Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Thread: 94 cutlass
  1. #1
    94 cutlass
    ive replaced the starter, alt,battery and when I turn on the lights (either) ac or heat my amp guage drops to 8. turn signals work slow and the car wants to die at idle . Being that the amps are being drained from the car im having problems trying to start the car.when I put on the flashers they flash at a normal pace. anyone have any insight on this problem ty Mark
    everydays a holiday some just better than others
  2. #2
    Join Date
    Sep 2004
    Posts
    1,963
    Thanks
    2
    Re: 94 cutlass
    Are all of the battery connections tight and clean?? Also, check the aux. battery terminal and make sure that it is tight and clean. I had the Aux battery post come lose on my regal in the winter, and I was kinda afraid that I wasnt gonna make it home. I knew exactly what was wrong, but I didnt have any tools with me.
    1989 Buick Regal GS Four Seater | 3.1L&nbsp; 440T4 |&nbsp; No Longer with a Black hood * For Sale come spring? *<br />1994 Chevy Silverado Z71 | 5.7 L&nbsp; 4L60 - E | 1 of a few<br />2000 Buick Regal LS | 3800 Series II&nbsp; 4T65-E| 1 of Many
  3. #3
    Re: 94 cutlass
    all grounds have been cleaned including the ones that go to the head lights, and yes the terminals were the 1st thing I checked
  4. #4
    Re: 94 cutlass
    Did your battery die on you? Causing the alternator to have to work harder to keep the car running? My 88 cutlass did that and well I had to replace both at the same time that sucked......
    James
    [Jonpro03] 2:28 am: when i first joined... i wondered why ppl here cared so much about semis
    [Jonpro03] 2:29 am: then i realized international was a type of cutty
  5. #5
    SigEpCutlass's Avatar
    Join Date
    Dec 2003
    Location
    Arlington Heights, IL
    Posts
    4,019
    Thanks
    0
    Re: 94 cutlass
    When the car is running without any accessories or lights on, is the voltage displayed on the dashboard over 13 or not?
    - Mike K.
    '94 Oldsmobile Cutlass Supreme SL 4AT - For Sale
    '00 Subaru Outback AWD 5MT - Soccer Mom Pimpin'
    '04 Mazda Mazda6s 5AT - Wife's
  6. #6
    Re: 94 cutlass
    if your remote post has a brass ring nut, replace it with a real nut. I've seen the brass ring nuts expand and loosen.
    BUILDER AND DESTROYER OF FINE(?) AMERICAN CARS.
  7. #7
    Re: 94 cutlass
    Mike, when all acc are off guage is at about 13 and signals work fine car runs gr8 , Ive also replace the turn signal switch also i got the 3.4 dohc so it not a vacation to take alt. off
  8. #8
    Join Date
    Dec 2003
    Location
    Posts
    4,019
    Thanks
    0
    Re: 94 cutlass
    The lowest my volt meter ever goes is about 10-11volts. That only happens if I have my headlights & foglights are on, 4 way flashers are on, Max A/C is on full blast, my stereo is on loudly (as always ), and the car is not in motion in either park or drive. You may just have a weak battery that is not allowing the alternator to charge it fully any more, or vice versa. If the car is in motion with the what is listed above, I'm still over 13 volts.
    I hope if anything your battery just needs to be replaced for your sake. Someone made a 45minute LQ1 alt change procedure, but it's definately a lot easier to change the alt on my L82.
    When how long ago exactly was everything replaced that you listed in your original post? That might help....
    - Mike K.
  9. #9
    Re: 94 cutlass
    Mike alt and battery about 7 months ago starter yesterday turn signal switch about 4 months ago
  10. #10
    Join Date
    Dec 2003
    Location
    Posts
    4,019
    Thanks
    0
    Re: 94 cutlass
    Do either the battery or alt have a warranty? This especially concerns the alt, as some places may even give you a new one under that warranty if it's gone bad. For example, I have a Bosch alternator in my car. I didn't have tools that year in college and I ended up having to pay pep boys to put that new alt in my car after a snowstorm. If it croaks, I can just go back to them with the paperwork and cash in my lifetime warranty to get a new alt, and they should even be installing it for me if I want b/c they did the work previously. Just a thought...
    - Mike K.
  11. #11
    Join Date
    Apr 2003
    Location
    Cincinnati, OH
    Posts
    17,684
    Thanks
    1,194
    Re: 94 cutlass
    So the battery drains when the engine is off? Or does the battery just not charge? Have you tested the output of the alternator with a multimeter? If it is the alt gone bad, check out the FAQ section. I wrote a 45 minute alternator repair for the 3.4 DOHC.
    Chris D.-
    '02 Buick Century- Wife's
    2012 Jeep Grand Cherokee- Company Car/DD
  12. #12
    Re: 94 cutlass
    Slick just went out and had system checked, all was ok . Went to NAPA to replace battery was only a few months old so I replaced it for $8.00. Question do you think the turn signal switch could be bad. The reason I say this is because even with a load on when I use flashers they blink fast (like they should ) and when I use turn signals it takes a second to come on when they do there slow
  13. #13
    Join Date
    Jul 2005
    Posts
    59
    Thanks
    0
    Re: 94 cutlass
    I had the same problem with my 94 3.1. Took it to the dealer and after about 20 min they took me out and showed me where the Fuse block next to the remote battery terminal was drawing too much power. It cost 150 or so for them to put a new fuse block (melted) and either clean or replace all of the wiring terminals in the block. This will be especially true if your gauge in the cluster is bouncing because the cluster wiring is routed through this block
    94 Olds Cutlass Supreme SL&nbsp;&nbsp; 3.1/4T60-E/185K and still going
  14. #14
    Join Date
    Jul 2005
    Posts
    59
    Thanks
    0
    Re: 94 cutlass
    Also, I would not reccomend that you try to do this yourself because the terminals are a bear to find and they take forever to replace.
  15. #15
    Re: 94 cutlass
    to everyone that helped me on this post . beleive it or not I had a short in the turn signal switch . replace it today every thing runs gr8 on a load
94 cutlass remote terminal
94 cutlass supreme remote battery post replacement
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
