Results 1 to 7 of 7
  1. #1
    Join Date
    Oct 2006
    Posts
    73
    Thanks
    0
    00-05 Monte Turn signals and hazards don't work.
    2004 Monte Carlo LS
    Was driving today and the turn signals didn't work. I pulled off the road and put on the left turn signal, it lights up on the dash,front of car and rear of car but does not blink. Also same thing when I use the right turn signal. Then I tried the hazards and all bulbs light but do not blink. What is this about and is there a solenoid I need to replace or relay???
    1994 Pontiac Grand Prix SE<br />-3100 SFI V6 191ci, Code M, 4T60-E, Cold air intake, Custom coil overs and Red <br />2004 Chevy Monte Carlo LS<br />-3400 SFI V6, Blue<br />
  2. #2
    Lurker DiscoStudd's Avatar
    Join Date
    Apr 2004
    Location
    St. Paul, MN
    Posts
    3,221
    Thanks
    0
    Re: Turn signals and hazards don't work.
    The flasher is integrated into the hazzard switch. The hazzard switch is notorious for failure in the 00+ Impalas/Montes, so that'd be the first thing I'd check...
    Kevin B.
    2004 Chevy Impala 3400 V6 - Color: Victory Red
    1999 Chevy Tahoe 5.7 Vortec V8 - Color: You guessed it, Victory Red!
  3. #3
    Join Date
    Oct 2006
    Posts
    73
    Thanks
    0
    Where is the flasher located on an '04 monte?
    Found this:
    The flasher is an integrated module for both turn signals and emerg. flashers. It is located in a junction block that is mounted on the firewall to the left of the steering column under the instrument panel. You have to remove the sound insulator panel and the lower steering column cover to get at it.
    Is this correct? Will find out soon enough.
  4. #4
    Euro's Avatar
    Join Date
    Jan 2004
    Location
    Schaumburg, IL
    Posts
    13,429
    Thanks
    377
    on my car one is right below the steering column, behind all the wires. I had to really climb below my dash, but its easy to get off/on
    -Matt
    2000 Regal GS
  5. #5
    Banned
    Join Date
    Aug 2004
    Location
    Toledo
    Posts
    6,434
    Thanks
    368
    If you take out the gauge cluster of the dash its right behind that on the right side of it you can push the whole assembly through the front of the dash if careful, "Lucas" electric made the flasher unit as in the English Prince Of Darkness...same reason Limeys Drink Warm Beer, dont know why...it's because they have Lucas refrigerators.
  6. #6
    Join Date
    Apr 2004
    Location
    St. Paul, MN
    Posts
    3,221
    Thanks
    0
    Quote Originally Posted by Eurosport94
    Completely different on the 00+ Chevys. There's one flasher and it's integrated into the hazzard switch. Hint: Locate the large button on the dash with the red triangle on it. Remove and replace the whole assembly. On the Impala, the whole dash bezel needs to be removed in order to access it, the Monte should be no different.
    http://www.impalahq.com/HowTo/Dash.html should get you in the ballpark...
    Kevin B.
  7. #7
    Join Date
    Oct 2006
    Posts
    73
    Thanks
    0
    Bought from gmpartsdirect.com. They are cheaper than the dealer ($45.00).
    GM Part #10359032, SWITCH
    SUBTOTAL: $25.78
    PROCESSING & HANDLING TOTAL:$9.95
    ORDER TOTAL:$ 35.73
2004 monte carlo turn signal problem
2002 monte carlo turn signal problems
2004 monte carlo turn signal flasher
2002 monte carlo blinker relay
2002 chevy monte carlo turn signal problems
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
