdude96's Avatar
    Join Date
    Aug 2002
    Location
    Bloomington, Indiana
    Posts
    1,601
    Thanks
    4
    check intake gaskets
    4 + 4 + 2 = 10 for Oldsmobile 1996 Olds Cutlass Supreme SL IV 3100
    RIP Oldsmobile 1897-2004
  8. #8
    Quote Originally Posted by cutlassdude96
    does this commonly cause external leakage?
  9. #9
    Join Date
    Aug 2002
    Location
    Posts
    1,601
    Thanks
    4
    Quote Originally Posted by joey b
    im not sure, but I have had that happen to me once and it was either the gaskets or an o-ring on the heather line going the heather core
  10. #10
    SigEpCutlass's Avatar
    Join Date
    Dec 2003
    Location
    Arlington Heights, IL
    Posts
    4,019
    Thanks
    0
    Quote Originally Posted by Chancho
    That is correct. Now if you were saying that there was coolant on the acc. belt, then it'd definitely be the water pump.
    That is incredibly unlikely to be the cause of an external leak unless the UIM is not torqued to spec. Check the upper rad hose and go from there.
    - Mike K.
    '94 Oldsmobile Cutlass Supreme SL 4AT - For Sale
    '00 Subaru Outback AWD 5MT - Soccer Mom Pimpin'
    '04 Mazda Mazda6s 5AT - Wife's
  11. #11
    no... it can leak to the outside. usually they leak to the inside though. maybe 1 in 20 leaks out and not in.
    BUILDER AND DESTROYER OF FINE(?) AMERICAN CARS.
  12. #12
    Lurker
    Join Date
    Nov 2007
    Posts
    96
    Thanks
    0
    Head gasket could come out the front also...
  13. #13
    i was thinking freeze plug too
  14. #14
    Join Date
    Aug 2007
    Posts
    420
    Thanks
    0
    I still think its the upper rad hose
  15. #15
    I think it's the intake gasket, only because when mine went, the coolant dripped from near the oil pump drive, ran down the block and soaked the starter.
    Yeah, it's still on the road. 5/21/12 210,800+
antifreeze leak on 3100 v6 on thermostat housing
1996 oldsmobile cutlass supreme coolant leak
2002 3100 coolant leak
95 oldsmobile cutlass leaking around the water pump housing
96 oldsmobile cutlass supreme leaking antifreeze
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
