Results 1 to 8 of 8
  1. #1
    Lurker
    Join Date
    Feb 2004
    Location
    RI
    Posts
    3,955
    Thanks
    0
    here's a question
    Has anyone tried bolting DOHC heads onto a 3400?
    If possible, would there be any advantage?
    -Tony
    gtsdurango.net
    '90 Turbo Grand Prix STE - Crane H260 Cam, Getrag 282 Swap, 1.6 Rockers, Intrax Front Lowering Springs, KYB GR2s, 34mm Sway Bar, CS FSTB, AWeb RSTB, ES Poly Sway Bar Bushings, Cooper Cobra 245/50s, Speed Primer, Hail Speed Dents, NFG Keyless Entry, Lots of Extra Wiring - Running once again! Sorta!
    '92 Gutless Supreme SL - RIP 5-10 | '90 Turbo Grand Prix - RIP 6-15-05
  2. #2
    Community Manager White93z34's Avatar
    Join Date
    Jan 2004
    Location
    Pittsburgh, PA
    Posts
    10,379
    Thanks
    43
    here's a question
    i don't think it can be done. oil passages may or may not be there, i'm asumeing that you'd remove the cam and instal the dummy shaft. and somehow try to route the belt to run the cams. i don't think it can be done.
    -Chris D. - Your Community Manager
    Quote Originally Posted by Breakdown View Post
    Now I know that some people are hesitant at times to follow some of my ideas and then refer to them as scams, etc.
    1992 Chevrolet Lumina Z34 3.4L TDC v6 Getrag 284
    1990 Pontiac Turbo Grand Prix 3.1L v6 Hydramatic 4T60
    1997 Pontiac Bonneville SSE Supercharged 3.8L v6, Hydramatic 4T60E
    1987 Chevrolet Camaro Z28/IROC-Z 5.0L v8, Hydramatic 700R4
  3. #3
    here's a question
    Soneone on 60*V6 put the LQ1 heads onto his Aluminum bowtie 3.4 Block. There was a lot of things that didn't line up.
    -Sean
    Current: 2003 Mercedes-Benz E500: M113/722.6 // Previous: Regal GS - 3800 L67 : 4T65-E HD -Sold
  4. #4
    Join Date
    Aug 2002
    Posts
    1,055
    Thanks
    0
    here's a question
    Really , there wouldn't be any advantages to that... the nice thing about the 3400 block is that is a roller cam , and if your using a dummy cam in it's place... there is no point.
    The other nice thing about the 3400 is it's heads, but once again , if your just going to use the DOHC heads.....
  5. #5
    Lurker
    Join Date
    Apr 2003
    Posts
    2,026
    Thanks
    0
    here's a question
    I had a 3.4 lq1 head next to a 3.1 head a couple years ago, the coolant passages, oil passages and lifter vally are all very different
    Baby Daddy
  6. #6
    Join Date
    Dec 2003
    Posts
    200
    Thanks
    0
    here's a question
    I dont see it working. That being said if it did, i honestly could see some advantages....
    2003 Monte Carlo<br />3400 V6<br /><br />For the 1st time in my life I see the car as MUCH more of an appliance than a fun thing.
  7. #7
    Lurker
    Join Date
    Apr 2003
    Posts
    2,026
    Thanks
    0
    here's a question
    I wanted 2 figure out how to put pushrods into 3.4 heads....it was a nice thought, aint no way it's gunna happen though
    Baby Daddy
  8. #8
    Lurker
    Join Date
    Feb 2004
    Location
    RI
    Posts
    3,955
    Thanks
    0
    here's a question
    I was wondering about coolant/oil passages... I wasn't sure exactly how different the blocks where between the two. (LH0 or LA1 etc vs. LQ1)
    I couldn't really see an advantages either I guess.. just wondering if it could be done. Started off wondering if you could throw them on a 3.1 or 2.8 block but at least the 3400 has the same bore...
    -Tony
    gtsdurango.net
Nobody landed on this page from a search engine, yet!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
