the info above is correct, though you might find splicing into and not cutting easier. I also imagine that the E/M wire terminates in an unused connector that is hidden in the dash, but i have not confirmed this...(will look for a harness I have that will answer the question and edit the post at that time)
Should you decide you want to be able to enable or disable E/M at any time, you can add a switch to ground or unground the E/M wire it as needed...
