Results 1 to 8 of 8
  1. #1
    Join Date
    Jan 2006
    Posts
    61
    Thanks
    0
    95 Lumina bent pushrod
    I picked this Lumina up to fix because it had a loud tapping noise and the owner didn't want to fix it. I figured it at least had some good parts if not repairable or I might fix it if it wasn't too bad, for my kid to drive. How bad could this be? Attached pictures.
    What disaster am I in for by trying to fix this?
  2. #2
    Re: 95 Lumina bent pushrod
    looks like the rocker arm just loosened up or the stud is almost broken
    2004 Chevrolet Colorado ZQ8 Extended Cab 3.5 I-5 5-speed<br />K&amp;N FIPK, Flowmaster 40 muffer...lots of power and really loud<br />1970 Plymouth Duster 360 4-speed - project<br />1994 Cutlass Supreme Convertible 3.4 DOHC -Dad&#39;s Toy
  3. #3
    Join Date
    Jan 2006
    Posts
    61
    Thanks
    0
    The push rod is bent bad. I was thinking of just replacing it but the previous owner had some gasket work done and something could have got switched like the intake and exhaust push rods. I need to make sure the rest are correct. I have never done these before so looking for advise before I replace it and miss checking something else while its apart.
    Thanks,
    Mike
  4. #4
    The intake and exhaust pushrods are all the same length, you can not mix them up... well at least thats what i think... but they are the same length, it looks as though the rocker arm came loose from vibration, whoever did the work before must have used the wrong torque specs per the documentation in the service manuals, and internet resources
    Replace the pushrod, then add a new one in.
    You will need to take off the lower intake manifold and everything above it. You might be able to just take that pushrod out since the rocker arm and what not are moved aside. if it is possible pull out that pushrod with some pliers or something, then set another in.
    Now i am not sure if that will work, seeing as the rocker arm holds down the lifter and i do not know so make sure you double check with other people here on the forum before diving in.
    The engine is salvageable though. if you end up taking it all apart replace the main bearings and lifters to make it last longer.
    1991 Lumina Euro 3.1 Vin T TH125c<br />custom dual flowmaster exhaust<br />clear corners<br />Needs a new engine old one seperated a piston from the rod, probably has block damage <br />She&#039;s decommisoned<br /><br />--------------------------------------------------<br /><br />[quote author=93z34 link=topic=45741.msg547358#msg547358 date=1150080157]<br />I would like to keep in mind that I plan on adding about 7 more neons in the interior... you&#039;d be amazed what a light show does to the horniness of a high female&nbsp; <br />[/quote]
  5. #5
    Join Date
    Sep 2002
    Posts
    6,452
    Thanks
    40
    they are not the same length
  6. #6
    really? the 93 one i pulled apart had pushrods and they all looked the same... maybe i was smokin some crack that day? hmm like i said don't believe what i say lol double check it with another person on the forums.
  7. #7
    19Cutlass94's Avatar
    Join Date
    Apr 2005
    Location
    Texas
    Posts
    10,140
    Thanks
    40
    The push rods for the exhaust are longer than those for the intake.
    Just make sure you dont have a cracked spring or theres no damage to the rocker arm or the stud. Take the rocker arm off, clean it up real good and just inspect it. But from the pictures, doesnt look too bad. You just get away with replacing a push rod
    Jay
    1994 Oldsmobile Cultass Supreme SL
    3400/Getrag 284
    1995 Chevy K1500 350c.i. 5spd Z71
    Stock
  8. #8
    the pushrods are DEFINATELY a different length. i have mixed them up before and I will say the car does not run very well at all when you do that.
    99 Grand Prix GT 242,800+ miles<br />9.75:1 L36|K&amp;N|No Cat/Ubend/res|160 tstat|UD ALT|Shift Kit|Powertuner|Ported M90/LIM/TB/Heads|XPZ|Stg 2 IC|Pacesetters|ElecWP|AlumCradle|4340 IS|2.93 15/16&quot; Chain|2750 stall|2.55&quot;. <br />379.9whp on 93 octane, 11.9912 @ 112.99 w/1.729 60&#39;<br />Gen V/N* TB/3.69s since ET.<br />03 CBR 600RR Stock.&nbsp; 11.38 @ 123.64
gm 3.1 bent pushrod
3.1 pushrod order
95 oldsmobile cutlass 3.1 pushrods
pushrod order 3400
bent pushrod 3.1 gm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
