Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
  1. #1
    3100 a good engine?
    I have the 3100 in my gp. I was wondering it its a good engine or not. Like wahts the most common problem with it? How many miles do they last before any major problems? Whats the average MPG? how dumb of a question taht might be.
    Also the tranny( 4spd auto) how long do they usually last?
    *94 Grand Prix Se
    <br />http://www.cardomain.com/ride/2212449
  2. #2
    Robby1870's Avatar
    Join Date
    Nov 2002
    Location
    Lexington, KY
    Posts
    6,742
    Thanks
    0
    Re: 3100 a good engine?
    Treat it like any 12 year old car. Do regular maintainence, plugs, wires, sensors, filters, fluid changes, etc and it'll last a long time. Average mpg for a 3100 in a W is around 20 city, 30 highway, if it's properly maintained.
    Robby Whitesell
    2006 Pontiac G6 GT - 3500 V6
    1985 Toyota Pickup DLX - 2WD - 2.4L I4
  3. #3
    Backseat M0derator jeremy's Avatar
    Join Date
    Oct 2003
    Location
    Livonia, MI
    Posts
    17,414
    Thanks
    258
    watch your intake gaskets
    2013 Veloster Turbo 6spd MT
  4. #4
    When should the gaskets be changed?
    *94 Grand Prix Se
  5. #5
    if you have no record of them ever being changed either have them changed or do it yourself if your mechanically inclined.
    James
    [Jonpro03] 2:28 am: when i first joined... i wondered why ppl here cared so much about semis
    [Jonpro03] 2:29 am: then i realized international was a type of cutty
  6. #6
    19Cutlass94's Avatar
    Join Date
    Apr 2005
    Location
    Texas
    Posts
    10,140
    Thanks
    40
    With proper care, a 3100 will last a LONG time. The biggest problem with these engines is the upper and lower intake gaskets. If you oil becomes milky, change them asap. If you start loosing coolant and dont know where its going, change them asap.
    As much as people here complain about the 3100 ( lack of power etc etc ) it really is a good engine, and no one can deny that.
    Jay
    1994 Oldsmobile Cultass Supreme SL
    3400/Getrag 284
    1995 Chevy K1500 350c.i. 5spd Z71
    Stock
  7. #7
    Its a really good engine, and for the era, it makes plenty of power, especially for being the base V6. Seeing as how i've run mid 16 1/4 miles with it, being totally stock, it can still hang with a lot of stuff on the road. I guess I just don't expect miracals from a 1994 car.
    Change the intake gaskets and also change to the aluminum valve covers if you have the plastic ones. Change the spark plugs and drop the transmission pan and change the fluid and filter and you should be all set.
    2004 Chevrolet Colorado ZQ8 Extended Cab 3.5 I-5 5-speed<br />K&amp;N FIPK, Flowmaster 40 muffer...lots of power and really loud<br />1970 Plymouth Duster 360 4-speed - project<br />1994 Cutlass Supreme Convertible 3.4 DOHC -Dad&#39;s Toy
  8. #8
    Well i got new tranny fluid and a gasket. What spark plugs would you recommend?
    *94 Grand Prix Se
  9. #9
    Join Date
    Oct 2003
    Location
    Livonia, MI
    Posts
    17,414
    Thanks
    258
    delcos
  10. #10
    Ok ive heard about them before. Anything else i should do? My engine has 124,xxx miles on it.
    *94 Grand Prix Se
  11. #11
    when i did my tune up i got ac delco plugs and wires (platinum plugs because that is what is stock), fram fuel filter, pcv vavle, cleaned my k&n, cleaned the engine (clean engine run cooler then dirty ones), and a added some fuel systems cleaner to a empty tank of gas then filled up. When it comes to the gaskets I wouldnt recommend changing them until you see some warning signs. No reason to replace something that is working fine.
    Mathew Smith <br />2009 Yamaha R6 - I love gold!
  12. #12
    Join Date
    Oct 2003
    Location
    Livonia, MI
    Posts
    17,414
    Thanks
    258
    Quote Originally Posted by 97loudcut
    I would bet that his intake gaskets are leaking, unless they have been replaced already
  13. #13
    MonteCarloChick's Avatar
    Join Date
    Nov 2003
    Location
    Lancaster, New York
    Posts
    2,983
    Thanks
    3
    It's better to replace something now then have to replace something way more expensive down the road.
    ♥ May 2007 COTM Winner ♥
    1996 Monte Carlo LS 3100 | 1981 Cutlass Wagon 307 | 1995 Tahoe LT
  14. #14
    Alright so so far I need to change my intake gasket, change my oil and coolant(been on list for a while), change my plugs and wires, and filter. Missing anyhting?
    Also what intake gaskets or both?
    *94 Grand Prix Se
  15. #15
    Join Date
    Apr 2003
    Location
    Cincinnati, OH
    Posts
    17,684
    Thanks
    1,194
    Both upper and lower intake gaskets. It will come as a kit if you plan on doing them yourself. BTW, if you do them yourself, set a weekend aside to do it, you will need the time starting like on a friday evening, until late saturday. If you are good with engine repair, maybe just 1 days worth of work. Having a shop do them, be ready to cash in anywhere between $500-$900.
    Chris D.-
    '02 Buick Century- Wife's
    2012 Jeep Grand Cherokee- Company Car/DD
pcv 3100 engine
pcv3100
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
