Page 1 of 14 1 2 3 11 ... LastLast
Results 1 to 15 of 197
Thread: How to lower a W-Body ( Gen 1, Gen 1.5 )
  1. #1
    19Cutlass94's Avatar
    Join Date
    Apr 2005
    Location
    Schenectady NY
    Posts
    9,489
    Thanks
    27
    Since this is being brought up soo much, Im going to make this a one shot deal with where you can get all the parts you need and all the options to lower your W-Body!
    This will be for 1st gen W-body's.
    If you do not know what 1st gen is, look on the main page of this site ( www.w-body.com )
    First we will start with the Front Suspension of your car. Here you have a few choices.
    1st - Held Motorsports Coilovers
    You can go with Held Motorsports Coilovers. Yes thats right Coilovers in the front of your W-Body. Held Motorsports' Coilovers can be found HERE:
    http://www.heldmotorsports.com/WBody/index_1.htm
    They come in 3 stages, but expect to pay more as the stage increase ( i.e. less for stage 1 and the most for stage 3 ) If you have any questions, e-mail THEM. They are good about getting back to you. I know. Ive e-mailed them several times. I am not sure if these come assembled or if you can assemble them to save money. These will replace your front strut assembly.
    Another option for front coilovers is to have your own custom made. This will involve research on your part. Im not going to sit in front of the computer for hours search all the part and part numbers. Why, because I dont want them bad enough. Thats your job if you want them
    2nd - Suspension Techniques
    These are Front Lowering Springs. They can be bought through JC Whitney. HERE:
    http://www.jcwhitney.com/autoparts/I...21749610192661
    Part number is 810113. These say that they will fit the '95-'99 Chevy Monte Carlo, but will fit the 1st gen suspension setup. Why because the front suspension is the EXACT same on these cars. Advertised drop on these springs are 1"-1.5". Although almost every member has claimed Atleast 2" drop. Some near 3". ( which is just about what I have gotten from these. )
    3rd - Eibach
    These are also Front Lowering Springs. These are advertised at a 1.7" drop.
    4th - Intrax
    Once again Front Lowering Springs. These are advertised at a 1.8" drop.
    I do believe that the Eibach and Intrax springs are now discontinued. Although still can be bought from another member/ebay, etc etc
    Now moving to the Rear Suspension
    Remember, although aftermarket parts can be bought, if it doesnt deal with lowering, Im NOT LISTING IT.
    1st - Fast FWD Performance Coilovers
    These kits are now discontinued. You can always purchase from a fellow member or ebay or wherever you can find them. They can be found HERE:
    http://www.fastfwdperformance.com/coilovers.html
    Since this link does not work anymore for the fact that no products are being made by FFP, You can still access install instructions by going HERE and clicking on How to Install Coil-Overs?
    These will replace not only your rear struts, but your rear monoleaf. You will have to remove your mono-leaf to install these.
    If you need new bushings for these coilovers, They can be found HERE: http://www.energysuspension.com/pages/sboots.html
    The part number that you need is 3.6110
    Here is a picture of what it looks like:
    http://i199.photobucket.com/albums/a...ture-05021.jpg
    And here is the bushing installed on the spring:
    http://i199.photobucket.com/albums/a.../photo0031.jpg
    2nd - Birchmount Rear Monoleaf
    These will replace your stock monoleaf, and nothing else. I have heard about a 2" drop, although I have not known many people to buy these, and as of late, however they are a source to lower the ass end of your W-Body! I have heard that they will make you a mono-leaf to whatever drop you need. This will match your front nicely.
    Contact Information:
    Birchmount Auto Spring Company
    458 Birchmount Road
    Scarborough, ON
    M1K1M6
    Telephone: (416) 698-3636
    Fax: (416) 698-5732
    3rd - Held Motorsports
    Like the FFP Coilovers, these are just like them. Coilovers for the rear of your car. More information can be found HERE:
    Just like the fronts ( from Held Motorsports as well ) they come in 3 stages. I am not sure if these come assembled or if you can assemble them to save money.
    4th - FAF ( Flex-A-Form ) Monoleaf
    This is similar to the birchmount in the fact that it replaces your rear monoleaf, nothing else.
    If you want to make your own rear coilovers, here is a start for you:
    There are many places you can buy these same exact parts. Such as www.Summitracing.com But this is just one place where you can find these parts.
    Here is a list from www.summitracing.com List includes different spring rates for the 12"x2.5" coil-over springs
    You will need to choose your spring rate from these springs.
    http://store.summitracing.com/egnsea...115+4294787535
    List from www.summitracing.com for sleeves and adjuster nuts
    You will need to choose the length of the sleeve. Normally a 7" sleeve will be more than enough for all the raising and lowering that one could do.
    http://store.summitracing.com/egnsea...115+4294807119
    Now that I have started you in this direction, you can do the rest if you would like!
    Now for the Gen 1.5 W-body's.
    Again, if you do not know your generation, check out the main site ( www.w-body.com )
    Once again, well start with the Front Suspension of your car.
    http://heldmotorsports.com/WBody/index_1.5.htm
    These are Front Lowering Springs. They can be bought through JC Whitney, HERE:
    http://www.jcwhitney.com/autoparts/P...n%20techniques
    Part number is 810113. These say that they will fit the '95-'99 Chevy Monte Carlo, which is the Gen1.5. Advertised drop on these springs are 1"-1.5".
    3rd - Eibach
    These are also Front Lowering Springs. These are advertised at a 1.3" drop. These can be found HERE. Remember!!!! These come in 2 pairs front and rear!!!
    http://www.drivewire.com/performance...rloprokit.html
    4th - Intrax
    Once again Front Lowering Springs. These are advertised at a 1.8" drop. These can be found HERE. Remember!!!! These come in 2 pairs front and rear!!!
    http://www.drivewire.com/performance...ngsprings.html
    Just like the fronts ( from Held Motorsports as well ) they come in 3 stages. Once again either call them or e-mail them to get pricing or with questions etc etc.
    These are Rear Lowering Springs. They can be bought through JC Whitney, HERE:
    http://www.jcwhitney.com/autoparts/I...21749710192663
    Part number is 810114.Advertised drop on these springs are 1"-1.5".
    3rd - Eibach
    These are also Rear Lowering Springs. These are advertised at a 1.3" drop. These can be found HERE. Remember!!!! These come in 2 pairs front and rear!!!
    4th - Intrax
    Once again Rear Lowering Springs. These are advertised at a 1.8" drop. These can be found HERE. Remember!!!! These come in 2 pairs front and rear!!!
    *IMPORTANT NOTICE*
    For all gen 1.5 W-Bodies, you can purchase all four springs in ONE set instead of buying them seperatly. Look for this as well and not just front and/or rear springs.
    A search on this site for these products is recommended, however here are some searches for you:
    Flex-A-Form Rear Monoleaf
    http://www.w-body.com/forum/index.ph...c,29355.0.html
    Make your own Coilovers
    http://www.w-body.com/forum/index.ph...c,55194.0.html
    http://www.w-body.com/forum/index.ph...c,51716.0.html
    Thanks for the links Low'nSlow!
    ST Front Lowering Springs
    http://www.w-body.com/forum/index.ph...c,51247.0.html
    Really, theres too many links to post. Its been talked about ALOT. Search and youll find whatcha need!
    Lastly, here is a complete thread that is basically a walk through on overhauling the W-body suspension. Parts used in this 'overhaul' include;
    - Front and Rear Held Coil overs (c/w KYBs)
    - Held Motorsports Trailing arms w/ Poly bushings
    - Held Motorsports Lateral links w/ poly bushings
    - 7/8" G-max rear sway bar w/ poly bushings ( ADDCO swaybar )
    - "Original Performance" Front end kit from P-S-T
    - Aweb RSTB (in paint)
    - Custom front STB
    This thread is 13pages long, however it contains great information about the W-body suspension set up w/pictures. Which can be found here: http://www.w-body.com/forum/index.ph...c,61157.0.html
    Thanks to GTP_MuNkY
    Jay
    1994 Oldsmobile Cultass Supreme SL
    -Modded
    1995 Chevy K1500 350c.i. 5spd Z71
    -Modded
  2. The Following User Says Thank You to 19Cutlass94 For This Useful Post:
    AMP (08-04-2011)
  3. #2
    Re: How to lower a W-Body
    Nice
    Aren't the Eibach front springs discontinued now though?
    Also take into consideration that manual cars will get less of a drop out of the front with springs. The person who sold me the Eibach springs claimed he recieved little to no drop out of the Eibach's.. where as I am sure I got almost 2 full inches.
    O yeah...I vote sticky
    Mathew Smith <br />2009 Yamaha R6 - I love gold!
  4. #3
    5speedz34's Avatar
    Join Date
    Feb 2003
    Location
    Islandview, Detroit, MI
    Posts
    10,447
    Thanks
    1
    Quote Originally Posted by 97loudcut
    Nice
    They've been discontinued for a while.
    Tony.V
    1992 Lumina Z34 |3.4L 207ci DOHC 60º V6; Getrag 284|
    1994 Pontiac Grand Prix GTP |3.4L 207ci DOHC 60º V6; Hydra-Matic 4T60E|
    1999 Chrysler 300M |3.5L 214ci SOHC 60º V6; 42LE|
  5. #4
    pwmin's Avatar
    Join Date
    Nov 2003
    Location
    Denver
    Posts
    4,069
    Thanks
    41
    thanks, its about time somebody did this...
    <-----yells at self
    fwiw, my car's stock gap w/ 5spokes and 225/60/16 tires was appx. 28" from the ground. after i lowered it w/ st springs and rear coilovers, it was appx. 25" from the ground on 245/45/16's.
    FAF monoleaf (search).
    quote from (tdaye): http://www.w-body.com/forum/index.ph...c,29355.0.html
    "i've got a flex-a-form spring in right now, I started with a 3 leaf steel spring but i didn't like the ride. I have got a total of 4 springs from George also. The trick is with George is to call him on the phone. I had the same problem with him not anwsering my emails. Call him on the phone and he was great with me and sent me another spring within 2 weeks each time.
    depending on the height you want on the rear use these numbers.
    his spring "300" (300lbs per square inch) gave my car 28" to center of the rear wheel well
    his spring "250" gave my can a 27 1/2" (1 and 1/2" total drop)
    now he is sent me a "200" and a "185" the "200 should give my car a 2" + drop and I think the "185" might be too low, but i'll let you know because I haven't installed it yet. Use these #'s if you plan to order from him and don't wanna change your spring 4 times...also call him on the phone don't email him!
    QA1 springs from summitracing can be had for like $80 shipped per pair or $110 for progressive springs. any 12" length spring w/ a 2.5" ID will work with the sleeves and nuts you posted; i have also found a few other companies you can get them from (if youre interested in different colors), including eibach. you can also buy sleeves and nuts from afco, but their sleeves will require slight honing to fit over the shocks.
    making your own coilovers:
    1998 Buick Regal GS
    1987 V10 (SM465/LT1-L31 TBI)
    Former w-bodies - 1996 GTP Special Edition, 1991 GTP 5-speed
  6. #5
    Forum Moderator digitaloutsider's Avatar
    Join Date
    May 2003
    Location
    Pittsburgh, PA
    Posts
    7,262
    Thanks
    34
    Quote Originally Posted by 19Cutlass94
    How to lower a W-body
    Wait a while.
    Seriously though, thanks for the write-ups!
    2006 Nissan Altima SE-R | 3.5L 214ci VQ35DE DOHC 60º V6 | 6MT
    Raclingline HFPCs and Y-pipe, NWP VIAS delete, Goodridge SS brake lines, removed airbox snorkel, deburgered.
    1997 Pontiac Grand Prix GTP | 3.8L 231ci Supercharged 90º V6 | 4T65E-HD
    SD hood, intake, big brake upgrade, 2500k HID fogs, Auto Meter Ultra Lite gauges, DHP 1.5.
    1992 Chevrolet Lumina Z34 | 3.4L 207ci DOHC 60º V6 | Getrag 284
    WOT-TECH chip, SPEC Stage 2 clutch. FOR SALE.
  7. #6
    Join Date
    Apr 2005
    Location
    Schenectady NY
    Posts
    9,489
    Thanks
    27
    Thanks for the info guys, Im gonna try to put all the information into the first post. Just so that everything will be in one spot and wont have to search for it.
    Jay
    -Modded
    -Modded
  8. #7
    To purchase a birchmount rear spring.
    458 Birchmount Rd
    Scarborough ON, M1K 1M6
    Phone: 416-698-3636
    Also it is a steel leaf that he makes when ordered. I believe they are in the range of $200 + ship. Also you can order with any amount of drop you want, you just need to specify what you want.
    Kyle
    1988 Cutlass Supreme, White/Black Leather,L67 Swap in progress 95,000 miles.
  9. #8
    Join Date
    Apr 2003
    Location
    Toledo, OH
    Posts
    17,543
    Thanks
    1,105
    You should all the part numbers for new strut mounts, and any other parts needed for redo-ing your suspension.
    Chris D.-
    '97 Ford Ranger- Project forever
    '02 Buick Century- Wife's
    '08 GMC Acadia- Company Car/DD
  10. #9
    how much do the S/T front springs lower the car??
  11. #10
    Lurker
    Join Date
    Jan 2007
    Posts
    90
    Thanks
    0
    The rear of my car already sits low enough, between my system, convertible top motor and a 14yr old monoleaf spring Its the front I need to lower to make the car look more even. This is great though, Im gonna look into some of these options.
    2006 Pontiac GTO 6.0L
    2006 Pontiac G6 GTP 3900
    2006 Pontiac G6 GT 3500
    1997 Pontiac Grand Prix GTP L67
  12. #11
    Join Date
    Apr 2005
    Location
    Schenectady NY
    Posts
    9,489
    Thanks
    27
    Quote Originally Posted by slick
    I have now started that. Ive some several listed right now, but if theres anything else, LMK
    Jay
    -Modded
    -Modded
  13. #12
    Join Date
    Apr 2003
    Location
    Toledo, OH
    Posts
    17,543
    Thanks
    1,105
    Nice!
    Chris D.-
  14. #13
    Euro's Avatar
    Join Date
    Jan 2004
    Location
    Streamwood, IL
    Posts
    12,928
    Thanks
    374
    wow that's a really good writeup!!!!!! I don't know why I didn't see this until now since it's been up for a little while lol. Too bad I don't have my Lumina anymore
    -Matt
    2000 Regal GS - Stock is the bestest...stock is the fastest...
    2000 Grand Prix GT - Yeah sure, I miss you too
    1994 Lumina Euro - Miss you..
  15. #14
    Join Date
    Apr 2005
    Location
    Schenectady NY
    Posts
    9,489
    Thanks
    27
    Write up now includes Gen 1 and Gen 1.5 W-Body's. If there is anything I forgot to add please LMK!!!! Ill leave it at that for now until I get more information.
    Jay
    -Modded
    -Modded
  16. #15
    Euro's Avatar
    Join Date
    Jan 2004
    Location
    Streamwood, IL
    Posts
    12,928
    Thanks
    374
    Re: How to lower a W-Body ( Gen 1, Gen 1.5 )
    Quote Originally Posted by GutlassSupreme
    Ok so 1st gen Monte carlo lowering springs work on 93-95 Cutlass Supreme aswell? because if i can just get springs that will be way better.
    only the front springs will work for your cutlass. The rear you need to choose between the choices Jay listed in the first post.
    -Matt
pontiac grand prix 1992 se
how to lower lumina w body
95 buick regal gs
body gen
pontiac grand prix 1992 w-body
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
